Computer Chip Key For '09 Taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rickochet, Nov 4, 2008.
  1. Nov 4, 2008 at 10:48 AM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    I didnt notice what model you had my bad man.
  2. Nov 4, 2008 at 10:53 AM
    ggparts
    ggparts Member
    Ottawa, Ontario Canada
    08 Access Cab SR5 Automatic 2WD
    Trifecta Tonneau Cover
    and there is an indicator light on my dash, I believe I have immobilizer installed but the model is built for Canada eh! Think that makes a differnce or is the light just for show?
  3. Nov 4, 2008 at 11:07 AM
    Mingy
    Mingy Well-Known Member
    Milton, Ontario
    V6 uble Cab TRX/Towing
    Lear cap.
    I was told the little round dot near the plastic was where the chip was - sounds credible - and the pix lack that dot
  4. Nov 4, 2008 at 1:34 PM
    Rickochet
    Rickochet [OP] Well-Known Member
    Rick
    Kentucky
    '09 Tacoma Access 2.7 4 x 2
    Added VS Wipers, Cruise Control, DRL, Undercover SE Bed Cover
    I don't think I mentioned the model until I posted the Toyota link, my bad. :)
  5. Nov 4, 2008 at 1:59 PM
    Rickochet
    Rick
    Kentucky
    Who knows. Could just be a diff between the '09 and '08 models. I have been following a DIY cruise control thread and apparently the '09's don't have some the preinstalled wiring the earlier years had. And some of the trucks made in Mexico were a bit different also. Confusing, eh? :confused:
  6. Nov 4, 2008 at 2:27 PM
    gfisher99
    gfisher99 Active Member
    Austin, TX
    11 MGM TRD Sport DC
    My 2009 X-Runner Key (I have immobilizer) has the little dot on the metal part of the key just under where the rubber meets the metal part.
  7. Nov 4, 2008 at 3:12 PM
    Rickochet
    Rick
    Kentucky
    Mine has no dot. I does have the letter "L" stamped in. Thanks for the info.
    Rick
  8. Nov 4, 2008 at 4:27 PM
    Tino4980
    Tino4980 Well-Known Member
    Bermuda Dunes, California
    09 TRD Off Road 4x4, 6 Speed , Magnetic Gray
    You Are Correct Mingy, if theres a round dot on top of the shaft near the plastic then you have it, if no dot then you dont, i work at Lowe's in the hardware department and i cut alot of keys everyday dont go to the dealer if you want another key with a chip go to your nearest lock shop and there alot cheaper there $40 bucks or so better then paying $115 or $130 at the dealer
