Confused about upstream o2 sensor
Discussion in '1st Gen. Tacomas (1995-2004)' started by Freki, Sep 24, 2014.
  1. Sep 24, 2014 at 7:06 AM
    Freki
    Freki [OP] Well-Known Member
    NY
    99 4 banger
    I have a 99 4 cyl 2.7 2wd.
    I replaced both o2 sensors a couple months ago. With non OEM parts.
    I have now been throwing all sorts of codes indicating that my truck does not like the upstream sensor.
    I am having trouble figuring out what/where to buy .
    Rock auto, which is where I usually buy everything, does not have a Denso upstream.
    I've found it on some sites being called the air fuel ratio sensor but not for the 2.7.
    I've found sites that have it, but there seem to be a few different versions as they're priced differently even though they appear to be the same.
    Not sure why I'm struggling with this but I want to make sure I buy the right thing because a) it's $150-$200 which is a lot and b) I don't want to destroy my truck.
    Thanks for any help. It's always appreciated.
  2. Sep 24, 2014 at 7:21 AM
    Madjik_Man
    Colorado Front Range
    Not exactly sure this will help but rockauto has the Denso upstream sensor for my 3.4.
    You sure they don't have it for the 2.7?
  3. Sep 24, 2014 at 9:12 AM
    wcp0611
    wcp0611 Well-Known Member
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    Grey wire and keyless entry. I like stock.
    Yeah, its an air fuel sensor. It reads and the ECM adjust the truck accordingly. The rear O2 just tells the truck the cat is working.
    Denso part# 234-4162 is what you want. Search on RockAuto. They have it.
  4. Sep 24, 2014 at 10:45 AM
    Freki
    NY
    99 4 banger
    DENSO Part # 2344162 {Click Info Link for Alternate/OEM Part Numbers} OE Style; Includes Gasket [​IMG]
    UPSTREAM
    Downstream; 4WD; Standard trans.
    Says upstream and downstream. Description most have thrown me off. Oh well...I just ordered it.
    Thanks a lot. Tacoma World never fails.
  5. Sep 24, 2014 at 2:35 PM
    Madjik_Man
    Yeah I saw that.
    That seems to be the upstream one. My only question is: Is there any difference between 4WD and 2WD models for O2 sensors?
  6. Sep 24, 2014 at 3:59 PM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    I know that Toyotas seem not to like Bosch parts. What brand did you get?
  7. Sep 24, 2014 at 5:12 PM
    Madjik_Man
  8. Sep 25, 2014 at 3:44 AM
    Freki
    NY
    99 4 banger
    Yea I'm not sure. I know my boss' 4x4 RAM has o2 sensors all over the place. I think 4 or 5 total.
  9. Sep 25, 2014 at 3:45 AM
    Freki
    NY
    99 4 banger
    Originally I bought APWI Part # AP443. I tried to cheap out. Bad call.
