confirming bolt pattern/offset and Bspacing
Discussion in 'Wheels & Tires' started by ComaTosin, Mar 8, 2009.
  1. Mar 8, 2009 at 7:02 PM
    ComaTosin
    ComaTosin [OP] The Not So New guy
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    i need new wheels/tires and wanted to make sure i had everything correct prior to ordering or serious shopping. does this sound correct?:
    *Tires - 285/75/16 or 17
    *Wheels 6/5.5, 16 or 17" 4.5 backspacing (ANY OFFSET?)
    **what rides better on the road? 16 or 17? any difference?
    BTW - i have toytec C/O at 2.5" and 2" blocks out back. I currently run 285/75/16 on polished al rims but can not rember the offset or backspacing.
    I rub a little but can fix by going up on C/O some.
  2. Mar 8, 2009 at 7:29 PM
    rick
    rick `
    it should fit. you probably mean 285/70/17. as far as the offset check this.
  3. Mar 8, 2009 at 7:37 PM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    better selection with 17" wheels but softer ride with 16" - yeah?
    not sure i understood the table for offset - I'm dense!
    Also i think i have 8"wide wheels now. how does the width effect the ride?
    I think i am sold on the Terra Grapplers as they get good reviews and look good and hopefully deliver a better ride than my BFG A/T.
    Lastly, is there a difference in ride quality between chrome and Al? given that they were same size and same tires etc?
    sorry for all of the Q's I'm hijacking my own thread here i think......
    thanks
  4. Mar 8, 2009 at 7:45 PM
    SuperD
    SuperD Mall Cruiser Pilot
    Texas
    '09 White TRD Sport DC LB 4x4
    ProComp 6" Stage II, 18x9 Moto Metal 955's, Cooper Discoverer STT 305/60R18, K&N FIPK, Go-Rhino Stainless side steps, Redline Elite hood struts, Magnaflow muffler, Delta Alum. Toolbox, Husky Liners F/R, Window tint
    Anything with a negative offset (ie. -12mm) and you should be fine.
  5. Mar 8, 2009 at 7:50 PM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    cool. thanks i had to take a grinder to my brakes to keep these from touching. probably .5mm that i took off and now they fit fine.
