Computer Reset
Discussion in '1st Gen. Tacomas (1995-2004)' started by jblair, Apr 6, 2011.
  1. Apr 6, 2011 at 7:56 PM
    jblair
    jblair [OP] Well-Known Member
    Colorado
    99 taco 2.7L I4
    lift, big boy tires, deck plate, no more sway bar, painted stuff
    What does the computer adjust after you reset it? I've been wondering exactly what for a bit now, but my friend just reset his after putting new plus, big tires, and a k&n air filter in. He says it's way different, and what's it doing anyway? It's not just fuel/air is it?
  2. Apr 6, 2011 at 10:22 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I've read that the ECU "learns" your driving habits and style and that gets reset when you remove battery power for more that 20 minute. I'm not certain whether all that is true or not but your right, sometimes resetting makes for a big change. I guess if it does learn, then it will eventually get back to where it was unless you radically change how you drive.
  3. Apr 6, 2011 at 10:26 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    yup.
  4. Apr 7, 2011 at 6:12 AM
    tlh178
    tlh178 Well-Known Member
    terry
    lake huron/sag bay
    2012 4WD reg cab/ 02 SR5 Prerunner/07 FJC 4WD
    i just replaced my ignition coil and wires, should i reset ecu?
  5. Apr 7, 2011 at 5:25 PM
    jblair
    Colorado
    99 taco 2.7L I4
    sure, I can't imagine there are downsides to it.
  6. Apr 7, 2011 at 5:34 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    yah id reset it,i usually reset mine anytime i tinker with any part of the truck that is to do with the electrical. even after cleaning the MAF ill reset the ecu.
  7. Apr 7, 2011 at 5:44 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Doesn't matter the operating info is non volatile memory only thing that will change it is a reflash of the chip.
