Coms Setup & Location
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Freeheelbillie, Dec 28, 2021.
  1. Dec 28, 2021 at 8:09 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I suppose if a guy had a headache rack that was bonded properly, he could mount an antenna on a small rectangular or round metal plate up high in a somewhat central location.. nothing beats the metal skin of the roof for a good ground plane and an omnidirectional radiation pattern though..
    tacovagon likes this.
  2. Dec 28, 2021 at 8:48 AM
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    I personally don't have input on the antenna, so I'd say go with the suggestions from others here. The review for this radio I had seen poked fun at the antenna that midland gives you, but he says it works well enough so I'm just going to send it now with the cheap mag mount it comes with. Interested to see how you do with the upgraded antenna.
  3. Dec 28, 2021 at 8:53 AM
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    He might not be everyone's cup of tea, but I enjoy this guy's perspective and sense of humor.
  4. Dec 28, 2021 at 10:36 AM
    Freeheelbillie
    Freeheelbillie [OP] Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    Yup, I like this guy too. No nonsense and knows his stuff without nerding out.
    RubyTaco21 likes this.
  5. Dec 28, 2021 at 10:47 AM
    Freeheelbillie
    Billie
    Saint Clair, MI
    @Sandman614 had a comment a few comments down the thread https://www.tacomaworld.com/threads/cb-antenna-hood-mounts.477360/#post-14501229 with regard to "fire ring" mounting and nylon washers. I assume this has to do with the bond. :notsure: But with my very limited knowledge, I agree that a centered antenna in the center of the metal ground plane is best. The stock magnetic antenna that comes with the Midland 15w mounted that way would likely get better range than the Ghost style mounted in the ditch light location...but that's a total guess on my part.
    Regardless, it wouldn't be a good fit for the style of wheeling I do in low-hanging branch 2 tracks.
  6. Dec 28, 2021 at 11:59 AM
    Freeheelbillie
    Billie
    Saint Clair, MI
    Another question, do Ghost style antennas need to be mounted in a perfectly vertical orientation to be effective?
    If not, I like the CBI A Pillar Mount. https://cbioffroadfab.com/product/3rd-gen-tacoma-antenna-mount/ It appears to follow the slope of the windshield which would make the antenna less susceptible to limb and brush damage. Or better just to go with a tunable 3' GMRS Firestick?
  7. Dec 28, 2021 at 12:39 PM
    Doc62
    Doc62 Well-Known Member
    Dave
    SE Pennsylvania
    2025 Tacoma TRD Off Road i-FORCE Max, 2019 Sahara
    To best understand the antenna pattern. Picture the antenna surrounded by a donut. As the antenna tilts off the vertical axis, the donut (representing the isotropic antenna pattern) tilts with it. This creates reduced coverage in the horizontal plane.
    MOC221_ and tacovagon like this.
  8. Dec 28, 2021 at 1:07 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    Thanks!
    That's crystal clear and a hard pass on the CBI slanted mount.
    Leaning toward the Ghost Style antenna mounted at the ditch light location.
  9. Dec 28, 2021 at 3:36 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    I am liking the filling in the blank plug next to the ETC button on my rig for sure!
    EatSleepTacos[QUOTED] likes this.
  10. Dec 28, 2021 at 3:53 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If you get it, let us know! I’m only 99% sure it will fit based off of cross referencing different sites that carry it but I haven’t seen anyone on here with it since it’s an obscure part.
  11. Dec 28, 2021 at 3:58 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    Will do! I'm surprised @CaliRaisedLed isn't all over these. They seem to be in demand.
  12. Dec 30, 2021 at 2:40 AM
    scotkw
    scotkw Well-Known Member
    A free State
    '17 DCSB V6 2wd Sr5
    Also torn where to put my gmrs antenna.
    The roof if I can fish wire through the existing shark fin antenna. I wouldn't mind drilling a hole in that plastic.
    Also there are some rubber plugs in the back of the cab. Only issue there is the cable flapping in the wind.
    Also thinking about just bolting a metal plate to those 2 bolt holes at the front of the bed and magnetically mounting it there. I know less ideal, but I'm not drilling or scratching paint.
    Hmmm.
  13. Jan 2, 2022 at 8:11 AM
    Freeheelbillie
    Billie
    Saint Clair, MI
    I meant to ask, for routing the antenna, if I route the cable through the driver's side main electrical penetration will I get interference/static? Or should I mount and route through the passenger side to avoid cable contact with the OEM electrical system?
  14. Jan 2, 2022 at 8:30 AM
    RubyTaco21
    RubyTaco21 Almost Known Member
    NY
    Barca Red SR-5 with some mods.
    I went through the main electrical grommet to the passenger side hood. I zip-tied the antenna cable to the cable running in the same direction and kept all the slack against the firewall inside the cab. No static or interference so far. Oh, and its a Midland 3db antenna for GMRS use.
  15. Jan 2, 2022 at 9:58 AM
    #35
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Where’d you decide to mount the antenna again? I went through a floor grommet and kept it away from anything electrical just in case. Would really suck to go through the effort of routing the cable only to have interference issues. I don’t know how susceptible the cables are to that though.
    Yota_MGM likes this.
  16. Jan 2, 2022 at 10:10 AM
    #36
    Freeheelbillie
    Billie
    Saint Clair, MI
    I'll use this hood mount https://www.victory4x4.com/product/VT3CB-BARE.html and solder a NMO style connection. I just wasn't set on driver or passenger side. If static is an issue keeping it close to the driver's side I'll run through the AC drip port on the passenger side.
  17. Jan 2, 2022 at 10:30 AM
    #37
    MOC221_
    Frank
    Just a friendly reminder to anyone running RF cables/radio chassis harness etc, make sure you're not physically interfering with airbag deployment zones ;)
  18. Jan 2, 2022 at 10:31 AM
    #38
    Freeheelbillie
    Billie
    Saint Clair, MI
    :cheers:
  19. Jan 2, 2022 at 1:46 PM
    #39
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    I saw that Radio and also have been waiting on Midland to release the MXT575, which it sounds like will be a MXT275 with 50W, wideband capability and I think it has the capability to transmit on more channels than the 275. Honestly the 275 is plenty of radio for my use, but it would be nice to have the extra power and channel/wideband capability if things got really hairy and I needed to communicate.
    I'll be interested to see your setup and performance. Antenna mounting is one thing I have some hesitation about. I would like to use the hood hinge mount type antenna brackets but that gives a poor ground plane AFAIK.
  20. Jan 2, 2022 at 2:48 PM
    #40
    Freeheelbillie
    Billie
    Saint Clair, MI
    https://www.youtube.com/channel/UCZeBmj9_UNMoqDHSO7QtzXg has some good no-nonsense reviews for "real world" applications of the MXT275. If I remember correctly he's getting out past 10 miles with an imperfect ground plane and the stock antenna. He gets more distance with the Ghost NMO and 6dB antennas, obviously.
