Confused-Blisten 5100's
Discussion in 'Suspension' started by ZachMX, Oct 24, 2012.
  1. Oct 24, 2012 at 5:39 PM
    ZachMX
    ZachMX [OP] Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    So I just want to clarify, I can simply level my 4WD Sr5 (2011)by adding the blisten 5100's up front set at 1.75 and no need for new coils or an aal? Thanks! Zach
  2. Oct 24, 2012 at 5:40 PM
    darkgohan
    darkgohan Well-Known Member
    Thats what I did,worked great!!
  3. Oct 24, 2012 at 5:41 PM
    Bloodhound
    Bloodhound Space For Rent
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    Yes, you'll be re-using the front springs and all hardware.
  4. Oct 24, 2012 at 5:42 PM
    ZachMX
    Great, did you guys have someone install or yourself? I have access to a spring/coil compresser thing at the autohobby shop. Blisten's ordered!
  5. Oct 24, 2012 at 5:45 PM
    1stacoma
    1stacoma Well-Known Member
    Austin
    2012 MGM SR5 DCSB 4.0
    5100's front and rear, front 2.5" rear 2" AAL, 18% tint front and rear, color matched grill. SCS wheels 275/70/17 BFG AT KO's. DTRL toggle switch.
    If you have a 3 leaf pack the front will probably be higher. If you have a 4 it will probably be level.
  6. Oct 24, 2012 at 5:47 PM
    ZachMX
    I only have a 3 leaf pack, warranty was just up when I bought her. So maybe .85 setting instead?
  7. Oct 24, 2012 at 5:48 PM
    darkgohan
    Had mine installed!!
  8. Oct 24, 2012 at 5:48 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I would use the .85 setting.
  9. Oct 24, 2012 at 5:50 PM
    AcadianTaco
    AcadianTaco Well-Known Member
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
    OME 885X with Bilstein 5100, Dakars with 5125, Wheeler's bumpstops, LR UCA
  10. Oct 24, 2012 at 5:50 PM
    1stacoma
    Austin
    My experience is that what it says is vary accurate I put mine at 2.5" and I got 2.5". The lower you put the 5100 the better your ride will be. Being at 2.5" my ride is rather harsh. Measure your front center hub to bottom fender and the rear and see what the difference is. It will give you an idea of how much to lift.
  11. Oct 24, 2012 at 5:53 PM
    darkgohan
    I used 1.75 looks good. Did the same on my last 2010 Tacoma.
  12. Oct 24, 2012 at 5:57 PM
    ZachMX
    Thanks for all the help guys. Gonna try 1.75, will see with my bike loaded in the back how much the nose goes up. might have to do .85 for some rake.
  13. Oct 24, 2012 at 6:55 PM
    Drewbiestaco
    Drewbiestaco Well-Known Member
    Dickinson, Texas
    2012 D/C 4x4 TRD Off Road Magnetic Grey
    what size tires can you run if you level the truck with the 5100's?
  14. Oct 24, 2012 at 7:03 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    Wyoming
    2012 TRD Off Road Double Cab V6 6Speed
    265/75r16 or 265/70r17 for a leveled stock taco is pretty good.
  15. Oct 24, 2012 at 7:05 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    265/75/16
  16. Oct 25, 2012 at 10:44 AM
    masshole taco
    masshole taco Well-Known Member
    Big Daddy
    Massachusetts
    2011 Tacoma Sport
    Fox 2.5 C/O's Fox 2.0 rear shocks Total Chaos UCA Trifecta Tonneau Cover K&N FIPK Sirius Satellite Radio Toyota OEM roof rack Wet Okole Seat Covers Homer Taco Custom Grill w/ M1 Mesh and Toyota Emblem
    set it at 1.75 and buy an AAL problem solved.
  17. Oct 25, 2012 at 11:49 AM
    ZachMX
    Was hoping to keep cost down, I know I can AAL but rather not if I dont have to. I only haul my dirtbike so no heavy loads.
  18. Oct 25, 2012 at 12:58 PM
    SconnieHailer
    Marc
    Wyoming
    This is my truck with 265/75r16. See sig for suspension mods. These tires fit perfect under stock suspension also. Is your rear end 2 leafs and an overload or 3 leafs and an overload? If you have 3 leafs total including the overload you will sit perfectly level with the 5100 at .85 ( my truck was set there for a while). If you have 4 leafs total with the overload you may sit level at 1.75 setting...
    ~M
  19. Oct 25, 2012 at 12:59 PM
    Large
    Large Red
    Beautiful truck you have there.
  20. Oct 25, 2012 at 1:21 PM
    SconnieHailer
    Marc
    Wyoming
    Thank you, same to you. Enjoyed your build thread :) nice wheeling shots!
    ~M
