Compression of our motor and octane
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MA250, Oct 16, 2019.
  1. Oct 16, 2019 at 10:54 AM
    MA250
    MA250 [OP] Well-Known Member
    2019 Tacoma TRD Pro
    Stock
    I have reached 10K miles. For the last 8K miles I've been running Mobil Supreme 93 octane. 1st couple thousand miles I ran regular. To me the engine runs considerably smoother on 93 octane compared to 87/89 Research on web leans toward I should not notice a difference. So this week I switched to mid grade 89 octane. I can definitely notice a difference after 3 trips to work and back home. Exhaust note is slightly louder and engine not nearly as smooth. I'm thinking the higher compression of this engine compared to typical is the reason. I'm thinking the ECU will slowly advance timing if not sensing engine knock. This advance in timing can be achieved do to the higher octane resulting in smoother performance. What do you guys\gals think or experience?
    cryptolime, TimC, CTF and 1 other person like this.
  2. Oct 16, 2019 at 10:58 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
  3. Oct 16, 2019 at 11:19 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    87 for me. It does run a bit smoother on 92, but either has the same MPG (on OVT) or loses mileage (stock).
    Below is a lot of good info about the engine. The octane noted (91) is non-US Research, not AKI.
  4. Oct 16, 2019 at 11:21 AM
    steven.croteau
    steven.croteau Well-Known Member
    Steven
    Maine
    2017 TRD OR
    You're wasting your money, the exhaust note is not changing from running 93 octane and any smoothness is just the lighter wallet making you sit flusher to the seat.
  5. Oct 16, 2019 at 11:22 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    The compression ratio for the 3.5l V6 is 11.8:1 compression
  6. Oct 16, 2019 at 11:25 AM
    Clearwater Bill
    Billy
    Largo Florida
    Do what you wish.
    But at the delta of reg vs premium you'll never have a ROI based on MPG or service life.
    Although the oil companies will thank you for funding their business.
  7. Oct 16, 2019 at 11:26 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    My theory is low MON sucks.
    87 AKI=91 RON=83 MON
    91 AKI=95 RON=87 MON
    Read up on RON vs MON testing...makes sense to me.
    Cementoffroad and tonered like this.
  8. Oct 16, 2019 at 11:31 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
  9. Oct 16, 2019 at 11:34 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    You not the first guy on here to claim to know more than the engineers.
  10. Oct 16, 2019 at 11:37 AM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    I don't think there's one good answer here. We do know the engine compression ratio is 11.8 to 1, but we also know that varies due to variable valve timing. That valve timing is adjusted based on engine load AND other factors, including fuel quality. The ECM determines fuel quality constantly, so in theory if it detects higher octane fuel, it can use different valve timing for more power/efficiency.
    Just my .02
    Kodiak420, D.A.S. Taco and GillyLink like this.
  11. Oct 16, 2019 at 11:39 AM
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    “Premium” labels got your panties all moist ay? Don’t worry lots of others on here that believe that shit too.
    Here we go again boys. Let’s ride the shit out of this bitch! Woo Hoo! :D
    I mean Friday close isn’t it?
  12. Oct 16, 2019 at 11:40 AM
    skierd
    skierd Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
    I notice a difference in power delivery and smoothness in my truck running premium vs regular. It cures most of the shifting and drivability problems for me honestly, and I get roughly 0.5mpg better. I think the stock ECU pulls a ton of timing, valve and spark, to compensate for regular gas which leads to the drivability problems so many 3rd gen owners complain about.
  13. Oct 16, 2019 at 11:50 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    If you monitor OBD2 data, the "adaptation" to premium is pretty darn instant. Its not like the old days when you either experienced no difference in performance or drivability OR it took multiple tanks before you'd notice a difference. These finely tuned knock sensors are ALWAYS advancing timing until knock, then holds, then will continue to attempt to advance periodically to maintain a -3 knock feedback value. You can run down a tank of 87 octane and see the knock feedback timing go from 18 degrees to the high 20s within minutes of filling up w/ premium and yes - this debate never ends on here, but the truck runs smoother on premium. It will survive on 87 and was designed to do so, but if you can justify the cost / afford it, this engine loves to drink the top shelf stuff. period.
  14. Oct 16, 2019 at 11:50 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Just a small clarification, VVTi does not change the compression ratio. Infiniti has the only motor in production with a variable CR.
  15. Oct 16, 2019 at 12:02 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I remember years ago reading about Saab working on some sort of weird variable compression engine, the Head actually slid up and down, seemed like that would have been a reliability nightmare.
  16. Oct 16, 2019 at 12:03 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    For older vehicles a 11.8:1 compression ratio would require race fuel only
  17. Oct 16, 2019 at 12:05 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yep. It was a nice science experiment. I don't really trust Nissan / Infiniti either.
    Mazda seems to have solid footing on very high CRs. Maybe they'll bring back the Wankel someday?
    Now, the Saab 2.0l HOT was a monster of a motor. I kinda miss it at times. If only it was hooked up to the proper wheels, we might still have it.
  18. Oct 16, 2019 at 12:10 PM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    I generally run 87 because it's cheaper where I am. But I swear the few times I've run 91 in the tank, the engine tick has been dramatically lower. I've even had other people notice it. And the gas is from the same station
  19. Oct 16, 2019 at 12:14 PM
    SDTaco4x4
    SDTaco4x4 Well-Known Member
    San Diego
    2016 Black TRD Sport 4x4
    Yep, I made the switch from 87 to 93 a couple months back and the difference is night and day. The engine runs better and I get a little better mileage.
    YUKONSLY, LV-TAC, D.A.S. Taco and 3 others like this.
  20. Oct 16, 2019 at 12:21 PM
    Mister Grey
    Mister Grey The Viking of disapproval looks in your direction
    Hayward Ca
    2017 Tacoma DCLB Sport 4x4
    The Works.
    Yeah! I was gonna say my dirtbike has an 11.5:1 piston AND a stage 2 cam and only runs on 110 octane.
    US Marine[QUOTED] likes this.
