CONDENSATION IN HEADLIGHTS
Discussion in 'Lighting' started by Reckless44, Apr 7, 2014.
  1. Apr 7, 2014 at 7:47 AM
    Reckless44
    Reckless44 [OP] RecklessGrl
    Susie
    Chino, CA
    Tacoma
    Front Suspension: Camburg 4" lift spindles, DR (Icon) Race Coilovers. OEM upper control arms, SS brake lines Rear Suspension: Old Man Emu 3" lift Dakar leaf springs, matching Old Man Emu rear shocks, extended rear SS brake line
    Ever since I changed the light bulbs in my headlights, I'm having a problem with one of them constantly having condensation. First of all, am I able to get it wiped out (does this require removal) and what can I check to see if I can prevent this from continuing to happen?
    Thanks!
  2. Apr 9, 2014 at 8:13 AM
    Reckless44
    Susie
    Chino, CA
    Tacoma
    53 views of this thread and not 1 suggestion???? LOL....ok, google here I come!
  3. Apr 9, 2014 at 8:17 AM
    Onurnez
    Onurnez Well-Known Member
    Richmond, Virginia
    2008 Toyota Tacoma
    Fog Light Anytime Mod, LED dome and Map, Alpine Head unit, w/ Alpine door replacements, De-badged/De-Flapped, Anzo Black Headlights, Anzo Black Tail lights, Satoshi by Homer, Full OME Kit, LR UCA's Black interior dash parts, UltraGauge, Custom Decals By RuggedT, TRD Exhaust, Volant CAI, Weathertech Rainguards, Weathertech Floormats, Blueinstinct Center and door handle covers, Tacoma Bed Mat, 17x9 Fuel Kranks, 285/70/17, Window Tint: 5% back/35% front, Powerslot Rotors, Redline hood strut, 14'' Black Billet Antenna, LED Bed Light Mod, 100k mile mod
    I would check the rubber gromlet(SP) behind the plug/bulb and see if it's installed correctly. I have never had this issue, but if it was going to leak, it would be from there.
    These are your stock headlights right?
  4. Apr 9, 2014 at 8:19 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Check the rubber grommets....... Check the o ring on the bulb...... Are they OEM housings?
    They should come off....... Spend time in a preheated oven.....sealed with GE silicone II
    I'll be back..... I gotta go to the docs and get more anti crazy meds.
  5. Apr 9, 2014 at 8:20 AM
    theblindchicken
    theblindchicken Well-Known Member
    Christian
    Long Beach
    '74 K10
    HID's, LED Dash swap, LED reverse lights, 15"x10" 5 slot mags, sliding rear window, 20gal aux. DS fuel tank,
    Check the seal around the bulb to ensure that it is actually a good seal.
    It might just be that the bulb has a manufacturer defect and is allowing moisture to get into and trapped in the housing.
    You can get rid of the condensation by removing the housing, removing the bulb, and setting it so that it points down with the bulb mount up top. Let it sit in the sun for a while or heat it up with a hair dryer (you can use a heat gun, but it's very likely that something will start to melt.
    Also, check the silicone seal all the way around the lens to make sure that it hasn't separated anywhere.
  6. Apr 9, 2014 at 8:22 AM
    BamaToy1997
    Bill
    Navarre, FL
    Condensation is normal in many cases, but you will want to be sure to check your vent, and the seals for the bulb. I would suggest against totally sealing the housing. I have seen it happen many times, and the end result is the the housing cracks from air expansion due to heat. if you have a factory housing you can use a can of dry, compressed air to GENTLY blow it dry after removing the bulb. Double check all seals, and reinstall the bulb.
  7. Apr 9, 2014 at 8:29 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    To get the headlight dried up, wait until you get a stretch of dry weather and pull the rubber boot around the bulb completely off and let it vent to the outside. A few days like that and the housing will be dry (time depends on the amount of moisture in the housing).
  8. Apr 9, 2014 at 8:07 PM
    Reckless44
    Susie
    Chino, CA
    Tacoma
    It only started happening after my bulbs were replaced. From what I know, everything is stock and wasn't changed (I bought my truck used). I'm using Sylvania Silverstar Ultra, white lights (Item# 9003/HB2). I believe I'm ok with the bulb but I'll have to check the rubber seal and see if it was put back on properly. The other headlight is just fine.
    Thank you guys for answering this for me, I really appreciate it. :D
  9. Apr 10, 2014 at 2:08 AM
    ZEROPILOT
    ZEROPILOT Can't re-MEMBER
    ED
    SUNRISE,FLORIDA
    09 2.7 XTRA CAB 5 SPEED
    LARGER WHEELS. DIFFERENT STEREO. PUSH BAR. TAILGATE EXTENDER. WIPER MOD. TPMS LIGHT DELETE MOD.
    A little bit of moisture would blow your new bulb pretty quickly once it heats up. I'd remove the bulb and blow compressed air into the housing and let it air dry out in the sun before putting the bulb back in and then make sure that the bulbs o ring is good as stated above.
  10. Apr 10, 2014 at 6:22 AM
    Reckless44
    Susie
    Chino, CA
    Tacoma
    Thank you!
  11. Apr 14, 2014 at 12:10 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    How goes it?
  12. Apr 22, 2014 at 2:14 PM
    AWF ROWD
    AWF ROWD ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
    Brock, I think you should be a little clearer about spending time in the oven sealed with silicone........#JustusSayingBro
  13. Apr 23, 2014 at 5:50 PM
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 S/T Maxx 16X8.5 Level 8 Trackers 5100 1.75 HID, LED interior, 3" N-Fab step bars
    This happened to me. Wait for a weekend with dry weather (very low humidity). For condensation removal, what worked for me...was remove the bulb and hold a shop vacuum over the bulb opening. It takes about 15-20 minutes for the condensation to disappear. (I found this worked better than the compressed air, since you are sucking all the moisture out of the housing). Then when you put your bulbs and the rubber boot..make sure the boot is completely on..if they are old, torn or have the slightest slit or hole you can order some new ones from ebay or your local dealership parts department. If they are in good shape you may want to put some Vaseline on the seal...for a really airtight fit. And as others said, there are 2 vent with black plugs on the back of the headlight housing..make sure they are on.
    Good Luck.
    poyota2015 likes this.
  14. Apr 23, 2014 at 9:52 PM
    Reckless44
    Susie
    Chino, CA
    Tacoma
    Thank you!! I have been so busy lately I haven't had a chance to take a look at that light. I am going to have a lot of free time next week so I'll be taking a look at it then. I appreciate all the responses :)
  15. Apr 24, 2014 at 2:51 PM
    27Tacoma
    27Tacoma Member
    NJ
    Stock for NOW
    Yeah check the grommet. Sometimes, depending on the manufacturer, they grommets tend to be thinner or softer, thus not creating the proper seal.
    Noticed that when i swapped over HID bulbs in my old car. The bulbs were still somewhat loose until i changed them over to the OEM ones.
  16. Mar 13, 2015 at 5:03 PM
    str808taco
    str808taco Active Member
    Sheldon
    Hilo,Big Island
    2014 Tacoma TRD offroad
    3" OME w/5100's upfront & 2.5" blocks in the back with bilstein 5100's. 17x9 Fuel's on 265 70 17 cooper stt maxx . 48 led dome light , led corners , led 5 cree headlights & HID 8k fogs. Switchback & fog light mods done .
    The factory bulbs dont have a rubber seal for headlights the base if light is metal with a spring clip holdind them in . The only rubber by the light is the big rubber on the housing .
