Compression test result on a 3.4 V6 engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacopablo, Nov 23, 2015.
  1. Nov 23, 2015 at 7:50 AM
    tacopablo
    tacopablo [OP] Well-Known Member
    Québec
    2002 tacoma 2.7l
    Hey,
    I did a compression test on my engine. It run good but I did it by curiosity.
    The result: starting from the right front cylinder :
    1:179 4:179
    2:150 5:150
    3:180 6:180
    The results seems to me very symetrical, but the center cylinders have less compression ( 17% less)
    Is it normal or there is a problem?
    opteron likes this.
  2. Nov 23, 2015 at 8:15 AM
    Indy
    Indy Master of all I survey.
    Per the Toyota FSM 2001
    With fully open throttle, and a full charged battery to obtain at least 250 RPM on a warm engine.
    5VZ-FE
    174psi or higher
    145psi Minimun
    Difference between cylinders 15psi
    I'd retest and do a leakdown, otherwise you've got 2 cylinders on their way out. The engine will run quite a ways lower yet, especially with 4 good cylinders pushing but you'll be losing some hp/mpg on those 2 eventually. I have no personal experience with those motors but from reading, 2 and 5 seem to be problem cylinders, 2 being the more prevalent.
  3. Nov 23, 2015 at 10:47 AM
    tacopablo
    Québec
    2002 tacoma 2.7l
    The spark plug on the cylinder 2 had some burning on it... I dont know if its linked...
    Thanks for the answer!
  4. Nov 23, 2015 at 12:04 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    The engine is still good. Low compression could be from piston ring wear or a leaky valve.
  5. Nov 23, 2015 at 9:38 PM
    Indy
    Burnt oil on the plug, best guess is piston ring.
  6. Nov 23, 2015 at 10:17 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    there's another test you can do, put some oil in the cylinder (coil not connected to spark plug) and do the compression test. i think if you do this, and the compression improves, you need new rings. or something like that. few beers and everything's a little fuzzy. can anyone else chime in on this?
  7. Nov 23, 2015 at 10:20 PM
    CodeSeven
    Serge.
    Coachella Valley
    or you could use chevron gas and/or system cleaners to remove potential carbon buildup on the valve seats that could be allowing compression loss.
    ThorInc likes this.
  8. Nov 23, 2015 at 11:27 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Yes, if compression increases with a little oil in the cylinder its usually a sign of worn rings. Low compression could also be something as simple as valves needing adjustment.
  9. Nov 24, 2015 at 11:21 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Thats roughly correct. Whats incorrect is directly attributing bad rings to it, there could still be bent valve if you money shifted or the timing belt lots a tooth. Though some level of blowby is expected and designed in to allow for thermal expansion. Not offsetting the break in the engine rings during installation can cause extra blowby. Most often a lack of compression is through crack heads or a bad head gasket
  10. Nov 26, 2015 at 5:54 AM
    johnny3
    johnny3 Well-Known Member
    01 Tacoma TRD
    Squirt a little oil in the 2 low cylinders & then test again, that will most always narrow it down to rings or valves (as undying said). That engine will run a long long time just like it is.
  11. Nov 26, 2015 at 7:55 PM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    "there could still be bent valve if you money shifted or the timing belt lots a tooth."
    3.4's are non-interference motors so a timing belt jumping wouldn't result in a bent valve.
    ThorInc likes this.
  12. Nov 27, 2015 at 12:58 AM
    CodeSeven
    Serge.
    Coachella Valley
    Oh man.... other day a daewoo head came by my shop for rebuilding. Timing belt had broke. 8 of the 16 valves were bent. 2 intake, 6 exh. And i had to hammer the valves out just to start the whole rebuilding process. he's likely going to need new valve guides and seats. It was ugly :-( but it's still a couple hundred dollars cheaper to rebuild than to buy used.
    thewarriordinghy likes this.
  13. Nov 27, 2015 at 2:57 AM
    Caligula
    Los Angeles, CA
    Daewoo..... :laughing:
  14. Nov 27, 2015 at 7:09 AM
    68dave
    Dave
    Some timing belt engines will damage valves if the timing jumps or if the tb breaks, that's a interference motor. But the 3.4L is a non-interference motor.
  15. Nov 27, 2015 at 5:50 PM
    CStoy
    CStoy mountain-top maniac.
    majestic gold 4x4... 1/4 million miles and counting!
    improved toyota goodness.
    so i did mine today out of both curiosity and boredom
    from right front;
    1:175 2:176
    3:169 4:164
    5:166 6:231
    #6 ...231 is really out of spec with the rest not to mention really high so i suspect error...241543 miles.
