Condensation passenger seatbelt ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Frez1812, Dec 27, 2020.
  1. Dec 27, 2020 at 3:40 PM
    Frez1812
    Frez1812 [OP] Well-Known Member
    2012 Tacoma 4.0
    2012 4.0 ext cab 97,000 miles
    Heavy rain the other day and noticed passenger side seat belt was damp, almost wet. Would the culprit be the obvious and replace the passenger side doors seals?
    when you close the both doors on that side it’s almost a hollow sound.
  2. Dec 27, 2020 at 3:55 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Do you have a roof rack?
  3. Dec 27, 2020 at 3:56 PM
    Frez1812
    2012 Tacoma 4.0
    No, I do not.
  4. Dec 27, 2020 at 3:57 PM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    I’d think seals.
  5. Dec 27, 2020 at 3:58 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Okay. I’d suggest taking the plastic trim off, closing the doors and running water out of a hose over the door seal to see if you can find the leak
  6. Dec 27, 2020 at 4:00 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Do the “dollar bill” test. Close the door on a bill and try to drag the bill around the door. The harder the bill is to move the better the seal
    vssman likes this.
  7. Dec 27, 2020 at 4:03 PM
    wingspar
    wingspar Well-Known Member
    Oregon
    2011 Tacoma 4x4 Access Cab
    I’m having the same problem, but on the drivers side. Seals look ok, but I don’t know what else would allow water inside the door. Mine is a 2011 Access Cab.
  8. Dec 27, 2020 at 10:22 PM
    wingspar
    Oregon
    I tried that. Resistance was exactly the same on both doors.
