Confused about AAL (help!)
Discussion in 'Suspension' started by truckistan, Apr 14, 2020.
  1. Apr 14, 2020 at 8:34 AM
    truckistan
    truckistan [OP] New Member
    Hello,
    3rd gen TRD off-road owner here, totally stock except for:
    Canopy (not sure - fiberglass so maybe 200lbs from quick googling)
    Steel swing out hitch (45 lbs)
    Aluminum bike rack attached to steel swing out hitch (45 lbs)
    Safety gear I keep in the back at all times (100lbs ish)
    This is a total of about 400lbs that are attached to my Tacoma at all times, and the back end is a bit saggy. I am not ready to bite the bullet on a full suspension upgrade at this time, but I'd love to just compensate for the weight in the back end.
    However, all the AAL's or leaf packs I see are "lifts" and I don't know if I should be looking at those or something else?
    Can anyone suggest to me the cheapest way to compensate for 500 or so lbs in the back of the truck without otherwise changing the suspension?
    I was looking at:
    https://www.amazon.com/Icon-Lift-Rear-Leaf-51100/dp/B07TG7BPKX
  2. Apr 14, 2020 at 10:09 AM
    zdski
    zdski Well-Known Member
    Zach
    Phoenix, AZ
    2011 DCLB TRD Sport
    5100s, AAL, TRD Wheels, 285 Ridge Grapps
  3. Apr 14, 2020 at 10:12 AM
    doorsidedown
    doorsidedown Well-Known Member
    a three leaf progressive AAL will provide about 1.5” of lift with an empty bed. If you’re constantly carrying ~400lbs it would most certainly get you back to stock height (maybe 1/2” - 1” of lift all said and done.
    but - your best option is to contact deaver or general spring and give them your exact specs and get a custom set made.
    @HeadStrong Off-Road
    if you talk with Marie at HeadStrong, she may have a good solution for you.
  4. Apr 14, 2020 at 10:55 AM
    truckistan
  5. Aug 4, 2020 at 11:04 PM
    C41n
    C41n KDMax Pro Authorized Tuner | Portland, OR
    Anthony
    Portland, OR
    2020 DCSB OR MT
    I just added a canopy and sleeping platform to mine. Looking at about 500#s all the time in the rear and I am not happy with the ride.
    Have basically the same question as @truckistan . I want to compensate for the extra weight in the rear without springing for a full suspension right now. Looking to get back to close to stock performance for as cheap as possible right now.
    Eventually I will do a full lift but I cannot do that right now.
    Options seem to be:
    Add a leaf
    Full leaf pack
    Airbags
    Helper springs
    Full leaf pack seems like it would need shocks also. Perhaps even so for an AAL.
    What did you end up doing OP, and how do you like it?
