Confirmation of wheels fitting
Discussion in '1st Gen. Tacomas (1995-2004)' started by GEENYUSS, Oct 13, 2017.
  1. Oct 13, 2017 at 12:17 PM
    GEENYUSS
    GEENYUSS [OP] Well-Known Member
    Colfax, CA
    1998 TRD Off-Road 3.4V6
    Icons, SPC UCAs, Solo Motorsports LCA, Bilstein 5125’s, All-Pro Exp Leafs, 285/75/16 BFG KM3s
    Planning on purchasing thes for my truck. Anyone running these just want to make sure they clear my calipers. Pic has wheel specs. 98 4x4 trd xtra cab auto.
  2. Oct 14, 2017 at 8:46 AM
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    It looks like they should fit but hopefully someone who has them will chime in. I'm running pro comp 7069's in a 15" with no clearance issues, and those have similar offset and backspacing (3.5" bs and -19mm offset)
  3. Oct 14, 2017 at 11:51 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    15" fit this gen. -19mm offset will push it out the fender quite a bit though, depending on the tire, you might rub when turning now.
  4. Oct 14, 2017 at 11:53 AM
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    i was always told youd have to run a spacer to make a 15" clear the caliper, but i could be wrong. Maybe that's only steelies.
  5. Oct 14, 2017 at 11:54 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    the earlier 1st gens come stock with 15s wheels.
    FirstTimeFirstGen likes this.
  6. Oct 16, 2017 at 1:01 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    1999-2004 6 lug non vsc trucks can use 15"s no problem. The vsc trucks require 16".
    Standard backspacing is 4.54" with 35mm offset.
    These have 3.74" BS with -19mm offset.
    That means the lip will stick out an additional 54mm from stock, or 2.12", however with the backspacing, pulls the wheel in .8", this all equates to the outter lip of the wheel sticking out 1.32" further then then stock.
    As others have mentioned, you should have no issues with a 15, provided you are running stock brakes you should have no problem. depending on tire size you may have some rub at full lock but ehh, nothing major.
  7. Oct 16, 2017 at 1:21 PM
    FirstTimeFirstGen
    David
    Pacifica
    Dumb question. What's VSC? Vehicle stability control?
  8. Oct 16, 2017 at 2:06 PM
    Fuergrissa
    Fuergrissa If you build it, trails will come.
    Devin
    San Jose
    2000 T4R Limited
    They won't fit your calipers..... if you get the tundra upgrade.
  9. Oct 16, 2017 at 3:07 PM
    GEENYUSS
    Colfax, CA
    thanks
  10. Oct 16, 2017 at 3:25 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    That is correct. I do believe it was an option after 01, not 100%.
    Correct. The 231mm setup wont fit quite a bit of aftermarket 16's either. Toyota 16's work (ask me how I know :D) The 199mm setup fits most 16's (not going to say all)
    No problemo!
  11. Oct 16, 2017 at 6:22 PM
    03 NIGHT TACO
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    VSC was optional on some 04's only, at least from what I have seen. There was no option for VSC prior to '04 and there's not much info around on this.
