Concerns about purchasing 09 TRD Off Road
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JesseRay, Aug 3, 2011.
  1. Aug 3, 2011 at 9:32 AM
    JesseRay
    JesseRay [OP] Member
    Houston, TX
    09 PreRunner TRD Off-Road
    Hey guys, could use some advice. I've been reading these forums for the past few weeks, tons useful information here. I finally took the plunge and bought a 2009 TRD Off Road edition with 61,000 miles this past weekend.
    Against my better judgement I bought the truck without test driving it because it was "in service" and they didn't have the key. I asked multiple times what the vehicle was in service for and the salesman assured me it was just normal maintenance.. new tires, brakes, battery, etc. The truck itself looked pristine. Engine bay was flawless, no rust underneath, nice interior. This was at a very reputable Toyota dealership here in Houston and the car was certified. SO! I went for it. They called me on Monday saying the car was ready to be picked up. I swing by and get it, as soon as I pull out and get to 35mph I notice a really bad whining noise coming from the rear end. At first I thought it was just the bigger tires that I'm not used to. It literally sounded like a freight train though.
    I call the used car manager and explained to him the problem. He does a little research and finds out there was a service ticket put in for the vehicle 5 days before I purchased it for "rear end noise". I was NEVER told about this before I bought it. They showed me the maintenance checklist they did on the truck and it was all routine stuff. The ticket for the noise was never closed out and the car was sold to me. I'm not to sure I would have bought the car knowing that repair had to be done on it.
    I drove around with the head mechanic yesterday and he said it sounds like a pinion bearing in the rear differential. He said a minor chip in the bearing can cause it to whine very loud like it. He played it down like it wasn't a big deal. Which maybe it isn't? That's the main reason I'm here asking you all.
    Should I walk away from the whole deal? Or do you think the truck will still be a reliable investment after the differential repair? Do you think that put any strain on the transmission and engine that might pop up over time? It seems like the previous owner was hauling some major stuff if they had to replace the brakes, pinion bearing, pulley belt all after 2 years. It's a gorgeous truck and I got a good price on it. I hate to give it up, I just want to feel at ease with my investment. I looked at almost 20 other Houston dealerships and didn't find a truck that even came close to it. Any advice is much appreciated.
  2. Aug 3, 2011 at 9:38 AM
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    I agree with your mechanic that it could be the pinion bearing. However, it could also be that the backlash is not within spec for the ring and it has not been shimmed correctly if the third member was ever rebuilt, or re-geared. You made the right investment, but got a lemon. Your choices are to have the third member rebuilt (by the dealership and make them warranty that shit), or make them give you another Tacoma at the same price. Oh and before I forget, as far as your mechanic says "it's not a big deal" it kind of is. It might take some time, but you could grenade the third member, or just bust a bunch of teeth on the ring and pinion. Mine hums because of a re-gearing gone horribly wrong, but I'm driving/offroading it until I buy new gears, and a mater rebuild kit. Hope this helps bro.
  3. Aug 3, 2011 at 9:40 AM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    since you bought it from the dealership, you still have a warranty... have them fix it
  4. Aug 3, 2011 at 9:42 AM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    09 Access Cab V6 4X4
    Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Goodyear Wrangler Duratracs, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings,... oh and the hot wife mod.
    A good dealership/sales man would never sell you a car without driving it first ... to much work to have someone get in a car they already did all the paperwork for and say "I don't like it"
    I would walk away from the deal .. I'm a huge "ease of mind" guy and that would always be on my mind every time I drove the truck.
    Also, it's possible this is just a random problem but I can't help thinking how the truck was treated or what is was put through to have a rear diff issue in two years. What else is prematurely worn out? Heavy off roading? Towing? Hauling to much? Possibilities are endless..
    I would also give the dealership hell and ask to talk to the actual manager, demand a similar TRD OR for the same price. Get some free add-ons for your wasted time..
  5. Aug 3, 2011 at 9:57 AM
    JesseRay
    Houston, TX
    Thanks for the replies guys. I did talk to the used car manager yesterday and told him I wanted an extended warranty on the truck to put my mind at ease. He said he couldn't do that. So much for trying to please the customer. I'm going to talk to the general manager today instead of the used car manager and see what he can do for me.
    I feel like what they did was misleading and probably illegal.
  6. Aug 3, 2011 at 9:58 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Why won't they fix it?
  7. Aug 3, 2011 at 10:03 AM
    Underdog777
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    Screw the GM, and the used car manager. Go to strait to the Fleet Manager. Hauling heavy loads will wear out the rear end faster than off roading, but both are still stressful. The Toyota third members are STOUT and are designed after the Ford 9'' for the exception that Toyota has an extra brace on top of the member. If you want peace of mind have them pull the third member and make them rebuild it. They legally have to warranty that despite how many times or ways they say they can't. There is no telling when you'll completely bust a tooth. It could be at 5mph or 50mph. I take the risk everyday, but I rebuilt mine myself so I can't blame anyone but me.
  8. Aug 3, 2011 at 10:22 AM
    JesseRay
    Houston, TX
    They are repairing it right now under warranty. It should be done in a few days. They gave me the option to test drive it after it's fixed and either walk away from it or keep it.
  9. Aug 3, 2011 at 10:23 AM
    Underdog777
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    :thumbsup: That's what I'm talking about!
  10. Aug 3, 2011 at 10:24 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    AWESOME!
  11. Aug 3, 2011 at 10:26 AM
    Underdog777
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    x2
  12. Aug 3, 2011 at 10:33 AM
    Icepuck72
    Icepuck72 Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    That's awesome....but just worry about other stuff on it. I'd still seriously think about walking away from it. You just never know.
  13. Aug 3, 2011 at 10:36 AM
    Fightnfire
    Marysville, WA
    Agreed, I'm walking.
    To much work on an '09 and with the dealership lying to me about it... no way I'm buying it.
    The only thing that would change my mind is an extended warranty that they provide at no cost. Even with that I'm iffy ..
  14. Aug 3, 2011 at 10:46 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Umm... Do you have two screen names?
  15. Aug 3, 2011 at 10:54 AM
    Fightnfire
    Marysville, WA
    Uhh no, I was agreeing with Icepuck above me and didn't quote because I was the next post.
    As for the "I" and "Me" just putting myself in his shoes, I wouldn't buy it.
  16. Aug 3, 2011 at 11:06 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Ha, that confused me also... and it's been done here before.
    I'd walk away if I found out the dealership was shady and hiding things about a truck they sold me. That dealership sounds crooked, I would find another place to buy your Tacoma.
  17. Aug 3, 2011 at 11:10 AM
    Fightnfire
    Marysville, WA
    I try to put myself in the other persons shoes so I answer as what I would do. etc.
  18. Aug 3, 2011 at 11:12 AM
    Pugga
    Massachusetts
    F-150 Mod
    No worries, I'm easily confused at times :D
  19. Aug 3, 2011 at 11:13 AM
    babytruck
    NorCal
    This past weekend was the end of the month and they probably were desperate for sales. If I were you, I'd take the way they hid the work from you as a hint on how that dealership conducts itself. At this point trust is violated and if you are feeling funny about it, deep inside there's a reason why. Trust yourself and your intuition.
  20. Aug 3, 2011 at 11:14 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    but he said "i would walk" not, "i'm walking on the deal"
    OP i would make them offer a warranty
