Computer modifications on first maintenance visit?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tombiosis, Mar 8, 2016.
  1. Mar 8, 2016 at 7:08 AM
    tombiosis
    tombiosis [OP] Well-Known Member
    T
    Ottawa Canada
    2016 TRD offroad access
    2016 Tacoma Access Cab, Super White, TRD Off Road package,//OEM Running Boards//TriFold2.0 Tonneau Cover//FJ Cruiser TRD SE Black TrailTeams replca wheels!
    Ok so I have scheduled my first oil change visit, and I get a free computer mod when I go...
    I plan on disabling the seat belt chime, and changing the signal touch feature to four blinks.
    What are some of the other options I have regarding mods to the computer???
    What mods have others asked for???
    Thanks
  2. Mar 8, 2016 at 7:10 AM
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    One touch of fob unlocks both doors would be awesome
    Also permanently disable traction control/vsc lol
    tombiosis[OP] likes this.
  3. Mar 8, 2016 at 7:16 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Good luck with the seat belt chime... I could see a law suite looming if they did that AND customer got killed in an accident without a seat belt.
    ZachMX likes this.
  4. Mar 8, 2016 at 7:21 AM
    tombiosis
    T
    Ottawa Canada
    ^^^lets not start that conversation! I do fence maintenance and drive in farm fields stopping every 25 feet to tighten fence staples...:lalala:
    Thanks
    YDCtaco likes this.
  5. Mar 8, 2016 at 7:26 AM
    bobrown14
    Bob
    Philadelphia
    Gen 3
    Didn't mean to start any "conversation" just sayin is all.
    They make seat belt male receptacles without a belt attached you can use instead of your actual seat belt. Check ebay....
  6. Mar 8, 2016 at 7:29 AM
    tombiosis
    T
    Ottawa Canada
    yes I have seen those... dealer can do it for free with the software. There is still a light on the dash to warn me the belt is not attached.
    I wonder also if there is a fix for stopping the door open beep so I can listen to tunes while outside the truck with the doors open...?
  7. Mar 8, 2016 at 7:35 AM
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Dealer will turn off the belt chime they did it for me.
  8. Mar 8, 2016 at 8:39 AM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    duct tape?
  9. Mar 8, 2016 at 8:46 AM
    Sbpark
    Sbpark Well-Known Member
    2017 Subaru Outback 2.5i Limited
    You can do this yourself without going to the dealer. Read the owner's manual and it tells you how to do this.
    vuTron and Tacoma2GR like this.
  10. Mar 8, 2016 at 11:23 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    If you put the key to "On" instead of "Acc" it shouldn't beep when the door is open.
    Jeff
  11. Mar 8, 2016 at 11:36 AM
    thepinktaco
    thepinktaco Well-Known Member
    Cody
    Orange, MA
    95 SAS Tacoma, 99 4runner, 16 Tacoma.
    There is a list of customization features in the owners manual. That was you have a list of what you want them to do.
  12. Mar 8, 2016 at 11:44 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    On my '15 they turned off the seatbelt chime, but the door alarm wasn't able to turn off. No option to do it.
  13. Mar 9, 2016 at 9:01 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Just had my first service, and they turned off the seatbelt chime, no questions (or cost). I think the door lock thing, you can do yourself.
    Also, think the blinkers are a dealer thing.
    G.
  14. Mar 9, 2016 at 9:02 AM
    Aw9d
    Aw9d That one guy
    If you want your seat belt chime to go away pull out your gauge cluster and on the back remove the little speaker. Problem solved for all annoying dash beeps.
    iyapysnf and ManBeast like this.
  15. Mar 9, 2016 at 9:40 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    anything in there about increasing the blink rate from 3 to ???
  16. Mar 10, 2016 at 5:42 AM
    tombiosis
    T
    Ottawa Canada
    yes. I read in another thread that the amount of blinks can be changed for when you just lightly press the signal indicator...I'm thinking 4 blinks is the way to go...5 is a bit much, 3 not enough, so 4 it shall be!
    subzero likes this.
  17. Mar 10, 2016 at 6:14 AM
    BlkTaco47
    BlkTaco47 Unhinged
    I meant can we do it, outside of getting the dealer to adjust it?
  18. Mar 10, 2016 at 6:17 AM
    Garyji
    Gary
    As I said before, I'm pretty sure the blinkers are a dealer adjustment.
    G.
  19. Mar 10, 2016 at 7:15 AM
    W00ds3oo
    W00ds3oo Well-Known Member
    Northern California
    16 TRD sport
    Can the speedo be adjusted for bigger tire size? Mine is off a bit, not a big deal but would be good if it was accurate for mileage. I tried to do the adjustment on the head unit, didn't seem to change at all
  20. Mar 10, 2016 at 7:16 AM
    Blazingbluesport
    Blazingbluesport Well-Known Member
    The OC!
    2016 TRD Sport 4x4 double cab.
    Get the Carista free app with the $20 in app purchase and a $17.98 OBD II wifi adapter from Amazon and you can adjust all the settings, chimes, lights you want and reset them if you change your mind
