confused about my lift kit
Discussion in 'Suspension' started by prerunner05, Oct 30, 2009.
  1. Oct 30, 2009 at 6:26 AM
    prerunner05
    prerunner05 [OP] Well-Known Member
    David
    middlesex,va
    05 prerunnerSR5 5spd
    265/65/r17 . fog lights. secondary air filter removal,AFE Pro S dry drop in. double din navigation HU 6.5" componet speakers in the back
    Hey there guys gotta a question for ya. I purchased a 3inch lift kit(spacer and AAL) and when i took it out the box the spacer is only 1.5" tall whats up with that??? how am i supposed to see 3" lift from it?? i just dont understand.
  2. Oct 30, 2009 at 6:28 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    2:1 ratio 1.5" tall spacer = 3" lift
  3. Oct 30, 2009 at 6:47 AM
    TACOFEAVER
    TACOFEAVER Well-Known Member
    Newfoundland, Canada
    09 SR5
    3" lift, and 265 75 R16 Trxus M/T's enroute. (to be installed in about 2 weeks)
    When the spacer is installed, it is "amplified" through the control arms, etc... as said above in a 2:1 ratio.
    My spacer actually measured 1.75" for a 3" lift, and when I measured the difference I did actully have a 3.5" lift.
  4. Oct 30, 2009 at 6:54 AM
    prerunner05
    David
    middlesex,va
    so what is your opinon on the spacer lift any issues??
  5. Oct 30, 2009 at 6:58 AM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    i currently have a top plate spacer and block lift. its a lift, not the best by any means but it will get you 3". expect a rough ride, if you have a block for the rear you'll have some wheel hop. honestly, unless you plan on upgrading lifts in the near future, i would have gotten an ome lift kit.
  6. Oct 30, 2009 at 5:10 PM
    TACOFEAVER
    09 SR5
    I'm happy with it - no issues, no vibes. even at 3.5" the alignment tech at our garage was able to bring the alignment into specs without new CA's... Used the AAL for the rear...
    What kit did you get? from ebay?
  7. Oct 30, 2009 at 7:01 PM
    prerunner05
    David
    middlesex,va
    yep. from ebay. [​IMG] $189.99
    What shocks/struts are you running? stock?
  8. Oct 30, 2009 at 7:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I hate to say this, but your alignment is not in spec with a 3+" lift.
  9. Oct 31, 2009 at 10:16 AM
    TACOFEAVER
    09 SR5
    thats the same lift i'm running - stock shocks for now... but there will be upgrades :D
    My understanding was that I wouldn't be able to... but according to the tech, and the print out - my truck is "within factory specs"
    I dont know what sort of voodoo magic the tech did - but whatever works. The truck tracks fine, doesn't pull, doesn't vibe and chalk test showing tires wearing fine... Shouldn't be possible - but I am not complaining! :D
