Conflicting Oil Capacities
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MK27, Jan 3, 2015.
  1. Feb 5, 2016 at 6:39 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
  2. Feb 5, 2016 at 7:13 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Always to top dot. There is roughly a quart in circulation while the engine is running. Check the dip stick while it is idling and see where the level is on the stick. If it is below the bottom dot while idling, the engine is on the verge of brief periods of oil starvation for bearings, depending on the driving conditions.
    Semi-notorious on the shallow oil pan engines. Due to the pick-up being in the shallowest portion of the lower oil pan.
    Always top dot.
