Condensate drip passenger side 2018
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Olstoneface, May 23, 2018.
  1. May 23, 2018 at 5:21 AM
    Olstoneface
    Olstoneface [OP] New Member
    Bill
    2018 Tacoma
    New Tacoma. I have a condensate drip on passenger side dripping cold water on Wife's foot, when accelerating or on slope... I thought this issue was solved years ago! Anyone else?
  2. May 23, 2018 at 5:23 AM
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    Check that the AC condensate drain is securely connected.
    Garyji likes this.
  3. May 23, 2018 at 5:33 AM
    Olstoneface
    Bill
    2018 Tacoma
    Will do...
  4. May 23, 2018 at 6:45 AM
    RustyTacos
    RustyTacos Well-Known Member
    CJ
    kentucky
    17 MGM TRD Sport 4x4 MT
    A/C drain may be stopped up too, if its connected then you can try and blow compressed air up the hose. If it is stopped up be carefull it can put out alot of water fast when you unclog it.
  5. May 31, 2018 at 9:39 AM
    Olstoneface
    Bill
    2018 Tacoma
    I briefly check the line and took it back to the dealership. They blew out the line cleaned everything up and it still drips. It only happens with outside air and drips only when turning or going uphill. Don't think it's the coil box drain something weird. Still drips and his back at the dealership.
  6. Jun 1, 2018 at 11:05 AM
    Olstoneface
    Bill
    2018 Tacoma
    Service department just called... It appears that the Evaporator Box is cracked, just enough so that when it is "outside air" is engaged, it builds enough pressure (I'm guessing) to leak slowly... Another week to get the part in and the loaner car thing again, but at least they've found the problem!
    doublethebass likes this.
  7. Jun 1, 2018 at 11:06 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I was just to say "Warranty"
