Computer programmer
Discussion in '1st Gen. Tacomas (1995-2004)' started by jmz82, Apr 25, 2013.
  1. Apr 25, 2013 at 8:02 AM
    jmz82
    jmz82 [OP] Member
    Pittsburgh
    2004 4x4 Access Cab Tacoma
    I bought a ELM327 ODB2 adapter online, mainly to look at diagnostic info i.e check engine light codes.
    The one I got will connect to my computer/phone, can I use it to reprogram the trucks computer? I'm new to this so any info is great, is there any benefit, are there any dangers, what computer program/app should I try, etc.
  2. Apr 25, 2013 at 8:11 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    You'd need a program to interface with the ECU and that varies with the year of your truck and I don't know of one that can do that for the tacoma. From what I've seen, people run a "piggy back" box that has a GUI for the user and translates inputs before sending them to the truck.
    This can be very dangerous if you don't know what you are doing. If you change items like fuel ratio or timing (don't know if you can do that on a taco) you can blow up your motor.
    What are you trying to accomplish?
  3. Apr 25, 2013 at 8:30 AM
    jmz82
    jmz82 [OP] Member
    Pittsburgh
    Thanks for the reply, I guess I wasn't really sure what I wanted to do just wondering what I would be capable of. If I were to start anywhere it would probably be trying to get better MPG since I do a good bit of driving in it. I have an 04 if that makes any difference.
    If my only options have a possibility of being dangerous I'll probably just stick with checking diagnostics.
  4. Apr 25, 2013 at 8:55 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Nope
    Our ECU's aren't reprogrammable. No stock ECU is.
    Only thing you can do is get a piggy back of some sort.
    or stand alone
    You'll see very little improvement without FAI though.
  5. Apr 25, 2013 at 9:07 AM
    Lumpskie
    New Hampshire
    So, with an 04 you will be OBDII. Like Blackdawg said, you won't be able to do much unless your are running forced induction (is that FAI?) I've seen 4 cylinder turbo tacomas make a lot of power and run aftermarket programs to tune fuel, timing, knock control etc.
    If you are set on it, you can check out megasquirt as a fuel management system:
    Here's the hardware:
    http://www.diyautotune.com/catalog/index.php
    V6 Tacoma stuff
    http://www.diyautotune.com/diypnp/apps/n76/usdm-toy-tacoma-9597-5vzfe-mt.html
    4 cylinder megasquirt thread on customtacos
    http://www.customtacos.com/forum/showthread.php?t=71430
    Some threads of people troubleshooting once they run into problems(tach won't work, truck wont idle, loosing crank signal)
    http://www.msextra.com/forums/viewtopic.php?f=101&t=48788
    http://www.msextra.com/forums/viewtopic.php?f=101&t=47665
    http://www.msextra.com/forums/viewtopic.php?f=134&t=47209
    Hope this helps,
    Lumpskie
