Concerned with highway speed drivability.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoSan2.0, Jul 10, 2019.
  1. Jul 10, 2019 at 4:33 PM
    TacoSan2.0
    TacoSan2.0 [OP] I like handbrakes
    Brandon
    Los Angeles, California
    2016 White TRD Sport
    Lights and Stickers
    First of all, I should state that I don't drive a lot of highway miles with my truck much anymore. I live and work in LA driving about 90% city & 10% highway
    Recently went on a couple of hundred-mile long road trip and was not super happy with how the truck drove at highway speeds (75mph+) At those speeds the steering felt really light and at times I had very little confidence driving the truck over 80mph. Specifically going downhill and turns while on the highway. It was not a windy day or anything, just to clarify. I'm usually a very confident driver having driven all sorts of vehicles in different types of environments. I've owned both full-sized and mid-sized trucks before and never had this issue.
    The truck has completely stock suspension with 30k miles on the truck itself. The only modification to the drivetrain is 265/70/17 tires over the stock 265/65/17 size.
    So my question is, has anyone else experienced this with there truck? Do I need to take it into the dealership for this or are there any front suspension recalls for these trucks? I feel that I shouldn't have these kinds of issues with such a low miles vehicle.
    Any and all help would be appreciated!
    GQ7227 likes this.
  2. Jul 10, 2019 at 4:35 PM
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    What were tire pressures set at?
  3. Jul 10, 2019 at 4:35 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    If it feeling like it was wandering you might need an alignment.
    HacksawMark and Big tall dave like this.
  4. Jul 10, 2019 at 4:36 PM
    pkang0915
    pkang0915 Well-Known Member
    Bay Area, California
    2017 Tacoma DCLB OR (first time Taco owner)
    TOYTEC 2.5 kit, SPC UCA, N-fab side steps, TRD pro grille, FN FX PRO Wheels, BFG KO2S (265/70/17 C Rated), TRD Skid plate, Tyger Tonnue Cover, OVtune, Borla S type exhaust
    When is the last time you had an alignment done?
  5. Jul 10, 2019 at 4:46 PM
    TacoSan2.0
    Brandon
    Lights and Stickers
    Getting an alignment was going to be my next move if no one else could relate to this issue.
    Tires were at 34psi all way around
  6. Jul 10, 2019 at 4:51 PM
    Jleeb
    Jleeb Well-Known Member
    Vermont
    2017 DCLB OR SUPERwhite.
    Stock
    I drive on the highway all the time. Other than having absolute crap MPG, my truck drives great. I usually go 65-70. FWIW, I keep my tires at 37psi.
    GQ7227 and Big tall dave like this.
  7. Jul 10, 2019 at 5:02 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    You must have the California edition... it’s not designed to go over 20mph on the freeway.
  8. Jul 10, 2019 at 5:02 PM
    tacomarin
    tacomarin ig: @travelswithchubbs
    Bay Area
    2018 DCLB TRD OR
    Prinsu Cab and Top Rack VO Drifter LED Interior, License Plate, and Reverse Lights Huskyliner Weather Beater floor mats Salex Center Console Organizers 35% Front/15% Rear Tint Debadged and De-stickered Anytime Front and Rear Cameras Brute force front bumper BAMF HC Dual swing out 285/75r17 BFG KO2 Front: ADS 2.5, EXT, RR, Clickers Rear: OME Dakar HD, ADS 2.5, EXT, RR, Clickers Stainless steel brake lines (+4 in rear) Wheeler's Offroad Superbumps Front and Rear Wheeler's Offroad U-bolt flip ECGS CV Axle Bushing SCS Stealth 6 17x8.5 wheels, matte dark bronze
    I would definitely have the alignment checked. If your caster is in spec, have them push it forward more.
    toku58 likes this.
  9. Jul 10, 2019 at 5:05 PM
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    I drive state highways daily, 60 to 65 and sometimes up to 75 :bikewheelie2:....
    I have driven many times on Interstates with speeds over 75 to 80 and truck is fine. Definitely check tires, rotate, and or alignment. It is not a Audi q5 at cruising speeds, but does not feel uncomfortable or unsafe.
  10. Jul 10, 2019 at 5:07 PM
    Fearthisbeard
    Fearthisbeard Well-Known Member
    Josh
    Gilbert AZ
    Taco
    I just drove from SD to Phoenix with cruise control set at 85, mine felt fine
    Bus007G likes this.
  11. Jul 10, 2019 at 5:09 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The Taco feels in the zone at 80 to 85. The MPGs don't like it, but the truck just eats up the miles at that speed.
  12. Jul 10, 2019 at 5:12 PM
    Techsan
    Techsan Well-Known Member
    South Texas
    2017 BBPDC
    I commute 40mi (round trip) daily on 75mph Texas highways. Set the cruise at ~78-79. I have no issues whatsoever.
    GreyBaldTaco likes this.
  13. Jul 10, 2019 at 5:18 PM
    pkang0915
    I drive about 60% hey and have a 2.5 inch lift with 265/70/17 (bfg ko2s C rated) tires and doing 80mpg is as stable as can be. I'm at 33 psi. More than likely it's your alignment.
  14. Jul 10, 2019 at 6:10 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    As others said, get alignment done, specifically caster, ask them to set it to the max of the allowed range, (probably about 3 to 3.5).
  15. Jul 10, 2019 at 6:21 PM
    Gamma11
    Gamma11 ((‘)) yea, i like the taste
    Andrew
    Northeast
    2024 DCLB OR Bronze Oxide, 2022 T4R ORP Super White
    I drove from Maine to Illinois this week, heading back tomorrow... No such issues to speak of, tires 38-39 psi averaging 22-23mpg if I don't use cruise control averaging between 77 and 80mph
  16. Jul 10, 2019 at 6:28 PM
    RocketTaco
    RocketTaco Well-Known Member
    2019 SR Access Cab V6
    This made me LOL, I'd wager it eats up exactly 80 to 85 miles every hour.
    Gamma11, Jleeb, HelloMyNameIs and 5 others like this.
  17. Jul 10, 2019 at 6:28 PM
    Bryanccfshr
    Bryanccfshr Well-Known Member
    2018 Trd OR , 2018 TRD Pro 4Runner
    I don’t have any issues and I drive several hundred miles a month at 80-85.
    Now winds and road crown can have an affect.
    OnHartung'sRoad likes this.
  18. Jul 10, 2019 at 6:31 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :rofl:
    I like the cut of your jib.
    :cheers:
    TeecoTaco likes this.
  19. Jul 10, 2019 at 6:38 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Portal axles and the wheel bearing fun, no doubt!
  20. Jul 10, 2019 at 6:41 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :rofl::rofl:
    I assumed that you knew.
    They have portal axles / gear reduction hubs. So, lots of driveline lash.
    Also with those axles, they tend to chew up wheel bearings.
