confused about tpms from a steel wheel into an alloy
Discussion in 'Wheels & Tires' started by daggertats, Nov 10, 2010.
  1. Nov 10, 2010 at 3:26 PM
    daggertats
    daggertats [OP] Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    my truck is a 2010 regular cab 4x4 with the 16 inch steel wheels. ive been lookin at alloys on line and in person at a few places. i was at discount tire last weekend and the guy there said the original tpms would work in the alloys however when i went online to tire rack and clicked on important nots it says only the factory alloy tpms will work in an aftermarket alloy. it says the steel are not compatable. any info on this would help me a great deal. thanks in advance
  2. Nov 11, 2010 at 1:53 AM
    daggertats
    arden nc
    anyone else have any answers?
  3. Nov 11, 2010 at 4:47 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    http://www.revolutionsupply.com/strapkit.aspx
    Here's an option for you. A few members here have this kit and seem to like it. It allows you to keep the TPMS sensor function but use standard valve stems.
    Otherwise, I was told the same thing Whippersnapper mentioned. The steel and alloy sensors are different and not be interchanged. Something about the angle they sit in the wheel I believe.
  4. Nov 11, 2010 at 7:32 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    I have been running a similar kit for 20,000 miles with no issues.
  5. Nov 11, 2010 at 2:02 PM
    daggertats
    arden nc
    thanks everyone :)
  6. Dec 26, 2010 at 12:12 PM
    Archangel
    Archangel Discount Tire Company
    Charlotte, NC
    13 Malibu LT
    Um... it's the same TPMS sensor. You need a new kit to rebuild it (rubber grommet, retaining nut, valve core, and cap), but you can use your sensor from steelies to aftermarket alloys without any problems.
  7. Dec 26, 2010 at 1:27 PM
    KPT
    09 Prerunner
    It is not the same sensor. The toyota steel wheel sensors have a 40 degree mounting angle and the toyota alloy sensors have a 20 degree mounting angle.
    Most aftermarket rims have a 20 degree mounting angle.
    Some have reported that tire shops got their steel sensors to fit in the alloys by turning them upside down. Others have used TPMS straps.
  8. Dec 26, 2010 at 2:13 PM
    RLDTACO
    RLDTACO Well-Known Member
    Bob
    Houston Tx.
    2010 DCLB PreRunner SR5
    Debadged,Tailgate theft mod,Extra D-rings,OEM bed mat,TRD exhaust, 5100 Billys@ 4 corners set@ 0 with Eibach springs, rear TSB springs.N-Fab tube Steps. TRD FJ SE wheels and Michelin LTX A/T 2's
    I just had new tires mounted on TRD FJ SE wheels. Discount Tire used the TPSM from my steel wheels, no problems that I could see. They rotated sensors 180 degrees. Clears the machine used to mount and break down the tire from rim. They wanted $50.00 more to use staps, but had to order the brackets that hold sensors to the bands. They made a note of how the sensors were mounted and everything seems to be fine.
  9. Aug 28, 2011 at 9:43 AM
    Hayes
    Hayes Well-Known Member
    Brandon
    Denver, CO
    2011 Regular Cab Tacoma 4x4
    I have mounted steelie tpms in allloy wheels with not problems, just need the rebuild kit for alloy wheels. There may be a difference with the sensors, but your tpms will work.
