Compressor replacement on my 2008
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ComaChameleon, Jun 3, 2025.
  1. Jun 3, 2025 at 3:42 PM
    ComaChameleon
    ComaChameleon [OP] 2008 Tacoma TRD
    Karla
    2008 Tacoma TRD
    Siderails
    Macanic said my air compressor is cracked badly some belt and pullys needs replacement. $1800. That sound about right to you folks?
  2. Jun 3, 2025 at 4:17 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    What air compressor?
  3. Jun 3, 2025 at 4:19 PM
    Nevin
    Nevin Well-Known Member
    Washington
    03 Tacoma 3.4 SR5 2022 TRD ORP 4Runner.
    OME 881 springs with 3/8 spacer. SCS SR8 16x8 Gunmetal 285/75/16 Yokohama G003 Nitros all 4 corners. Dakar rear leafs. Deckplate mod. Marlin Crawler 1200lb clutch. Redline hood struts. ECGS clam shell bearing. Philips LED headlights. Front Runner bed bars. Katskinz leather interior.
    A/C compressor I'm guessing...
  4. Jun 3, 2025 at 5:07 PM
    ComaChameleon
    Karla
    2008 Tacoma TRD
    Siderails
    (Jimmyh..Is there more than one?)
    Yes, A/C compressor.
    It had an obnoxious occasional rattle at stop lights. Even when the a/c was off and w/ just the fan on.
    It would never make the noise for the macanic, of course.
    When they put it on the rack... saw the compressor was "bady cracked". And some other things needed replacement belts/pullys while the compressor was removed.
    $1800 was the quote.
    It didn't seem like something I should ignore.
    I walked home,... it will be done tomorrow afternoon.
  5. Jun 4, 2025 at 9:53 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Just trying to get clarification. You said "Air Compressor" Toyota doesn't come with an Air Compressor....
    An A/C Compressor ( Air Conditioner Compressor ) is a different animal entirely.
    I would say that A/C Compressor, belt and Pulleys for $1,800 is a good price.
    That being said I think the Mechanic is full of poop as a cracked A/C Compressor is not going to work properly.
    Did he show you the crack?
    Does the Air Conditioner System work other than the intermittent rattle?
  6. Jun 4, 2025 at 9:58 AM
    69 Jim
    69 Jim 4-word Jimmy
    PNW
    2013 Standard Cab 4x4
    For eighteen hundred bucks seems like he found your crack alright.
    Rob MacRuger and Jimmyh like this.
