Confirmation on Rear Diff Whine
Discussion in '3rd Gen. Tacomas (2016-2023)' started by specialscale, May 7, 2025 at 10:21 AM.
  1. May 7, 2025 at 10:21 AM
    specialscale
    specialscale [OP] Active Member
    Took my 2020 Trd sport to dealer today to get this rear diff whine checked out. Can someone confirm that this TSB fix does not apply to me since for me the whine goes away if I let off the gas pedal? As soon as I push down again it comes back. Dealer is saying bearings.
    Confirm the condition exists.
    Does the vehicle exhibit a whine noise from the rear of the vehicle while driving around 50 mph (80 kph) at constant speed, slight acceleration, or slight deceleration?
    So what does slight deceleration mean here? The noise def dies down/goes away when gas pedal not engaged.
    HondaGM likes this.
  2. May 7, 2025 at 10:30 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Some 2019 – 2023 model year Tacoma Double Cab vehicles may exhibit a whine noise from the
    rear of the vehicle. This condition may occur while driving around 50 mph (80 kph) at constant
    speed, slight acceleration, or slight deceleration.Looks like the warranty for that is
    3/36
  3. May 7, 2025 at 10:50 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    I've experienced this with both my previous '06 TRD OR and my current '21 TRD OR.
    Only under light acceleration on a level road. Seems to be normal and has never triggered any repairs.
    Chew likes this.
  4. May 7, 2025 at 11:47 AM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    Mine could be whining but between the roof rack wind noise and tire noise I will never know.
    musicisevil likes this.
  5. May 7, 2025 at 5:13 PM
    denimdan73
    denimdan73 Well-Known Member
    2022 TRD Off Road DCSB
    Pro Skid Plate - Lone Star Knock Off Trail Edition Lift - DIY - Toyota Parts
    Pretty sure mine is fuel pump whine. It’s done it since brand new and can only hear it with all windows open at low speeds.
  6. May 7, 2025 at 7:15 PM
    1taco2motos
    1taco2motos Well-Known Member
    Colorado
    19 DCSB mgm TRD OR 6MT
    I changed the gear oil in the rear diff @ 54k and the whine disappeared. My belief is that the oil level was a bit low from the factory.
    GTGallop likes this.
  7. May 8, 2025 at 7:04 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    This is "feathering" the accelerator between slightly accelerating and slightly decelerating. Gas pedal is engaged slightly - not off the pedal in both cases.
    My 2021 OR did it before I put on noisy tires.
  8. May 8, 2025 at 7:07 PM
    islandhiker
    islandhiker Well-Known Member
    Calgary, AB
    2021 TRD Off Road AC
    My '21 access cab trd off road whined from the factory - I took it back to them after about 500kms (new) and they said it was full of metal and they replaced the entire rear diff under warranty. The new one still whines when I do exactly what you do, they checked it over and said it was fine. Just something I've gotten used to.
  9. May 8, 2025 at 9:13 PM
    DadBodTaco
    DadBodTaco Member
    Bay Area, CA
    2021 TRD Off Road
    My '21 OR had it since new. I changed my diff oil at 30K with Redline 75W85 and the whine went away.
  10. May 8, 2025 at 9:19 PM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    If you have ever seen them filling fluids on the line you'll realize it's a miracle they are anywhere close. Sure the exact measurement is known and some of those guys hit the mark exactly, but some of them pour like the hostess is having to man the bar. Over pouring and under pouring.
