Confirmed- don't switch back to regular oil after high mileage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoHunter805, Dec 19, 2017.
  1. Dec 20, 2017 at 7:20 PM
    #41
    TacoHunter805
    TacoHunter805 [OP] Well-Known Member
    Sorry but 170k miles with zero leaks then 3 weeks after switching there's a pretty big leak. That's more than a coincidence. At least more than likely. And if you do some research there's quite a bit of discussion on this topic. I wouldn't have necessarily bought into it before this either. But I do now. Laugh it up. Idc. Yes I can change the seal. That's not the point. Was an additional bit of personal experience I thought might be helpful to someone. Isn't that what this forum is about? Anywho, haters gonna hate I guess.
    toyodajeff likes this.
  2. Dec 20, 2017 at 8:28 PM
    #42
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    I too can't see why the "Lubricant" should change the seal of the pan.
    If I had to take a flying guess ..... Perhaps the change in type oil caused a difference in sealing and blow by of the rings and wipers on the pistons. Increased pressure in the pan could result if there are problems with the PVC system ??? Just trying to think out of the box.
    mechanicjon likes this.
  3. Dec 20, 2017 at 10:17 PM
    #43
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    I’m not trying to give you a bad time. And maybe for some reason the oil is the cause of the gasket failing and leaking. In any event I would at least tighten the pan bolts. Whether it’s the oil or not the gasket has failed. The problem is the gasket!! What caused it is debatable but the leak is due to gasket failure. At this point changing back to the previous oil may or may not fix the problem. No matter what, you need to replace the gasket. Even if changing the oil stops the leak you still need to replace the pan gasket.
    PackCon likes this.
  4. Dec 20, 2017 at 11:12 PM
    #44
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    If you dont want too fix the leak,then why bother.
  5. Dec 20, 2017 at 11:47 PM
    #45
    BWilley
    BWilley Well-Known Member
    Brian
    Seattle
    2005 Tacoma DCLB Prerunner Desert Sand
    Skid plate, TRD Exhaust
    Holy cow I was literally crying I was laughing so hard reading this that I couldn't even get through it. :rofl:
  6. Dec 21, 2017 at 8:17 AM
    #46
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Why is everyone shitting in this thread.
    Op, I can see how putting in oil with less additives that are supposed to make the gasket swell and stay soft, after using oil with more additives, would cause a leak. I normally try to stick with one brand and type of oil for this reason. Maybe I'm just not as much of a genius as everybody else in here.
    Most of the people shitting in here get there oil changed at jiffy lube and will trade their truck in for a nissan leaf next year anyways.
  7. Dec 21, 2017 at 9:26 AM
    #47
    Chris Miles
    Chris Miles Well-Known Member
    2016 Toyota Tacoma
    Trailer Hitch Cover - Star Wars Pulp Fiction Boba Fett & Stormtrooper
    one time i put different electricity in my nissan leaf and all the electricity leaked out of my battery. i'm going to go back to my old electricity. that should fix it.
  8. Dec 21, 2017 at 9:38 AM
    #48
    JGO
    JGO Well-Known Member
    South Central Kentucky
    '14, 4 Cyl, A/T, Silver A/C
    I have learned one thing by reading this thread and that is to never post if you have a problem and you are not knowledgable; this is a forum exclusively for those who know what they are doing.
    Kolunatic and DGXR like this.
  9. Dec 21, 2017 at 10:06 AM
    #49
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Welcome to TW. btw you misspelled knowledgeable. :)
    jshsltr, black coffee, Pigpen and 2 others like this.
  10. Dec 21, 2017 at 10:37 AM
    #50
    JGO
    I am obviously one of those people who is not knowledgable.
    Borealis, stickyTaco and DGXR like this.
  11. Dec 21, 2017 at 10:57 AM
    #51
    mojovious
    mojovious Well-Known Member
    PA
    2013 Baja TX
  12. Dec 21, 2017 at 11:32 AM
    #52
    scottfarm
    scottfarm Well-Known Member
    Florida
    tacoma 4X4
    aires 3D mats, scan gauge II, rear differential breather relocation, and bakflip G2 bed cover.
    Should have used Quaker State 30 weight.
  13. Dec 21, 2017 at 11:34 AM
    #53
    EnonEye
    EnonEye Well-Known Member
    David
    O-H-I-O
    Silver '06 DCSB TRDPreRunner Off-Road/ Tow package
    Pleeeeeease... quit confusing me with facts... I'm enjoying the dino/synthetic/ low/high mileage theories.
    Sprig[QUOTED] likes this.
  14. Dec 21, 2017 at 11:38 AM
    #54
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    that just about sums it up. it shouldn't leak no matter what oil. Lets say its due to the change in oil, well, it was close to leaking anyway
    b_r_o[QUOTED] likes this.
  15. Dec 21, 2017 at 11:45 AM
    #55
    EnonEye
    David
    O-H-I-O
    Not true GJO. I have mostly life experience, backyard mechanic knowledge and 2 years working with "mechanics" at Uniroyal back when the Browns were good (oh the memories) in other words I'm a novice but over the years this site has been GREAT. Ya gotta take the good and the bad and remember not everything on here is gospel. We're all on the same team here, all Taco lovers, ya gotta expect a little fun being poked around and don't be so easily insulted. Lots and lots of good information here and it won't take you long to know who really knows their stuff on here. Welcome
    Pigpen and JGO[QUOTED] like this.
  16. Dec 21, 2017 at 11:58 AM
    #56
    TacoHunter805
    Kolunatic and toyodajeff like this.
  17. Dec 21, 2017 at 12:06 PM
    #57
    TacoHunter805
    That was cute :thumbsup::rolleyes:
  18. Dec 21, 2017 at 12:12 PM
    #58
    Sprig
    Ken
    The op is getting a load of poop from most because he made a statement as if it were fact. It isn’t a fact, nor does it have any validity. He just guessed. Had he asked for people’s thoughts on the cause of the oil leak or asked if people thought the leak could be caused from using a different oil he would have gotten thoughtful reply’s. He basically set himself up to have people dump on him by making dumb statements. I personally think the leak was caused by changes in the earths magnetic field along with a drop in barometric pressure. Or possibly the cause is due to climate change.
  19. Dec 21, 2017 at 12:50 PM
    #59
    TacoHunter805
    So here are the facts. Just to simplify for anyone who needs it
    1) Some high mileage oils have additives that swell seals.
    2)Those seals will only stay swollen as long as the hm oil (or another additive to do this) is in the engine.
    3)I went 170k miles without seepage/leak. Zero. 3 weeks after switching - bunch of seepage.
  20. Dec 21, 2017 at 12:57 PM
    #60
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You keep saying "seals". Not to split hairs too much but the gasket you're looking at is FIPG (form in place gasket) or silicone. It seals/behaves differently than a regular metal/rubber gasket. Drop the pan, clean and dry the sealing surfaces really good, get your hands on a tube of good quality silicone and lay a nice bead! Don't get too sloppy with it, a little goes a long way. Surfaces have to be clean and dry with no oil residue.
    Also there is some wisdom to checking the pcv system to make sure there isnt excessive crank case pressure forcing oil out the seals. With the engine running, take the oil cap off, ziptie a rubber glove over the fill neck and see if it blows up like a balloon. Ideally there should be a small amount of vacuum (sucking the glove down the fill neck)
    DaveInDenver and blu92in99 like this.
