Concerns about the Timeing Belt
Discussion in '1st Gen. Tacomas (1995-2004)' started by Boudreaux, Oct 31, 2010.
  1. Oct 31, 2010 at 11:08 AM
    Boudreaux
    Boudreaux [OP] Well-Known Member
    Church Point, LA
    2017 Tacoma Limited (Barcelona Red)
    I have a 2000 PreRunner (V6) purchased in March 2000. Although the truck has been in service 10 years 7 months, the mileage is only 22,000 miles (not a mistake).
    My concern is the future reliablity of this aging Timeing belt. I was told it's a rubber belt and not a Timeing chain. Although there's very little use on te engine, there is the aging process of the rubber belt.
    Change it or not....??? Any idea from you "experienced" wrenches out there......???
  2. Oct 31, 2010 at 11:21 AM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    California
    2002 Tacoma TRD SR5, 3.4, 5spd
    -Bilstein 5100 Series shocks on all 4 corners -Rancho HD lift coils -1/4" Toytec driverside top plate spacer -Toytec 1" diff drop -Wheelers 1.5" AAL's -Toytec 1" lift shackles -Revtek extended length BPV bracket -285/75/16 BFG KO T/A's -Pro Comp rims -ET Conical tyle lug nuts -Spidertrax 1.5" wheel Spacers -CV Boot slide mod -TRD skid plate -Magnaflow 14" round muffler -Shortened tailpipe hidden behind framerail -Toyota bug deflector -Weathertech floormats -Black leather seat covers -Valentine 1 Radar Detector
    That's pretty awesome to have such low mileage for that year.
    I wouldn't worry about the belt too much, although I think I might change it a little earlier than what is recommended for extra piece of mind. Maybe around 75-80K.
  3. Oct 31, 2010 at 4:35 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    rec'd is every 5 yrs. Just rule of thumb. rubber rots and decays mostly from age. Not really from use.
  4. Oct 31, 2010 at 4:48 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Rob
    Pacific Northwest
    2005 4x4 DC TRD Off Road
    11 Color Matched Grille, Pro comp 7089s, 265/70/17 Wrangler Duratracs, Black Running Boards, Tinted Windows, Bed mat, Weathertech Floorliners
    I would definitely have it inspected.
    It would make a difference if the truck has been garaged its entire life or stayed outside. Outside would obviously be harder on it.
    If you do decide to change it, you might as well do the water pump at the same time.
  5. Oct 31, 2010 at 5:24 PM
    Boudreaux
    Church Point, LA
    I'm puzzeled here. Why the water pump with such low mileage....??? Is the water pump designed with plastic parts as well....???
    I'm not trying to be cynical, I just don't know....!!!
  6. Oct 31, 2010 at 5:37 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Breaks, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    No worries, the motor is fine if the belt breaks, you wont hurt a thing,(you're just stranded) the reason to change the water pump at that time is because if you are paying someone to do it for you, getting the belt off to change the pump is the first step, once belt is off it's 10 minutes and pump is off, trust me i've done it twice. The pump is around $120.00 and the belt is $45 or $50, so if you spend the labor to do the belt might as well do the pump as well. Good luck
  7. Oct 31, 2010 at 5:42 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    When it comes to timing belts better safe than sorry. At least it's not an interference motor. As stated before, if it breaks you're just stranded. So, if you're worried about it then just change it out. What's the worst that could happen, peace of mind?:D
  8. Oct 31, 2010 at 6:14 PM
    Boudreaux
    Church Point, LA
    SO.....you guys are saying that the 2000 Taco V6 is not like other engines.
    In that if the timing belt should break, there's no chance of the pistons crashing into the valves and the engine would self-distruct....???
  9. Oct 31, 2010 at 6:22 PM
    giscott
    giscott Well-Known Member
    Scott
    Austin
    2003 TRD SR5 PreRunner DC Revtek 3" Lift,
    Correct. No Engine damage should the belt break.
  10. Oct 31, 2010 at 6:27 PM
    Boudreaux
    Church Point, LA
    OK....just for my peace of mind.
    We all know that I'm refering to the timing belt incased behind a cover on te lower front of the engine, and not the serpentine beld on te outside of the engine....right.....????
  11. Oct 31, 2010 at 6:39 PM
    Boudreaux
    Church Point, LA
    I ran a googgle on the Interference Engine, and I now see the difference in some old engine designs and the taco V6.
    Is there a name for the engine design of the 2000 Taco V6....??
  12. Oct 31, 2010 at 6:55 PM
    Boudreaux
    Church Point, LA
    Thanks to your information I now know that there are "Free Running Engines", and "Interferrence Engines".
    And you're saying the Taco engine is "Free Running".
    I think I now have a grasp on the situation....thanks.....!!!!
  13. Oct 31, 2010 at 7:17 PM
    Boudreaux
    Church Point, LA
    Hello Nelson,
    Let me say that I really appreciate your time and info.
    I googled the Gates Timing belt site and found that both my 2000 Taco V6 & my 2000 Avalon V6 have an interferrence engine. At least, that is what Gates is saying.
    http://www.gates.com/downloads/download_common.cfm?file=428-1466_web.pdf&folder=brochure
    Thanks to all. I will call my Toyota Dealer in the morning. As mentioned best to be safe....!!!
  14. Oct 31, 2010 at 7:20 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    I just did mine, and there was a sticker on the cover that it was done at 54,000 ish.I have 141,000 on it now..The old one looked just fine, but Its better to be safe then sorry.
  15. Nov 1, 2010 at 3:44 PM
    NelsonTacoma
    Tucson, AZ
    From what I've read on this site, the 3.4 is not an interference engine.
    Here's a link I found on another toyota site.
    http://www.yotatech.com/f2/3-4-interference-motor-10826/
    But as you do agree, better safe than sorry.
    Let us know what the dealer says too.
  16. Nov 1, 2010 at 4:12 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    Don't forget about the T-stat as well ;)
  17. Nov 2, 2010 at 1:42 PM
    Boudreaux
    Church Point, LA
    OK....I called my dealer today about the Taco PreRunner V6 (free Running or Interference engine).
    She seemed to know what I was talking about right away, and mentioned that Toyota was know suggesting 60,000 rather than 90,000 (as apposeded to previous years) but wasn't positive about the Interference issue. She said she would call me back.
    She called back within a half hour. My 2000 PreRunner V6 has a Free Running engine and not an Interference engine as suggested by the Gates site. On the other hand, my 2000 Avalon XLS 3.4 V6 has an Interference engine.
    Thanks for your time and info. It gave me direction.
  18. Nov 2, 2010 at 1:55 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Google is your friend ;) The name of the 1995.5-2004 Tacoma V6 engine's is called a 5VZ-FE. Its a bullet proof motor. And it IS non-interferience. :cool:
  19. Nov 2, 2010 at 2:40 PM
    Boudreaux
    Church Point, LA
    Thanks to everyone for the guidance.....!!!
    Any idea what the technical number would be for the 2000 Avalon XLS V6 engine......????
  20. Nov 2, 2010 at 2:59 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    Toyota TRD Pro Grille, Skid Plate, ARE Series II Lid,
    You have time; I took my 03 to the dealer for the something only had 38,000 they started laughing told I don’t do it, too early its mileage not time. They told me when I do it, replace the following parts: they have to be removed anyway.
    1. All the belts
    2. Water pump
    3. Timing belt
    4. Hoses
    5. Thermostat & Fluid (extra step but might as well)
