Confused about modified banjo bolt with tundra brake upgrade
Discussion in '1st Gen. Tacomas (1995-2004)' started by ghoststoglory, Oct 29, 2010.
  1. Oct 29, 2010 at 6:51 PM
    ghoststoglory
    ghoststoglory [OP] Well-Known Member
    Like the title says...I'm not entirely sure how to modify the banjo bolts. From all the threads I've looked at, I couldn't find one with pictures still active. Could someone please explain to me exactly what to do to my banjo bolts to keep them from leaking with tundra calipers? I've searched around and haven't found much, so thanks for your help.
  2. Oct 29, 2010 at 7:43 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    never read the tundra brake upgrades, but could it be as simple as getting custom brake lines or even getting a different size copper washer? could you pm me a link so i can read?
  3. Oct 30, 2010 at 6:38 AM
    ghoststoglory
  4. Oct 30, 2010 at 10:02 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    it says the kit comes with custom brake lines ???
    if it didnt id reccomend getting custom ones, with a toyota tacoma end for the part that connects to the double wall steel line on your truck and a tundra banjo bolt for the tundra caliper and the proper copper washers
  5. Oct 31, 2010 at 12:41 AM
    JDBECK23
    JDBECK23 Well-Known Member
    Jesse
    King George, Va
    '01 Tacoma Reg Cab 4 cyl 4x4
  6. Oct 31, 2010 at 10:37 AM
    ghoststoglory
    I have read that, thank you though. So is the consensus that I should get tundra hoses for the calipers? Will I need to modify the other end of the hose (not on the caliper side) or will it mate right into the existing fitting on the truck?
  7. Nov 3, 2010 at 4:23 PM
    ghoststoglory
    new lines...drill the banjo bolts...? thoughts?
  8. Nov 3, 2010 at 10:28 PM
    cmf21
    cmf21 Well-Known Member
    Arizona
    04 4x4 dbl cab trd
    I don't remember where I saw it, but if you order the brake lines from wheelersoffroad, they come with the banjo bolt and there is no drilling required.
  9. Nov 4, 2010 at 3:51 AM
    ghoststoglory
    I appreciate it man, thanks. I just found that thread on TTORA last night and ordered the lines right then. $72.50, no mod required, and I can use them with the lift I want...sounds like a win!
  10. Nov 5, 2010 at 5:49 AM
    JDBECK23
    Jesse
    King George, Va
    Ghost, im assuming you ordered the lines for a Tundra? Or just a new set of Tacoma lines from Wheelers?
  11. Nov 5, 2010 at 7:09 AM
    1finetaco
    1finetaco Member
    saw 2.0 coilovers, rear aal, stainless brakelines all around home depot special c.a.i
    To use the stock lines you need to just drill the tip of the bolt out so that it will go all the way in. Its pretty simple there is a write up somewhere with pics. The aftermarket lines are the better choice anyway because you dont have to drill anything and you get a much firmer feel as long as the back line is also a stainless. Just depends if you are doing this upgrade on the cheap or not.
  12. Nov 6, 2010 at 8:25 AM
    ghoststoglory
    I ordered the Tacoma lines. The banjo bolt with those lines will bolt straight up to the caliper according to the two or three people that bought them on TTORA.
    I understand the mod wasn't all that hard, however I didn't want to drill them, nor could I find a thread with pics that were still active, showing how to do it.
  13. Nov 7, 2010 at 4:45 AM
    JDBECK23
    Jesse
    King George, Va
    Im with you on that! I like to have a very good idea of what needs to be done before I start... or at least know that all the parts will fit before I start!
    Can you post some pics of your install when you're done?
  14. Nov 9, 2010 at 6:09 PM
    ghoststoglory
    Sure man, I will. According to UPS my package will arrive tomorrow. I'm off Thursday, so my plan is to get it done tomorrow night. I will post some pics when I'm done.
  15. Jun 17, 2013 at 8:56 AM
    hokiruu
    hokiruu Well-Known Member
    Santa Cruz, CA
    '00 4x4 TRD V6 SR5
    Reviving this old thread. Just to verify: I have braided stainless lines from wheelers on my stock tacoma brakes now. I am putting on Tundra brakes. The banjo bolts i am alreafy using should be ok on the Tundra calipers without being modified?
  16. Jun 19, 2013 at 8:03 AM
    cdj1
    cdj1 Well-Known Member
    Clint
    Vidalia, GA
    97 Tacoma
    King Extended travel coilovers, 5100 Shocks, Daystar shackles,OME Leaf Springs,255/85/16, front diff drop, RAT skid plates, 4.56 gears, LSD in rear, Aussie locker in the front, Front Range Offroad twin sticks, trail gear/ Bash Fab rear bumper, elite off road front bumper and sliders, warn m8000 winch, in cab winch control
    Even if you have to modify them its easy. Just put the bolt head in a vise and use a cordless drill with a 3/8 bit. The metal used for the bolts is soft and the hole in the center acts like a pilot hole to keep you straight. Drill off a couple of threads deep, clean and test fit. I just did the upgrade on my Tacoma last night. I have aftermarket ss lines I bought from 4wheel parts.
  17. Jul 27, 2017 at 6:43 AM
    Thaitoy
    Thaitoy 2003 3.0 turbo diesel. 6in lift w 33's
    2003 taco 3.0 turbo diesel
    6 inch lift. 33in tires 10000lb winch and shocks
    Will factory banjo bolts work
  18. Jul 27, 2017 at 6:46 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    Philadelphia, PA
    99 TRD Prerunner 3RZ
    SAW 2.0 Coilovers Wheeler's 5 Leaf Bilstein 5100s LCE long tube header Flowmaster Delta 50 Muffler FJ Trail Team Wheels 255/85/16 Cooper ST Maxx 4Runner overhead sunglass console RSX Leather Seats All LED lights Red/Clear Tail Light Tundra Brakes Black Headlights and Corners 4Runner Auto Up/Down Windows Bullet Liner Cargo tie down system
    The factory bolts are longer than the ones that come with the wheelers kit. Therefore they will bottom out in the caliper and cause it to leak. You basically need to shorten the bolt, but it needs to keep its concave end. In comes a drill bit, which will shorten the bolt and keep the end concave.
  19. Jul 27, 2017 at 6:49 AM
    Thaitoy
    So factory tundra bolts won't work
  20. Jul 27, 2017 at 6:53 AM
    Dalandser
    Dalandser ¡Me Gustan Las Taco-mas!
    Anthony
    Downey, LB
    Empty Wallet Mod
    Tundra bolts will work with Tundra calipers. Stock Tacoma bolts have to be modified to fit Tundra calipers.
