Compression test how to / missing step?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Lars A, Mar 22, 2025.
  1. Mar 22, 2025 at 1:35 PM
    Lars A
    Lars A [OP] Active Member
    2002 Tacoma TRD
    Lift and HD bumpers
    My 2002 Tacoma 3.4 has developed a miss. I have changed spark plugs with no resolution. I've owned mostly diesel 4 cylinders over the last 30 years, so my knowledge of the whole ignition coil type system is limited. I was about to buy all new coils and wires, and the parts house guy says, "Why don't you do a compression test before you throw all that money at it?" An excellent idea, but I've never done a compression test. A video I watched gave a basic procedure of:
    1. Remove all plugs.
    2. Disconnect the distributor so it doesn't short out (but the 2002 Tacoma doesn't have a distributor).
    3. Disconnect injector wiring.
    4. Install compression gauge, and roll it over 3 or 4 times.
    Anything above 200 is good. Cylinder pressures should not be more than 10 to 15 different between cylinders.
    Does this sound like the right procedure?
    Since the Tacoma doesn't have a distributor, is there something else I should be disconnecting to avoid damage?
    Thanks very much for your help here!
  2. Mar 22, 2025 at 2:04 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    So just remove the EFI fuse (within the main engine bay fuse box), then you don't have to worry about disconnecting all the injector wiring.
    No need to worry about the plug wires or a distributor (just drape the wires off the side off the motor out of your way) .
    And usually you want to crank the motor for about 5-6 seconds or more (until the gauge stops climbing and building any further compression). Ideally you'd also get the motor nice and warm before the test (drive it for a while), then quickly get the plugs out, remove the EFI fuse and do the test.
    If you do the test on a completely cold motor, you'll get lower compression readings that aren't really accurate for what it'd develop under normal running conditions.
    Lars A[QUOTED][OP] and Dm93 like this.
  3. Mar 22, 2025 at 2:08 PM
    Lars A
    2002 Tacoma TRD
    Lift and HD bumpers
    Thank you so much!
  4. Mar 22, 2025 at 2:08 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Just pull the EFI fuse to disable fuel and spark, no need to unhook anything. Hold the throttle wide open while cranking.
    Standard compression for the 3.4L is 174psi, minimum is 145psi, maximum difference between cylinders is 15 psi.
    Lars A[OP] and Red_03Taco like this.
  5. Mar 22, 2025 at 2:16 PM
    Lars A
    2002 Tacoma TRD
    Lift and HD bumpers
    Excellent info! Thank you!
  6. Mar 22, 2025 at 2:23 PM
    Bishop84
    Bishop84 Well-Known Member
    I have never seen over 200 haha, altitude matters as well. We see 130-150 on older V6s like yours.
    Let us know.
    Lars A[OP] likes this.
  7. Mar 22, 2025 at 2:26 PM
    Red_03Taco
    Jerad
    I got the 160s-170s a couple years back when my truck had 280k miles, and that's up in Prescott, AZ at 5300 ft. Pretty pleased with that
  8. Mar 22, 2025 at 2:48 PM
    Bishop84
    that’s great we are a little lower than that and always happy to see 160+
  9. Mar 22, 2025 at 5:56 PM
    Glamisman
    Glamisman Well-Known Member
    Is the CEL (check engine light) on?
    Do you have a scan tool?
    Compression test is a good starting point. If the compression in the lowest cylinder is within 10% of the highest cylinder you are good to go. If the compressions are outside that range IMHO I would check valve clearances. If they are out of spec I would seriously consider taking it to a shop that can do the job. It isnt that it is a difficult job it is getting the adjusting shims.
    The ignition system on the 3.4 is what is called a wasted spark ignition system. You will see that there are only 3 coils for a 6 cylinder motor. When each coil fires on the respective compression stroke the companion cylinder that is on the exhaust stroke that spark plug is fired too.
  10. Mar 23, 2025 at 12:38 PM
    Lars A
    2002 Tacoma TRD
    Lift and HD bumpers
    Thank you all for the excellent information! I'll let you know when I finish the test.
  11. Mar 26, 2025 at 10:21 AM
    Lars A
    2002 Tacoma TRD
    Lift and HD bumpers
    I ended up not having to do a compression test, but I have saved your advice for next time. I found a problem with the plug wires, resolved that, and it runs smooth again!
    Thank you all, once again! Your help is very appreciated!
    Red_03Taco and Dm93 like this.
