Confirm My Read Diff / Xfer Case Fill Method Is Sufficient
Discussion in '2nd Gen. Tacomas (2005-2015)' started by awoit, Aug 8, 2021.
  1. Aug 8, 2021 at 1:18 PM
    awoit
    awoit [OP] Well-Known Member
    CA
    08 TRD, SR5
    After draining and capping the drain plug on my diff and transfer case I filled them both until fluid was flowing out of the fill hole. I let them both sit for about 15 mins, filled again until the fluid was coming out once more, then capped/torqued the fill plugs.
    the manual says rear diff takes 3 qts but it was more like 2.5-2.7, so just wanted to make sure. I thought about checking with my finger to make sure they’re the right level after driving a little, but wasn’t sure if that’s smart considering the crush washer might be wrecked if I reuse it.
  2. Aug 8, 2021 at 1:25 PM
    Shellshock
    Iowa
    As long as you were parked on level ground, you’ll be fine.
    lots of people don’t even bother to replace the crush washer and don’t have issues
    Taco-Obsessed, TnShooter and Jojee117 like this.
  3. Aug 8, 2021 at 1:36 PM
    awoit
    CA
    08 TRD, SR5
    Yep, all the work was done on level ground!
  4. Aug 8, 2021 at 1:37 PM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    You can always check it a little while later too. It’s not hard to just pop it off and check again.
  5. Aug 8, 2021 at 1:41 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    You can’t drain 100%, there will be some residual fluid. Crush washers are cheap if you “need” to check the fluid level.
  6. Aug 8, 2021 at 2:20 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    You should be fine. I always use Teflon tape on both my drain and fill plugs. I think it helps keep them from being too difficult to remove the next time. I can't remember the last time I bought a crush washer.
