confused about 5100 shocks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JTO, May 25, 2010.
  1. May 25, 2010 at 7:29 AM
    JTO
    JTO [OP] Well-Known Member
    San Diego
    PreRunner Sport
    are these for lifts or are they for replacing stock shocks?
  2. May 25, 2010 at 7:30 AM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    yes :)
  3. May 25, 2010 at 7:33 AM
    JTO
    San Diego
    PreRunner Sport
    so if i got these to replace my stock shocks what else would i need if i wanted to lift my truck? Sorry but im a total noob to this stuff. Ive only owned cars before getting my tacoma.
  4. May 25, 2010 at 7:38 AM
    Kernel
    Kernel Well-Known Member
    Ohio
    09 TRD Off Road 6sp Manual
    5100's all 4 corners, front at .85 with Eibach Coils, Rear TSB w/AAL, TRD Catback Exhaust, AFE Pro Dry S, Duratracs, redline hood struts, maglight mod, weathertechs
    You can adjust the 5100's up to 2.5 inches of lift with your stock coils. Some are also running the 5100's at the stock 0 setting with lift coils. So depending on what you want to do, nothing.
  5. May 25, 2010 at 7:39 AM
    JM76
    JM76 Ride On
    Jon
    SC
    2016 AC SR 4x4
    bone stock save for the block lift that came on it with the open country m/t.
    how much do you want to lift it?
  6. May 25, 2010 at 7:39 AM
    NetMonkey
    Geogetown, TX
    the adjustable 5100's have 4 settings of lift (0", 0.85", 1.75", and 2.5") for the front only. for the rear, you would need an add-a-leaf, a block, or a new spring pack.
    for the front, the 5100's are all you need to lift. at the 2.5" setting, you may have problems getting a good alignment and you may want to get new upper control arms (UCA's), but most people with the 5100's at 2.5" dont get new UCA's.
  7. May 25, 2010 at 7:42 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The 5100's for the front are coilover struts and are adjustable. That is why you can get a lift from them.
    The 5100's for the rear, are a standard shock. They are not adjustable and will not lift the rear of the truck.
  8. May 25, 2010 at 7:59 AM
    JTO
    San Diego
    PreRunner Sport
    Im looking to lif the truck 3" preferably.
    so what would be the best set up for lifting the rear, an add-a-leaf?
  9. May 25, 2010 at 8:04 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    3 is the max without cutting stuff.
    AALs are 2" or 1 1/2".
    The rear 5100s will handle the extra 2" lift, stroke wise.
  10. May 25, 2010 at 8:07 AM
    JTO
    San Diego
    PreRunner Sport
    So if i wanted a 3" lift should i just buy a suspension kit from pro-comp or something?
  11. May 25, 2010 at 8:15 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    If you really want the extra 1/2", you could go with an OME (old man emu) setup along with a small top plate spacer. Do a search for it and you'll find what you need.
  12. May 25, 2010 at 8:17 AM
    JTO
    San Diego
    PreRunner Sport
    2 1/2" lift is fine, i just want to make sure that i get the best bang for the little money that i have :)
  13. May 25, 2010 at 8:19 AM
    TexasTacoma37
    The bilstein 5100's up front and an AAL in the back is your best bet for a good quality, inexpensive lift.
  14. May 25, 2010 at 8:22 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Check out ToytecLifts.com A lot of guys got there setups through them.;)
  15. May 25, 2010 at 9:26 AM
    PreRunner
    PreRunner Well-Known Member
    dont get the 5100's for the rear if you're going to lift, they're not any longer than stock.
    1.5" lift ~ 8,60 length 5125
    2.5+ lift ~ 9,24 length 5125
    IMO
  16. May 25, 2010 at 9:29 AM
    TexasTacoma37
    The 5100's can accommodate up to 2" of lift according to what I've read. There was also a picture around here showing that the billy's are indeed a bit longer than stock . DSM or Toytec posted it.
  17. May 25, 2010 at 9:34 AM
    PreRunner
    Ive had both the 5100's and 5125's. Lots more travel and articulation with the 5125's. 5100's are not longer, and frequently top out easily. They are 22.5" extended, same as stock.
  18. May 25, 2010 at 9:41 AM
    JTO
    San Diego
    PreRunner Sport
    Again, forgive me if i sound ignorant.
    If the 5100's are the same length as stock how can they give you any lift? are the 5125's all the way around, the way to go?
  19. May 25, 2010 at 9:46 AM
    98tacoma27
    Ben
    Not Beech Creek
    The front coil overs are adjustable. The rear 5100's don't give lift, they only accomodate for lift. That's way you will need an AAL (Add A Leaf) in the rear for lift.
  20. May 25, 2010 at 9:50 AM
    JTO
    San Diego
    PreRunner Sport
    so 5125 front and back combined with an AAL in the rear? Would this give me a level lift or will it do that Cali lean lift ( higher in the front than the back)
