Computer cuts power 1st to 2nd gear at times
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kurti7711, Jan 21, 2023.
  1. Jan 21, 2023 at 5:43 PM
    Kurti7711
    Kurti7711 [OP] New Member
    Kurt
    11 Tacoma dclb
    Mainly stock other then billstein 5100s, soft topper, rear hooke road bumper, off road led lights, hello wheels, good year wrangler authority's 265-70-17, mounted air tank and fire extinguisher in bed, bed led lights, remote start, touch screen stereo with amp and subs to highs and lows
    I have a 2011 Tacoma Sport with a V6. I've noticed once in a while when it shifts from first to second the computer will cut power (a slight hesitation occurs) but no slipping felt. Could this be normal and i never noticed before? Or a weak shift solenoid. There are no codes, fluid level, and condition is good?
  2. Jan 21, 2023 at 6:01 PM
    Bishop84
    Bishop84 Well-Known Member
    Does it flare or just do nothing for a slight second?
    Not much you can do until it’s more pronounced, usually with my experience its a solenoid but typically it triggers a code. When did you change/ check fluid last?
