Concerned about upcoming alignment after billy install...what are your thoughts??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dakota 08, May 19, 2011.
  1. May 19, 2011 at 7:29 AM
    Dakota 08
    Dakota 08 [OP] Well-Known Member
    Portland
    08 Dbl Cab
    Situation: Just completed a install of billy 5100s all the way around with the front set at 1.75" and a 1.5" AAL in the rear. My alignment is scheduled for tomorrow afternoon.
    Concern: Since the install, I've noticed that there is only about a finger-widths worth of clearance between the upper inside edge of the tire's sidewall to the knuckle that sticks out from the front a-arms (I think that's there name? The main piece connecting the uca to the wheel hub.)
    Question: Is there enough room to align my front end? It almost seems I will need some spidertrax wheel spacers to obtain enough clearance to get it done? Is this the case??
    What are your thoughts?? If I do need spacers, are they still on backorder? If not, any good deals for ordering them?
  2. May 19, 2011 at 7:34 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    you should be fine but id invest in new UCA's
  3. May 19, 2011 at 7:38 AM
    CaptainFun
    CaptainFun That Guy
    Washington DC
    2005 Double Cab 4x4
    What size tires are you running and are you on stock wheels or aftermarket?
    I think you should be fine. I have limited clearance in relation to the UCA with my stock rims and tires.
  4. May 19, 2011 at 7:46 AM
    Dakota 08
    Portland
    08 Dbl Cab
    Will be running 265/75/16... went this route because i thought i had done my research to make sure everything would fit with an alignment.
  5. May 19, 2011 at 7:48 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You should be fine. The distance between the tire edge and the UCA wont change. Ive seen clearance less than an 1/8" and its been fine.
  6. May 19, 2011 at 7:52 AM
    CaptainFun
    CaptainFun That Guy
    Washington DC
    2005 Double Cab 4x4
    Yes that size should fit fine on the stock rims even on stock suspension. Issues arise with that size when aftermarket rims are used and they have the wrong backspacing.
    A good reputable shop should have no issues getting you alignment into factory specs. It probably won't be exactly the same as stock because the suspension is modified but you should be good to go.
  7. May 19, 2011 at 7:57 AM
    Dakota 08
    Portland
    08 Dbl Cab
    Thanks for the advice. I'm having the alignment done at Les Schwab. Has everyone had a good experience with them??
    Also, does anybody have an example of what the specs should be considering the front end does have the billys set at 1.75"??:confused:
  8. May 19, 2011 at 8:02 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    You wont have a problem at 1.75". Mine is set at 2.5" and its not totally within spec but very close.
