concealed carry options
Discussion in 'Guns & Hunting' started by biker105nn, Dec 13, 2013.
  1. Dec 13, 2013 at 7:33 PM
    biker105nn
    biker105nn [OP] Active Member
    omaha
    09 tacoma
    1.) 2012 touch screen Panasonic stereo. 2.) Plasti-dip steelies
    was thinking about getting the springfield armory XDs for a concealed carry in a 9m, any thoughts?
  2. Dec 13, 2013 at 7:37 PM
    hmcclung
    hmcclung Well-Known Member
    Heath
    St. Louis
    14 Superwhite S/C DCSB TRD OR
    I have the XDM .40 and love it. It's a bit on the larger side for a CCP, but it's all I carry.
  3. Dec 13, 2013 at 7:44 PM
    MotoTacoma
    MotoTacoma Adrenaline Addict
    Pencilveineeya
    14 Tundra TRD OR, 05 GX470
    tacoma sold 11/13/13 GX470 has 2” Dobinsons IMS w/JBA UCA, Baja Designs S1 ditch lights, more to come!
    honestly i think a lot depends on your height, weight, what you wear on your feet usually, the climate in your area.
    the smaller you are the smaller the pistol you can conceal easily. if you usually wear boots, an ankle rig probably isn't the best option in my opinion. if you typically wear shorts, that obviously also takes out the ankle rig. i am a big fan of the Ruger LCP .380. i have a few handguns but i primarily choose the LCP because it is the lighest, smallest, and most comfortable forme to conceal based on the handguns i own.
    first i would decide where you want to conceal it on your body (inside the pocket, inside the waist, outside the waist, ankle), then decide what handgun to go with by what is most comfortable in that place. lets face it if it isn't comfortable you will be less likely to take it with you, and risk becoming a sheep if the wolf shows up. i have friends that are bigger guys that can conceal bigger guns on their hip wearing a t-shirt with no problem. i need to hoody or coat to do that.
    i also conceal a S&W 442 .38 special revolver.. it is heavier and bulkier than the LCP, less capacity, but more reliable. revolver vs. auto is a whole different debate...
  4. Dec 13, 2013 at 7:47 PM
    JTacoma
    JTacoma Well-Known Member
    Washington
    1995.5 2.7 4X4 5 speed
    Icon Stage 2 Coilovers, Camburg UCAs, 33x12.50x15 Dick Cepek Trail Country EXP on American Racing AR201 15x10 wheels, differential drop, carrier bearing drop, BPV bracket, Leer canopy with Rhino Racks
    Have you looked at the XDS .45 ACP?
  5. Dec 13, 2013 at 7:56 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Hold (and shoot if you can) the XD, the S&W M&P 9, and the Glock 19 Gen 4. All three are great options. From there it's a matter of personal taste.
    The reason I didn't list 99 other good options is that one of these will surely fit you and serve you well and after you have a lot of experience with it and know what you want and don't want you won't need to ask what gun to get, you can just go out and find the ones that fit any certain needs you may find.
    Of the three I actually liked the XD the least in hand. The M&P was the most comfortable and the G19 the second most. I ended up with the G19 after I fired them and cleaned them. I just liked it. I still want an M&P someday. ha
  6. Dec 13, 2013 at 7:59 PM
    tacoftw
    tacoftw 5100s are the same price as spacers, seriously
    McDonough, GA
    05 Double Cab 4x4
    5100s, camburg arms, toytec AAL, 285s on m/t 17x9
    I agree completely with the above post...glock 19 or 26 are good choices, as is the glock 33. M&p is also a great choice and so it xd
  7. Dec 13, 2013 at 8:01 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    yall know he's looking at an XDS and not an XD right?
    only reason i ask is cuz some people get confused and/or dont know that an xds is different from and xd
  8. Dec 13, 2013 at 8:01 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    reading isnt required for replying here
  9. Dec 13, 2013 at 8:04 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    yeah i know :/
  10. Dec 13, 2013 at 9:02 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    S&W, Glock and Springfield are still my recommendations. And I'm a proponent of 9mm as well, which is what the OP is looking for. It's only so long before the 45 gurus try and sway him haha. I rarely shoot my 45 since getting 9s. And 22s haha cheap is cheap, man.
  11. Dec 13, 2013 at 9:50 PM
    biker105nn
    omaha
    09 tacoma
    my dad has the xdm 9m and i loved shooting it. One of the things i liked most was the easy take down and clean, i also like the safety. im 6ft 166,and intend on carrying under the waist band at 3oclock right side. i shot the lcp 38 and it was a little small for my hands, the recoil and rub of my fingers on the trigger guard killed me. I thought about the glocks, but was under the impression they had no safety true not true? also, this would be my first CC, is carrying that hard? I typically wear t-shirs, is that enough?
    thanks for all the advice?
    also, good price? was thinkin about just pickin it up at the local cabelas
  12. Dec 13, 2013 at 9:53 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Glocks have no safety.
    If i were to carry i'd prefer a hammer fired weapon with a decocker (if semi-auto) and carry double action with no safety.
  13. Dec 13, 2013 at 10:04 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    They actually have three safeties.
    Trigger lock, slide lock, and firing pin lock.
    They are deactivated by pulling the trigger.
    XD is the same EXCEPT it has a grip safety that deactivates the slide lock... but like the Glock, a normal grip and trigger pull shuts the safety off.
  14. Dec 14, 2013 at 8:53 AM
    Paleus
    Paleus Well-Known Member
    Arkansas
    '13 DCSB TSS 4x4
    For IWB I would get an M&P Shield in 9mm or an M&P 40c, if you can deal with the bulk. For pocket carry, an LCP.
  15. Dec 14, 2013 at 9:02 AM
    NvrSumR
    NvrSumR Well-Known Member
    Jeff
    Colorado
    If you decide on the XDS make sure you buy one that has the recall fix. I just sent mine in last week and it's a 9-10 week turnaround for repair (from what I've read and heard). I did not have it during the summer, so I don't have experience carrying it with shorts and a t-shirt, but depending on the size of your t-shirt I think it's doable. Carrying it IWB in winter is a piece of cake.
  16. Dec 14, 2013 at 10:00 AM
    biker105nn
    omaha
    09 tacoma
    this may sound really stupid, but whats IWB?
  17. Dec 14, 2013 at 10:03 AM
    TexasCrow
    TexasCrow Member
    In the Waist Band holster.
  18. Dec 14, 2013 at 10:04 AM
    00redlight
    00redlight Active Member
    Arkansas
    12 trdsport
    It means inside waist band. I have an XDS 45 and love it!
  19. Dec 14, 2013 at 10:09 AM
    TexasCrow
    TexasCrow Member
    I carry a full size 1911 .45 because they don't make a .46.
  20. Dec 14, 2013 at 10:15 AM
    JimBeam
    JB
    2015 Tundra
    by that logic...you should be carrying a 500S&W
