Conflicting information for balljoint torque spec
Discussion in '1st Gen. Tacomas (1995-2004)' started by Nessal, Jun 21, 2021.
  1. Jun 22, 2021 at 11:02 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I think he brought up the rubber shield because in another LBJ thread I had mentioned that I broke a brand new bolt (bolt/washer) when torquing them down to spec without the rubber boot. I figured maybe those two mounting circles on the rubber boot helped keep those two bolts from bottoming out in the spindle and that's why I snapped one :notsure:
    I ended up putting the rubber shield back on, got another OEM bolt and it went on just fine. I don't know if it was a just a bad bolt or if it broke because the rubber shield wasn't in place, but either way I'm not keen on finding out again. Getting the broken half out of the spindle sucked. Luckily I was able to back it out slowly with needle nose pliers.
    MalinoisDad likes this.
  2. Jun 22, 2021 at 11:04 AM
    Nessal
    Nessal [OP] Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Can you confirm that you used these 35mm length bolts?
    https://www.mcmaster.com/95735A635/
  3. Jun 22, 2021 at 11:12 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Yeah, I could see where that might be possible with the two outboard bolts since they do not go through the spindle. The OEM bolts with a washer are longer than the flanged head bolts.
    This looks correct, but I'll have to confirm later once I get back to my records at home.
    eon_blue[QUOTED] likes this.
  4. Jun 22, 2021 at 11:16 AM
    Nessal
    Texas/Bay Area
    Thanks. I appreciate it!
  5. Jun 22, 2021 at 11:16 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Those are the correct ones, yes. 35mm should not bottom out in the two blind holes either with or without the rubber boot guard. It’s always worth cleaning out as much of the threads as possible, to get any old Loctite, grease, or rust out of there to ensure the correct thread fitment.
    Nessal[QUOTED][OP] and Digiratus like this.
  6. Jun 22, 2021 at 12:04 PM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    Since we're on the subject of balljoints, does anyone run the Sankei 555's? I have a set on my lifted 04 Tacoma that I installed a few years ago. I just installed these lowers on my wife's 02 runner 2 weeks ago. I was told by my parts guy at my local Toyota dealership that Sankei is the manufacturer of bj's for Toyota. These come with the new mounting bolts.
  7. Jun 22, 2021 at 12:08 PM
    Nessal
    Texas/Bay Area
    They are the OEM manufacturer but I read that there is a large quality difference. Someone did a disection of both BJ and the afternarket one was very different internally. The OE is a full ball joint whereas the aftermarket one is only a half ball. I'm not in the position to pull up the thread at the moment but I believe the consensus is to just get the OE. But I'm glad it's working out for you.
  8. Jun 22, 2021 at 12:09 PM
    eon_blue
    Azusa, CA
    ^ that's what I was going to mention. That thread is very informative.
    They are the manufacturer but the specs to which the ones for Toyota are made are different. That being said, a lot of people seem to run the 555 lowers and swear by them so, to each their own.
  9. Jun 22, 2021 at 12:39 PM
    68dave
    Dave
    I did not know that. I'll research it and read that thread. On all my yotas I rotate the tires every other oil change and I check the bj's with a pry bar under the tires every time. So far no issues with the 555's on my Tacoma. I recently replaced my wife's because her t4r is at 145k miles and I read its recommended to change them at 150k for preventative maintenance.
  10. Jun 22, 2021 at 12:40 PM
    68dave
    Dave
    I'm a auto tech by trade and I've installed 555's on all my customer's yotas and so far no issues.
  11. Jun 22, 2021 at 1:10 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    This is more simple than what is being discussed.
    Simply use the proper grade bolt of the correct diameter and thread pitch. Torque per specification.
    Most torq specs are for dry threads, as soon as you put any liquid (locktite, anti-seize, butter, ....whatever) it is now a lubricated thread. The torq spec needs to be reduced to use the lubricated specification. This is common a path to over-torque troubles.
    All fasteners at correct torque will "stretch". This stretch is what provides the clamping force to hold the parts together. If the bolt begins to YIELD, or stretch without return, then the bolt has failed. When the bolt is stressed within its tensile strength, then it will hold the parts. Beyond tensile strength the clamping load is gone. This is a fundamental property of steel and all materials.
    Always use NEW replacement fasteners for critical applications. Bolts, nuts, screws are like engine oil. Cheap. A failure is much more trouble.
    FWIW, a flange head bolt performs the same as a hex head/washer combination. It is easier for production assembly due to less parts need to be handled. A Grade 10.9, 10 x1.5, flange head will have the same strength as a Grade 10.9, 10x1.5 hex.
    Digiratus, MalinoisDad and drr like this.
  12. Jun 22, 2021 at 4:22 PM
    Digiratus
    Roaming the PNW
    The RedHead
    As Dan confirmed, the McMaster-Carr webpage you listed is to the correct bolt. I just confirmed my invoice displays the part number as: 95735A635. These are available as 10-packs. I paid $15.07 shipped for one 10-pack.
    68dave likes this.
  13. Jun 22, 2021 at 7:38 PM
    petecarlson
    petecarlson Well-Known Member
    2002 4X4 DC TRD
    I think that the original question is if one should follow the FSM (59 ft/lb) or the Recall (37 ft/lb). I would argue the recall supercedes the FSM and thus 37ft/lb is the correct torque per page 7. I come from the aviation world. If the manufacturer came out with a fix, that's the way it's done from then on. Doesn't make any sense to replace the bolts holding the wings on, torque them to a new value, and then, the next time you work on them start using the old torque value again.
    http://media.fixed-ops.com/Toy_Campaigns/50Jtech.pdf
  14. Jun 22, 2021 at 9:28 PM
    Nessal
    Texas/Bay Area
    UPDATE: So I changed out the passenger side this evening and did some experimenting. TLDR: Both McMaster and the original bolt did not stretch when torqued to 59ft/lb with blue loctite. Not sure how that person linked in the original post got them to stretch at such a low torque.
    Picture 1: This is the OE bolt that I removed put side-by-side with a new McMaster bolt. As you can see, there was no stretching. However, we don't know if the factory torqued to 59ft/lb or 37ft/lb.
    Picture 2: I put the OE bolt back in and torqued it to 59ft/lb with blue loctite. The bolt did not stretch after removing. Here it is comparing it to the McMaster bolt again.
    Picture 3: Here is the Mcmaster bolt torqued to 59ft/lb with blue loctite compared to a new McMaster bolt. Again, no stretching.
    eon_blue likes this.
  15. Jun 22, 2021 at 9:34 PM
    #35
    Nessal
    Texas/Bay Area
    I forgot to ask...it appears that you can't use the balljoint rubber protector with the flanged bolts. When you try to tighten them, it will start to tear. Is this protector critical? If not, I was planning to remove it. The only way I got them to not tear is if I put the OE bolt with the washer back in but I don't want to use old bolts since I already have new ones.
  16. Jun 22, 2021 at 9:48 PM
    #36
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    I like that you tested this theory, there's no better way to understand how something works than the scientific method. However, there are some underlying principles that will help in explaining what's happening here.
    There are two types of stretching that might be seen in these bolts - either elastic deformation or plastic deformation. In elastic deformation, the stress in the bolt when it's torqued is lower than the yield stress of the material, and the bolt will be temporarily stretched when stressed (which provides the clamping force holding the ball joint to the knuckle) and then will return to it's original length when un-torqued (think elastic like a rubber band).
    In plastic deformation, the stress is higher than the yield point of the material, and any load/torque above the yield point will result in permanent stretching of the bolt. This is commonly taken as 0.2% strain, so in a bolt that is 35mm long it would start to permanently deform once it reaches about 35.07mm - probably too small of a stretch to see with the naked eye.
    Almost all bolts and machine screws are designed to stay below their yield point when fully torqued, with the exception of torque-to-yield bolts like head bolts. You should not expect to see any permanent deformation in the LBJ bolts, if you did that would be an indication to replace them.
    Knute and Nessal[QUOTED][OP] like this.
  17. Jun 22, 2021 at 10:27 PM
    #37
    eon_blue
    Azusa, CA
    The rubber dust shield isn't necessary. 1995.5 - 2000 1st gens didn't have them. They do help protect the LBJ boot though, from road debris and what not. But not necessary
    Thoy and Nessal[QUOTED][OP] like this.
  18. Jun 22, 2021 at 11:08 PM
    #38
    Nessal
    Texas/Bay Area
    Thanks. One of the hole complete broke and the other is barely hanging on. I'm going to undo the bolts tomorrow and just remove it. Then on the driver side, I'm not going to reinstall it. Thanks.
    Digiratus likes this.
