Concern over 5100/Eibach setup...
Discussion in '1st Gen. Tacomas (1995-2004)' started by cu1n81, Feb 25, 2014.
  1. Mar 3, 2014 at 11:09 AM
    Taylor
    Taylor Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Glad to hear it, man!
  2. Mar 3, 2014 at 12:13 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Just to clarify for you:
    for 1st gen tacomas- MUST be on the lowest setting for 3+" lift
    for 2nd gen tacomas-they go to the 2nd clip for 3'' of lift as they weight more.
  3. Mar 4, 2014 at 7:25 AM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    That article you posted is referring to 2nd gens. 1st gens are meant for lowest setting only.
    Here's a question I have that could help you out...
    Does anyone know if he could add 1/4" or 1/2" top plate spacers to achieve the height he's wanting?
  4. Mar 4, 2014 at 8:26 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No. Shouldn't need too until he has lots of weight up front. As in plate bumper skids and winch.
  5. Mar 4, 2014 at 8:37 AM
    airmax233
    airmax233 Always ready for the next adventure
    Southern California
    12 PreRunnerTrd sport R.I.P 21 Tacoma Off road 4x4
    2.5 Kings w/resi Adj. Total Chaos Upper control arms. IG: Cement_runner23
    so this applies for the 885x as well right? use the lowest setting on 5100
  6. Mar 4, 2014 at 8:38 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    For 2nd gens yes. 885s and 886s should be at lowest setting on 5100s
  7. Mar 4, 2014 at 9:19 AM
    Mainmoe02
    Moe
    Austin, Texas
    I understand that. But let's say he did have 200+ pounds of weight up front and because of the added weight he went from 3.25" lift up front to 2.75" of lift. Now, to get back to 3.25" of lift Is it safer/ better to add a 1/4" top plate spacer to maintain the 3.25" lift the Eibachs initially gave? Or would that have the same negative effect as moving the C clip to the middle setting?
    I'm trying to figure out the difference between a 1/4" or 1/2" top plate spacer compared to setting the C clip on the 2nd setting on Bilsteins when paired with EIBACH coils. I can see that the coil compression is one difference because when adjusting the C clip it compresses the coil and a top plate spacer does not. But my main question is which option is worse on suspension parts like ball joints, tie rod ends, etc...?
  8. Mar 4, 2014 at 9:47 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    id do a 1/4'' top spacer.
    Preloading the coil more will just merit a shitty ride haha
  9. Mar 4, 2014 at 9:51 AM
    airmax233
    Southern California
    Thanks :thumbsup:
    And going this route will require at least an AAL? or will it sit level w/out
  10. Mar 4, 2014 at 10:10 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    you'll want an AAL
  11. Mar 4, 2014 at 10:19 AM
    airmax233
    Southern California
    gotcha or else I will get the bro lean? And stock shocks will work with the AAL for now right?
  12. Mar 4, 2014 at 10:36 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea you would.
    and not sure on 2nd gens..probably some rear 5100s be better
