Concentrated coolant
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chris515, Jan 26, 2025.
  1. Jan 26, 2025 at 8:26 PM
    Chris515
    Chris515 [OP] New Member
    Christian
    2.7 tacoma
    I accidentally put concentrated coolant on my 2008 4cyl tacoma. It had only water and I only drained the radiator. Should I drain it again and mix it or the water left in the engine is enough to dilute it?
  2. Jan 26, 2025 at 8:42 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Total capacity is about 2 gallons so if you only added a gallon of concentrate and the rest was water you should be good.
  3. Jan 26, 2025 at 8:45 PM
    Chris515
    Christian
    2.7 tacoma
    Well almost a full gallon, it didnt take it completly, it has like 1/8 left on the gallon
  4. Jan 26, 2025 at 8:46 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Your fine, that puts you very close to the recommended 50/50 mix.
    Chris515[QUOTED][OP] likes this.
  5. Jan 27, 2025 at 6:13 AM
    eherlihy
    eherlihy 2009 Access Cab TRD Off Road
    Florida or Massachusetts
    2009 TRD Offroad Access Cab in Silver Streak Mica
    o_OI didn't know that Toyota Pink or its equivalents were available 'concentraded'... I always thought that they were only available retail as a 50:50 mix with distilled water.
  6. Jan 27, 2025 at 6:17 AM
    Chris515
    Christian
    2.7 tacoma
    The is the concentrated that is red that you have to mix with distilled water and the pink that is already 50/50
  7. Jan 27, 2025 at 6:52 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Harbor freight sells coolant testing tools you can buy cheaply to see what your protection level is. In general if you are in a hot region then you want 50/50 mix but if you are somewhere frigid cold you can go to like 70% antifreeze concentration for freeze protection.
    Williston likes this.
  8. Jan 27, 2025 at 7:02 AM
    545 Well-Known Member
    2015 Access Cab
    Just about any auto parts store will sell them too, the useful range is pretty wide, but 50/50 is good for the lower 48, 60% coolant is better for Alaska, parts of Canada
  9. Jan 27, 2025 at 7:06 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Toyota Red (Long Life) and Toyota Pink (Super Long Life) are 2 different coolants, the Red was used up to 04 and the Pink is used 05+.
    Probably won't hurt anything but Pink is the original and recommended coolant.
    eherlihy likes this.
