Condensation on inside of windshield
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Twist18, Jan 7, 2024.
  1. Jan 7, 2024 at 6:28 PM
    Twist18
    Twist18 [OP] Member
    Patrick
    2022 White Tacoma SR5
    The past few mornings, I’ve been finding pretty heavy condensation on the inside of my windshield. I’ve never had this issue before, truck is a 22 double cab SR5. I haven’t driven the truck much over the past two weeks, as I’ve been on vacation, just a few short trips, and moving it in and out of the driveway so my wife can get her car in and out of the garage. I know it’s not the heater core because of the lack of use lately. I’ve checked the carpets and they’re all dry, checked underneath the back seats, everything is dry. We have had rain recently, but not a ton, and the nights have been cold. Oh, and the condensation is on the windshield only, no other windows. Any ideas?
  2. Jan 7, 2024 at 6:30 PM
    MountainMike68
    MountainMike68 Well-Known Member
    55°N
    2016 TRD Sport AC/MT
    It happens. Hang a damprid bag and crank the heat and fan when you do drive it.
  3. Jan 7, 2024 at 6:44 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Just because you haven't used the heater much, the heater core may still be bad.
    wombatz likes this.
  4. Jan 7, 2024 at 6:52 PM
    danny15l
    danny15l Well-Known Member
    2022 white Tacoma TRD sport MT
    nada
    Hmmm watch out for any water leaks. I’m just being honest. Check your rugs after heavy rains and really use your nose while in the truck. They’re not common on tacomas.
  5. Jan 7, 2024 at 6:55 PM
    CVCV
    CVCV 3rd Toyota Truck
    Tacoma 2022 3.5L DCSB TRD OR 4x4
    Had a leaky OEM roof rack and saw the same thing. First thing is to figure out where it is leaking.
    If you get a dry day, drive with the windows open to blow out the moisture.
  6. Jan 7, 2024 at 6:58 PM
    iliketacosandburritos!
    iliketacosandburritos! Well-Known Member
    My salvage g2 did that all the time, leaked like a sieve! It’s real fun when you live where it’s cold and you have to scrape the ice off the inside :)
    danny15l likes this.
  7. Jan 7, 2024 at 6:59 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    If you have the recirculate button on, try turning it off so you are drawing fresh air in.
    BC Hunter, Canadian Caber and Chew like this.
  8. Jan 7, 2024 at 7:08 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Pretty common on vehicles that sit for a period of time in winter. The sun is rising and setting, but the days are shorter. Sometimes the interior is colder than the outside air, sometimes vice versa. The windshield and glass is the thinnest interface between these temperature ranges so the condensation occurs there
    if the coolant level is fine it's not leaking, you'd smell it if it was
    CVCV likes this.
  9. Jan 7, 2024 at 7:35 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Like Bro said, it's Normal to some degree.
    If you don't use the truck a lot, moisture in the air will condense on the windows just sitting there.
    The surface temp on glass wont be equal to the air temp.. Once the inside air gets warmer than glass you get condensation.
    I have this happen in the summer. I have gone out to the truck and seen it on m y windshield.
    But mine is due to body sweat. (I do lawn care) I now use towel and seat covers, then take them out and let them dry over night.
    Keeping the windows cracked so that the air temps inside stay closer to outside helps a lot also.
  10. Jan 7, 2024 at 7:44 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    When you drive the truck and have the heater on, make sure the A/C button is on. The A/C will pull condensation out of the air before it is heated and blown into the truck. I never shut off my A/C, even in winter. It helps keep the windows dry. It helps in the wet coast where I live. We have lots of condensation and moisture in the air here.
  11. Jan 7, 2024 at 7:45 PM
    TnShooter
    Deogee
    STOCK
    If you have it set to defrost. The A/C will run automatically. Even if the A/C light isn't on.
    b_r_o and Speedfreak[QUOTED] like this.
  12. Jan 7, 2024 at 7:46 PM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    I mostly get windshield condensation when I leave the heater in the defrost setting when I shut the truck off.
  13. Jan 7, 2024 at 7:48 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Out of curiosity have you checked you in-cab filter?
    Speedfreak and BC Hunter like this.
  14. Jan 7, 2024 at 7:56 PM
    MGMDesertTaco
    Turn on the defroster and it'll clear up.
  15. Jan 7, 2024 at 7:59 PM
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    Also check if there are leaves blocking the air intakes at the base of the windshield, under the hood. That can reduce the amount of fresh drier air coming in.
  16. Jan 7, 2024 at 8:22 PM
    TedTRD
    TedTRD Well-Known Member
    Charles
    2023 Tacoma TRD
    Having the exact same problem with my 2020 Audi Q3. Taking to the dealer tomorrow for a check. Floors and interior are bone dry. Interesting point that it happens to cars that sit a lot and don’t see daily use. This could be the problem for me too.
  17. Jan 7, 2024 at 8:28 PM
    MGMDesertTaco
    When's the last time the system was cleaned? Klima Cleaner on Amazon. :boink:
  18. Jan 7, 2024 at 9:27 PM
    BC Hunter
    I don’t believe that is the case on Canadian models; we’d just get ice in the coils half the year.
    The manual advises against using the A/C for defogging when it is below freezing (32F, OC) or when it is very humid outside.
    Seems counterintuitive that it would come on automatically since both conditions are fairly common in different parts of the US too.
  19. Jan 7, 2024 at 9:35 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    It definitely kicks on in defrost on my Canadian 2nd Gen.
    BC Hunter[QUOTED] and TnShooter like this.
  20. Jan 8, 2024 at 8:48 AM
    Twist18
    Twist18 [OP] Member
    Patrick
    Thanks for the replies, everyone. It happened again this morning. I noticed condensation on the inside of the windshield last night, so I wiped it off with a towel. This morning I went to move the truck so my wife could leave, and the truck was covered with ice. I turned on the defroster, and noticed water all over the inside of the windshield, not sure if it was frozen before I turned on the defroster. The truck said the outside temp was 32 degrees, so I’m sure it got a few degrees colder than that overnight. The truck is in the garage now, with the windows cracked open a bit.
