confused about lifts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tomwilson74, Apr 1, 2012.
  1. Apr 1, 2012 at 4:38 PM
    tomwilson74
    tomwilson74 [OP] Well-Known Member
    Tom
    West Virginia
    2020 TRD double cab OR
    OME 3” lift Mickey Thompson Classic III Wheels
    I am a two week Tacoma owner. I have read and read on this forum about lifts. Suspension and body. I just want a body lift to put 285's on. I don't do much off roading, just "dirt" roading mostly. I can't seem to find a body lift for a 2012 double cab with everything needed to complete the job without having to buy extra parts. I have a trailer hitch that came on the truck and that is starting to be a problem. I would love to talk to someone here in southern West Virginia in person about what they have done to their truck. I am hoping to get rid of some of the confusion soon.
  2. Apr 1, 2012 at 4:43 PM
    tacoftw
    tacoftw 5100s are the same price as spacers, seriously
    McDonough, GA
    05 Double Cab 4x4
    5100s, camburg arms, toytec AAL, 285s on m/t 17x9
    well put man, id never do a body lift or even ride in a truck with one. especially if you plan on using your truck as a truck (hauling, towing, etc)
    i wouldn't want 1500 lbs in my bed resting on 3" poly spacers
  3. Apr 1, 2012 at 4:44 PM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    body lifts are a no-no, even for the most mild of drivers
  4. Apr 1, 2012 at 4:45 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Do it the right way and do a suspension lift. Body lifts look stupid and could be dangerous. You just bought a brand new $30k truck. Don't cheap out. You'll thank yourself later.
  5. Apr 1, 2012 at 4:47 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
  6. Apr 1, 2012 at 5:03 PM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    ^^^ no wheels ?
    Its a spacer lift
  7. Apr 1, 2012 at 5:05 PM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    Jk its a body lift;)
  8. Apr 1, 2012 at 5:50 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    1" BL and a small suspension and some trimming, clear 285s no problem.
    NO lift and trimming and clear 285s no problem.
    I keep thinking about a 1" but the bumper gap would drive me fucking crazy I think.
  9. Apr 1, 2012 at 7:17 PM
    tomwilson74
    Tom
    West Virginia
    I have been driving a Dodge Dakota for the last seven years and don't know much about Tacomas. Where should I start looking for a suspension lift? And what would be a decent price for everything needed to complete the job. I just want to find a complete kit because I don't know what all is needed for a lift. Thanks for the help.
  10. Apr 1, 2012 at 7:27 PM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    lots of guys do the ultimate lift.
    if ur short on cash just get bilistein shocks on all 4 corners preload them. I think people are saying 400$ from downsouth motorsports (a vendor on here)
  11. Apr 1, 2012 at 7:28 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    beat me to it haha
  12. Apr 1, 2012 at 7:28 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    There are preload spacers. Spacers that mount above the whole shock/coilover assembly, but they're a bad idea. Then there are 5100s, a new shock that basically preload your factory coil without a spacer. Then there are lift coils that replace factory coils. Then there are coil overs that replace coils and shocks with a whole new adjustable assembly.
    Kinda depends on how much you want to spend and what quality you're looking for.
    I'd recommend lift coils myself. Spacers or 5100s work too.
    If you get a full 3" chances are high you won't be able to get your caster angles (alignment) into spec, they'll be a bit low and though it won't wear your tires, it depends on you whether or not you're okay with how the truck handles.
    Some don't notice, some feel like it wants to wander and requires more steering input to keep the truck tracking straight.
    Some won't have that issue at all. To fix you'll need aftermarket UCAs with added caster and camber, another 400$.
    Keep your lift low and maybe a 1" BL, no more, and you'll likely be able to get away with going cheap on your lift.
    AAL in the rear.
    Wheelersoffroad.com, really good guys.
  13. Apr 1, 2012 at 9:01 PM
    TheGloryFades
    TheGloryFades Well-Known Member
    Seth
    Arizona
    '13 toaster
    Do you have a link by any chance?
  14. Apr 1, 2012 at 10:22 PM
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    X2
  15. Apr 1, 2012 at 11:10 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Pre-load spacers or 5100s might not ride as nice but IMO you have less chance of breaking shit since you're not extending the whole assembly however many inches your top spacer is.
  16. Apr 2, 2012 at 9:20 AM
    tomwilson74
    Tom
    West Virginia
    I have about $500 to spend on the lift. Any suggestions. I want it to be safe and ride well on the freeway. Like I said, I do more "dirt roading" than off roading. We have a lot of back roads here in West Virginia and spend lots of time exploring them.
  17. Apr 3, 2012 at 9:07 PM
    ILove2Drive
    ILove2Drive Well-Known Member
    Casey
    WV
    07 Tacoma 4X4 5 Speed Manual
    Halo headlights, Black tail light covers, dual exhaust, 5100s front and rear, eibach coils, wheelers 1.5 AAL, window tint, bow arrow antenna, bull bar, painted grille emblem, debadged, raceline rims, a few decals, CB radio, alpine HU, husky floor liners, tool box, mesh grill...and more to come eventually
    I love the setup I have and its right around your price rang. 5100s up front and back with eibach coils and wheeler's 1.5" AAL in the rear as well. I'm sitting at about 3.5" of lift though and have had the needle bearing issue that's pretty hit or miss with these trucks so you may want to keep it one notch down but it is definitely a pretty cheap way to look good and have some good performance too!
  18. Apr 4, 2012 at 6:19 AM
    ILove2Drive
    Casey
    WV
    No you're not. I had a big long thread on here a while back and we determined that the billies were set on the second rung with the eibachs plus I'm a reg cab 4 cyl so not as much weight up front either.
  19. Apr 4, 2012 at 6:22 AM
    ILove2Drive
    Casey
    WV
    Plus from center of hub to bottom of fender is a hair past 23.5" and I was told that that was about 3.5" beyond stock.
  20. Apr 4, 2012 at 6:52 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    IMO you will sacrifice function for form with any $500 lift just to fit 285's.
    I see no reason one must have 285's besides "looking cool" and to me getting them for that reason is just stupid.
    IMO either do it right and spend way more then $500 or don't do it at all and buy tires that fit your truck as it is now.
    If your an avid trail rider I would suggest a TALLER tire for more clearance, not a wider tire that does just about nothing besides provide a very miniscule amount of added floatation in sand/mud/snow and has you chopping shit apart to fit them.
    Good luck OP. I would go back to the drawing board if I was you and seriously consider what you want. Form > Function or Function > Form.
