Condensation Drain Problem
Discussion in 'Technical Chat' started by NH03TacomaTRD4x4, Jul 6, 2013.
  1. Jul 6, 2013 at 5:23 AM
    NH03TacomaTRD4x4
    NH03TacomaTRD4x4 [OP] Well-Known Member
    Doug
    New Hampshire
    03 TRD Double Cab 4x4 Tacoma
    Hi All
    I have a problem where my drain is no longer draining. when I go around corners left or right the water pours out from under the dash on either side of the console. I blew my air line up in the drain which temporarily fixed the problem but not for long. Because of this I assumed there is some kind of filter that is clogged. anyone else seen this problem. want to fix myself if I can. don't have cash to bring to dealership.
    any help would be appreciated. I took the glove box out but don't see ant clear way of getting into the unit.
    please help
  2. Jul 7, 2013 at 4:23 AM
    NH03TacomaTRD4x4
    Doug
    New Hampshire
    Wow I can't believe no one else has had this issue. I'm thinking that is probably not a good thing for me.
  3. Jul 7, 2013 at 4:28 AM
    hogeyphenogey
    hogeyphenogey Rotted frame = New Truck!
    Dave
    Chicopee, MA
    2015 TRD Off Road Crew Cab
    new truck... No mods yet!
    You may have some mold or something else that is still in your evap pan. Blowing air up there may have dislodged it then it went back into the hose. I cannot think of anything else that can cause water from the evap into the passenger side floor besides a blockage of the drain.
  4. Jul 7, 2013 at 4:44 AM
    NH03TacomaTRD4x4
    Doug
    New Hampshire
    I agree hogeyphenogey question is how do I get to where the drain is and is there some chemical that can be circulated through the system to prevent it from happening in the future.
    thank you for replying
  5. Jul 7, 2013 at 7:28 AM
    snoope
    snoope Well-Known Member
    Ft.myers,FL
    2003 Lexus ES300/2004 Lexus 330 AWD
    Quick "search" found that this is a common problem....drain hose is clogged;numerous ways to drain/clean it....long screwdriver or small wire BUT be careful when doing so....
    My problem with self diagnosis and self-help is that it can sometimes cost more than having a quailified "tech" address the problem;;;;; one of our "Experienced drivers" took an air hose to his and blew "Shi!" all over himself and truck PLUS cost the company $erious $$$$$ for an A/C component replacement...
  6. Jul 7, 2013 at 3:35 PM
    NH03TacomaTRD4x4
    Doug
    New Hampshire
    Yeah giving it a quick blast with the air hose frees it up for a while, not sure if i'm causing some kind of damage that way or not.
  7. Jul 7, 2013 at 4:47 PM
    hogeyphenogey
    Dave
    Chicopee, MA
    I don't know how to get in there, but how about a vacuum on the end of the hose?
  8. Jul 7, 2013 at 4:50 PM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    A vacuum on the end of the drain would be best. then the wire 2nd. you never wanna blow air into the evap
  9. Aug 22, 2013 at 7:37 AM
    hiroze
    hiroze Member
    Raleigh, NC
    02 Tacoma 4x4 TRD SR5
    I just had this problem (within the past few days). I usually try and fix things myself, but under my current circumstances I had to take it to the dealer. It turned out that the AC drain hose was clogged and causing the water/condensation to dump into the foot area of the cabin.
  10. Aug 24, 2013 at 6:28 AM
    NH03TacomaTRD4x4
    Doug
    New Hampshire
    What did the dealer charge to fix it?
  11. Aug 25, 2013 at 5:34 PM
    hiroze
    hiroze Member
    Raleigh, NC
    $47.52
  12. Aug 25, 2013 at 5:42 PM
    SOSHeloPilot
    SOSHeloPilot Well-Known Member
    U.S.A.
    2016 SR5, AC/LB, 4x2, V6, Auto, w/Tow, SiriusXM, Stock
    UnderCover SE, Bed Mat, Tint, Weather Techs & DashGoPro
    A small "wire snake" (with a smooth end) should do it.
  13. Aug 25, 2013 at 5:54 PM
    HAVOC
    HAVOC Well-Known Member
    You can use shop air and a blow gun but you have to be very gentle with the amount of air.
  14. Mar 16, 2015 at 4:44 AM
    NH03TacomaTRD4x4
    Doug
    New Hampshire
    Wanted to follow up.... I did just this blew air up the tube gently and it drained properly for a while, then started leaking inside again, so I blew air up the tube again(not so gently) and it has worked flawlessly ever since.
  15. Mar 16, 2015 at 4:49 AM
    Clearwater Bill
    Clearwater Bill Retire from work, but not from life.
    Billy
    Clearwater Florida
    '13 5 lug base ACLB w/convenience package
    When you blow up the tube, all you are doing is moving the debris back into the case. Who knows where it's stuck now.
    Clearing the tube should always be attempted with suction first. At least that way you have a hope of actually removing the debris.
  16. Mar 16, 2015 at 5:24 AM
    NH03TacomaTRD4x4
    Doug
    New Hampshire
    I know I tried all that I could, coat hanger trying to free it up and it worked temporarily but wouldn't fix, since I blew it up forcefully it has drained properly without issue. Not saying I recommend others do it this way but can not afford to take to dealer.
    Thx for your input Bill
  17. Mar 20, 2015 at 7:47 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    Probably just snotted up the evap core with mold/algea. :)
  18. Mar 21, 2015 at 1:33 PM
    NH03TacomaTRD4x4
    Doug
    New Hampshire
    I think your right because each time I did it the liquid came out black.
