Confused about shocks & lift - Need some help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Crash_aka_John, May 23, 2025 at 9:39 AM.
  1. May 23, 2025 at 9:39 AM
    Crash_aka_John
    Crash_aka_John [OP] Member
    Looking
    Thanks in advance for any help offered.
    I do not know my vehicle measurements before allpro expedition springs were added to the truck, so im not sure how to find my lift height in order to select the correct shocks. The info for leaf springs say they add 3" of lift, but I have about 450lbs in the bed normally and I'm guessing its closer to 2" of lift.
    Question 1: How do I get an accurate lift measurement without the initial numbers?
    Question 2: If im at 2"+ of lift, I believe standard billstein 5100s are out of the Question. I had the B110 extended 5100s on there, with sumo springs where the bump stops normally are, but the b110 blew so im thinking it compressed too much. Now im looking at the billstein 5125 and thinking that may be the best choice, so im looking for thoughts on that. I mostly drive florida trails, no real rock crawling so I don't think I need any overly bad ass shocks.
  2. May 23, 2025 at 10:10 AM
    LOLLY
    LOLLY Well-Known Member
    Alfredo
    Norwalk, CA
    '05 Tacoma DCLB TRD Sport (RIP) Now '21 TRD Off-Road
    Measure from shock eyelet to eye at ride height. Then measure from the bump stop to the bump bap. Subtract the bump measurement from the eye to eye measurement. That'll give you your compressed measurement. Then lift the truck by the tow hitch to let the wheels drop out. Measure from shock eye to eye while dropped out. Your compressed and dropped numbers will be the compressed and extended shock lengths that you need to look for when buying new shocks.
    Your previous shocks blew out because either the compressed or extended length didn't match from leafs to shock. Something has to give. It doesn't matter if shocks are "Tacoma specific".
    You can also make the bump stops taller or add limit straps to prevent too much droop to keep them from blowing out again.
    Toy_Runner, BabyBilly and HondaGM like this.
  3. May 23, 2025 at 10:12 AM
    Crash_aka_John
    Looking
    That's extremely helpful. Thank you.
  4. May 23, 2025 at 10:14 AM
    LOLLY
    Alfredo
    Norwalk, CA
    When you droop it out make sure to unbolt the shock. That way you can see where the leaf limits out when it droops.
    Toy_Runner and HondaGM like this.
  5. May 23, 2025 at 10:18 AM
    Crash_aka_John
    Looking
    Ok, so you're making sure the shock is removed so the shock itself isn't limiting the droop or compression during measurement and causing you to end up measuring for a new shock that will inevitably blow out because it became the limiting factor. Makes sense if in understanding that correctly.
    BabyBilly likes this.
  6. May 23, 2025 at 10:24 AM
    LOLLY
    Alfredo
    Norwalk, CA
    That is correct
  7. May 23, 2025 at 10:31 AM
    Crash_aka_John
    Looking
    I appreciate the education on the topic.
  8. May 23, 2025 at 10:32 AM
    LOLLY
    Alfredo
    Norwalk, CA
    No problem. I went down the deep rabbit hole not too long ago.
  9. May 23, 2025 at 11:31 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    This is very misleading. Any OEM replacement shock will work fine for the OP. His lift only affects the position of the shock at rest.
  10. May 23, 2025 at 11:34 AM
    gudujarlson
    Minnesota
    Springs do not limit up or down travel. Up travel is limited by the bump stop and down travel is limited by the shock.
    Intuitively, a spring cannot limit up or down travel because it is springy. It bends.
  11. May 23, 2025 at 12:51 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Here's a great quote from member Ryan
  12. May 23, 2025 at 8:39 PM
    LOLLY
    Alfredo
    Norwalk, CA
    So you're saying that if you catch flight that the internals of the shock should stop the weight of the axle and tires? Ok
  13. May 23, 2025 at 8:59 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    They would, right up until the moment they didn't.
    LOLLY likes this.
  14. May 24, 2025 at 6:09 AM
    gudujarlson
    Minnesota
    Also note that all of the OEM replacement shocks have approximately the same collapsed and extended length. They are interchangeable with themselves and the stock shocks.
