CONFUSED ABOUT MY 3RD GEN PROBLEMS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JordanDziekan, Feb 21, 2017.
  1. Feb 21, 2017 at 4:43 PM
    JordanDziekan
    JordanDziekan [OP] Well-Known Member
    Jordan
    2017 Tacoma TRD Sport
    Yes, I have posted to this forum several times before about the problems that I experience with my truck. I am sorry if any of you are bothered about my constant posting. However, I am still in need of answers. I have my 5k service tomorrow, and I need some information to "bring with me". I really don't know too much about anything with vehicle mechanics, but I believe I am slowly getting there. This is only my second vehicle as I am only 20 years old, so please work with me.
    I have a 2017 TRD Sport. The truck excels in just about everything, besides driving quality. Which for me, is one of the most important aspects.
    When I first got my truck, I couldn't stop driving it. Well... that was until I started noticing constant transmission hesitation and flaring. So, I took to my local Toyota and they performed the TSB. Basically fixed the flaring and hesitation (I do still experience it from time to time). What the TSB did not fix was another issue I was battling, which is a hard to explain "behavior" of my truck.
    The best way for me to describe my truck "behavior" is a clunk/ jerking forward and backward motion. Sometimes it feels as if I'm harshly hitting the brakes, but I can assure you, this happens even when Im not using the brake. It kind of feels like the body of the truck is not attached to the frame, if that even makes sense. I experience this sometimes with shifting from park to drive and vice versa. But the bulk of this behavior comes with acceleration and deceleration, especially from 2nd gear to 1st gear.
    I have no clue what could be wrong with my truck, I can't imagine this is "normal" for the Tacoma. I used to believe that this was a transmission problem of some sort, low transmission fluid? Also, saw it may be something with lose u-joint bolts? One person mentioned something about a dry I have also read that this is normal behavior, but like I mentioned before... I don't think thats the case. Most recently, I have read and that part of the problem could be something to do with the brakes on the Tacoma. But that can't be the whole problem, due to the fact that this happens when I do not apply the brakes. Someone also mentioned something about a part under lubricated, can't remember what part.
    I have my 5k mile service appointment tomorrow. Need to know, what to tell them... so I don't sound like an idiot and they take me seriously. I need some ideas of what the problem may be so I can inform them. Possibly, some potential solutions. Thanks in advance to anyone who helps,
    EB Group, Toyko Joe, SilverII and 2 others like this.
  2. Feb 21, 2017 at 4:48 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    I would recommend the following:
    1) tell your service advisor you want to test drive a truck from their new lot. See if it exhibits the same problem yours have
    2) take service advisor or tech in your car. When the clunk problem happens point it out in real time so they know what you are talking about
  3. Feb 21, 2017 at 5:00 PM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    Sell it, boys.
  4. Feb 21, 2017 at 5:02 PM
    JordanDziekan
    Jordan
    Me either...
    theguystrong[QUOTED] likes this.
  5. Feb 21, 2017 at 5:03 PM
    JordanDziekan
    Jordan
    I would, but I'm in a lease... going to talk to the dealership about maybe switching lease to Tundra.
  6. Feb 21, 2017 at 5:04 PM
    taczilla
    Marc
    2016 RAM Rebel
    Good plan.
    theguystrong likes this.
  7. Feb 21, 2017 at 5:15 PM
    InfernoTonka
    InfernoTonka Infernal Order of Knights Templar of Inferno-ness
    TOD aka Toyota Onroad Development
    2016 Inferno SAF base model SR5 4x4
    You are approaching this the right way. I'm like you, I don't know a lot of technical jargon but like to learn so I can talk to mechanics on a level where there is no misunderstanding.
    With dealerships, they could play games if they sense someone doesn't know much about cars and they can take advantage of that. I like knowing at least just enough to let them know to not mess around with me.
  8. Feb 21, 2017 at 5:35 PM
    InfernoTonka
    While you are waiting for some responses, definantly do some searches on this and write down all the things that people mentioned in the past.
    Just off the top of my head from reading TW for the past couple of months:
    1. Transmission fluid level for sure.
    2. Differential fluid level.
    3. Ask them if you have grease zerks, if you do make sure they grease those. 2017's may not have these.
    If I can think of anything else I will post more. Maybe someone out there can think of other things. Make a list like you're going to the grocery store. It'll show them you know about the issues. Then make sure all of the stuff you want them to check is somehow documented on your service sheet.
    MadDaddy and JordanDziekan[OP] like this.
  9. Feb 21, 2017 at 5:51 PM
    tcjacado
    tcjacado Well-Known Member
    U bolts along with differential and ATF
    I would also have them do a check on the Trac contol, auto slip differential and vehicle sway control system as these also control braking at certain points. Maybe check the leaf springs for lubrication.
    Hope this helps.
  10. Feb 21, 2017 at 6:01 PM
    TRDinOhio
    TRDinOhio Well-Known Member
    Andrew
    Lima
    16 Trd Pro 4Runner
    No more Turd-gen :)
    Take it in for service and explain yourself until they understand. Take 15 minutes of the advisors time if you need to. YOU are the customer and they are in a CUSTOMER SERVICE job. See what the service dept. has to say. If they fix it then awesome but if they blow you off THEN trade it in.
    tcjacado likes this.
  11. Feb 21, 2017 at 6:22 PM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    Mine bucks/rocks if i release off the gas pedal too quickly or apply the gas too quickly, especially in 2nd gear lower RPM's. I think it is normal for the truck :(, other members have said theirs do the same.
    And i have a manual trans, so no shifting is involved when this happens.
  12. Feb 21, 2017 at 6:46 PM
    avitaco
    avitaco Well-Known Member
    A
    2017 DCSB 4x4
    mine does the aggressive pop from 2nd to 1st in a down shift essp when its cold.... every morning until its at a normal op temps I feel that freaken pop... I hate is and its def not normal
  13. Feb 21, 2017 at 6:50 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Slip yoke...Grease it
    /Thread
    RedBeard1 and TRDinOhio like this.
  14. Feb 21, 2017 at 7:25 PM
    ElGatoLoco
    ElGatoLoco Well-Known Member
    '17 DCSB TRD Sport
    Get rid of it
    laboss3 and Mush Mouse like this.
  15. Feb 21, 2017 at 7:37 PM
    TRDinOhio
    Andrew
    Lima
    16 Trd Pro 4Runner
    No more Turd-gen :)
    I'm on t4r forum and have no issues. You could get a vehicle without defects too...there's always that option :bananadance:
    Riding Dirty likes this.
  16. Feb 21, 2017 at 7:39 PM
    stevebaz
    stevebaz Well-Known Member
    2016 access cab, TRD offroad 4x4, Quicksand
    Ask for the service advisor to take a test drive with you. Its hard to brush off a problem if the truck is kicking you both in the but at the same time. Make sure they note the problem in the service write up. The latest transmission update does help allot from the shifting condition the truck came with. Except with the cold 2nd to 1st down shift clunk.
    Kilokato likes this.
  17. Feb 21, 2017 at 7:41 PM
    TRDinOhio
    Andrew
    Lima
    16 Trd Pro 4Runner
    No more Turd-gen :)
  18. Feb 21, 2017 at 7:43 PM
    TRDinOhio
    Andrew
    Lima
    16 Trd Pro 4Runner
    No more Turd-gen :)
  19. Feb 21, 2017 at 7:49 PM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    Man if I didnt need the truck bed I would so be in a Japanese built 4runner.
    Riding Dirty and imjdoggie like this.
  20. Feb 21, 2017 at 8:18 PM
    Oldman808
    Oldman808 Well-Known Member
    Planet Earth
    2023 Taco TRD Sport
    Sounds like low atf is causing your clunks. If you have the tow package I can almost guarantee your close to a quart low and this will fix that issue. While your there make sure they check your rear diff fluid and make sure those bolts aren't loose. Good luck!
