Concealed pistol. Thoughts?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thor170, Mar 17, 2020.
  1. Mar 17, 2020 at 12:47 PM
    Thor170
    Thor170 [OP] Member
    Jeff
    San Diego Native living in Alabamski
    2019 Blk DCSB 4X4 TRD Sport
    Eibach 3" Lift System (Stage 1) OME Dakar Medium Duty Leaf Pack CB Drop SCS F5 / Black / 16x8 3.5"BS -25mm BFG KO2 285/75/16 TacomaBeast Tail Lights (Black) CBI Front Skid Plate Meso Customs LED Map Lights Meso Customs LED Dome Lights TRD Pro-faux Grill Grill Garnish Raptor Lights Amp Research Bed Extender Black Badging Black Tail lettering Glove Box OCD Organizer Center Console OCD organizer Amber Lamin-X Fogs Husky Liners X-act All Weather Floor Mats (Front / Rear) Meso Customs Smoked Indicators Dashtop Multi-Mount / Taco Garage Prinsu CabRack CBI T3 Front Bumper / Steel / Low Center Bar TacomaBeast Headlights (Black) Tint
    My apologies if this has already been done before. Since I’ve been stuck at home, I’ve been busy tinkering in the garage. I was trying to figure out a way to conceal a pistol in my truck. I think I figured it out since I have plenty of usable space in the console to make something.
    So I tested out the space using my .45 and 9mm as templates.
    4A4730EA-1A43-444C-BF6B-106DD11577A5.jpg 928A1D6E-A24A-4A7B-A9CB-1B9D2104F458.jpg
    And cut out a piece of 1/2 whiteboard to the exact dimensions of my console. After that I found the exact same felt pattern and applied it using plenty of spray adhesive.
    FD48F068-A3CF-496F-A76D-E1889AEDBD36.jpg DAE4412D-CBC8-4F35-A45B-C17E8A9A29BF.jpg
    Then I added some foam so that the cover wasn’t resting directly on my pistols. These allowed it to sit perfectly flush when inside.
    Wallah!! What you can’t see under the faux base is my 9mm and spare magazine. I had to remove one of the foam inserts in order to stuff my spare magazine, but it works. There’s a tiny screw that’s inserted in the corner (you can’t see it). This is what I pull up on in order to remove the cover.
    Gotta add a picture of the ol’ girl
  2. Mar 17, 2020 at 12:50 PM
    Tttacodan
    Tttacodan Well-Known Member
    Dan
    Nice, I like it. Good spot for your backup.
    4x4cajun and Thuguon2.7 like this.
  3. Mar 17, 2020 at 12:51 PM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    Interesting. How do you remove it quickly?
    Thuguon2.7 likes this.
  4. Mar 17, 2020 at 12:51 PM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    Why do you need a place to conceal inside your vehicle?
    Why hide a spare mag?
    I like what you did. Good job!
  5. Mar 17, 2020 at 12:53 PM
    Thor170
    Thor170 [OP] Member
    Jeff
    If you look at the 5th picture, you’ll see a small screw. I pull up on it and the cover slides right out. Because of the screw’s location, it’s not easily detectable and doesn’t elude to suspicion for those not inquiring.
  6. Mar 17, 2020 at 12:55 PM
    Thor170
    Thor170 [OP] Member
    Jeff
    Great question. There’s no purpose for the spare mag. I just want everything together, but my purpose was mainly for road trips and to keep out of sight from the kiddos.
  7. Mar 17, 2020 at 12:56 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Nice and clean job. My preference is on my person, but everyone is entitled to and has their own preference.
    b_r_o, Naveronski, 4x4cajun and 10 others like this.
  8. Mar 17, 2020 at 12:57 PM
    dangeroso
    Jon
    Dallas, TX
    I see it now. It was cut off in the last pic. Nice design and execution.
    Are the foam pieces positioned to keep it from sliding around?
  9. Mar 17, 2020 at 12:58 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  10. Mar 17, 2020 at 12:59 PM
    Thor170
    Thor170 [OP] Member
    Jeff
    I positioned them so nothing would slosh around and to keep the platform level. Worked out surprisingly.
    dangeroso[QUOTED] likes this.
  11. Mar 17, 2020 at 1:02 PM
    Thor170
    Thor170 [OP] Member
    Jeff
    Not going to work today, yard work is done and I’m bored. Why not!
  12. Mar 17, 2020 at 1:05 PM
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    Great work, just be careful. I also have a Smith M&P, love it!
    Hidden compartments are not illegal everywhere and/or with every use. Just be aware of varying laws about what can be in them and how that can change state to state, when driving. I am no lawyer, but if your have you handgun in there for a legal purpose in Ohio (for example, was easy to find) that should be no problem, but if something is illegal about you having it, having it loaded, or lying to police, it could catch another charge.
    Ohio just as an example: http://codes.ohio.gov/orc/2923.241v1
    Thor170[OP] likes this.
  13. Mar 17, 2020 at 1:11 PM
    Thor170
    Thor170 [OP] Member
    Jeff
    It’s not loaded (as in magazine is no longer inserted) and I definitely would let LE know. You offer some great perspective I’ll take when traveling. Like you, I love my M&Ps!
    VirusCage[QUOTED] likes this.
  14. Mar 17, 2020 at 1:12 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Looks good as a deep concealment option.
    BlackGT99 likes this.
  15. Mar 17, 2020 at 1:56 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Here's my solution. Custom cam lock to restrict any access to the center console and a magnet mount.
  16. Mar 17, 2020 at 2:03 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    I like your taste in hand guns. :)
  17. Mar 17, 2020 at 2:09 PM
    Thor170
    Thor170 [OP] Member
    Jeff
    Nice! I’ve shot my fair share of pistols and it’s definitely the softest shooting 9mm I’ve ever shot. Probably my favorite too.
  18. Mar 17, 2020 at 2:11 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    So why have it in reach in the first place if it’s not loaded ? Maybe because I carry with one in the pipe I don’t understand people that leave their fire arm unloaded but within reach. The last thing I want to have to worry about is being so nervous during a DGU that I have to put a magazine in and the rack the gun.
  19. Mar 17, 2020 at 2:15 PM
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    -Bilstein 5100s @1.75" -16x8 SCS Ray10s with 305/70R16 General Grabber AT -CMC -URD Short Throw Shifter -Bed stiffeners -Bed mat -Aftermarket head unit -AFE Rebel exhaust -ME-SO Customs dome/map lights -Window tint with eyebrow -OEM LED 2015 tail lights -GTR Lighting headlight bulbs -Husky floor liners -Camper shell -Sumo Springs -Air intake -Aftermarket Volkswagen key fob -Aftermarket A/C knobs -Aftermarket LED license plate lights -Console organizer -JBA High Caster UCAs
    Just make sure if you are going on a road trip with it concealed that it's legal to have it concealed in the areas you'll be traveling through, even if it's legal on your permit. Seems a bit unnecessary to me, or you could just get a center console vault or something and it would be locked too.
    k8md, Kwikvette and velogeek like this.
  20. Mar 17, 2020 at 2:18 PM
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    My weapon of choice as well
