CONFUSED? DPST
Discussion in 'Technical Chat' started by smurf taco, Dec 30, 2012.
  1. Dec 30, 2012 at 9:38 PM
    smurf taco
    smurf taco [OP] Well-Known Member
    Brian
    Hobe Sound, Fl
    speedway blue 09 prerunner sport 2wd
    brite ass led headlights and fogs, fuel hostage wheels, mellow tone dual exhaust, black westin bull bar, go rhino nerf bars, toyota neoprene black and blue seat covers, image dynamics door speakers all around, Bilsteins 5100s all around set at 0 with maxtrac spindles and eibach coils and total chaos UCAs with OCtaco brakelines all around and all pro expo leafs in the rear running 295/70/17 cooper ST Maxx, cobra cb radio w/ 3ft fire stik, bed lights, jvc double din head unit, AC in cab mod, AFE CAI...more mods to come
    im gonna do the bed light mod and i bought a switch for it and im used to switches with 3 prongs on it but the switch i bought has 4 prongs and ive never worked with them before. ive been doing some searching about them and its a double pole single throw switch. if someone can help me figure out which prong goes to the battery and which one gets grounded and which one goes to the lights and so forth. also does it mean i can have 2 switches do the same thing? such as a switch in the bed and a switch in the cab maybe? thanks for helping
  2. Dec 31, 2012 at 6:37 AM
    aw113sgte
    aw113sgte Well-Known Member
    That is not a DPST unless it is a lighted switch. The switch should have a diagram on the side of came with a paper showing the connections.
  3. Dec 31, 2012 at 6:56 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Why does it look like everything on that switch is metal? If it is, I'd chuck it.
    A switch doesn't care what the polarity is, all it does is close a circuit. That being said, I could pretty confidently say that the bar down the middle is seperating the sides of the switch. Dual pole means two sets of contactors, so as long as you put a wire on one side and the other directly across from that same terminal, you'll be fine. If you wire it wrong, that just means whatever you are controlling will remain on without effect from the switch, OR you won't be able to turn it on, you wont hurt anything unless you touch a positive wire to the chassis.
    Also, aw113sgte, why do you say its not a DP? It has 2 sets of contactors.... only thing is it could be a DPDT, but I can't see the other side.
  4. Dec 31, 2012 at 7:23 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    I would verify with a continuity test.
  5. Dec 31, 2012 at 9:14 AM
    smurf taco
    Brian
    Hobe Sound, Fl
    so i have to put one red wire (to the battery) and one red wire (to the lights) directly across from each other and then just ground a wire on a pole below one of the two?
  6. Dec 31, 2012 at 9:23 AM
    98tacoma27
    Ben
    Not Beech Creek
    That's a DPST switch. A DPDT switch would have six prongs. It doesn't matter which side goes to the battery but you should keep it uniform and have the battery on either the top two or bottom two poles.
  7. Dec 31, 2012 at 11:27 AM
    smurf taco
    Brian
    Hobe Sound, Fl
    so i have to have 2 wires going to the battery? im so confused :frusty:
  8. Dec 31, 2012 at 11:33 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    It basically is two on off switches side by side. They are independent of each other.
  9. Dec 31, 2012 at 1:10 PM
    98tacoma27
    Ben
    Not Beech Creek
    Can't be explained any better than this. VVVV
    +1
  10. Dec 31, 2012 at 2:30 PM
    smurf taco
    Brian
    Hobe Sound, Fl
    thanks so much that helps a lot
  11. Dec 31, 2012 at 4:10 PM
    smurf taco
    Brian
    Hobe Sound, Fl
    well i wired exactly how it is on the first diagram and it wont turn on....idk where i went wrong
  12. Dec 31, 2012 at 5:42 PM
    brian
    Elizabeth City, NC
    Think of electricity as nothing more than plumbing. Its quite simple :)
  13. Dec 31, 2012 at 9:32 PM
    smurf taco
    Brian
    Hobe Sound, Fl
    yea im not using LEDS. im gonna run through everything and make sure my grounds are good. thanks for the help guys im sure ill figure this out sooner or later lol
  14. Dec 31, 2012 at 10:40 PM
    smurf taco
    Brian
    Hobe Sound, Fl
    since im the kind of person who doesnt sleep until the jobs done i finally got it all figured out and it looks awesome! thanks for everything guys really appreciate it :)
  15. Jan 1, 2013 at 5:19 AM
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Ben, good diagram to explain the possible combinations of a DPST switch. Thanks for posting it.
  16. Jan 1, 2013 at 11:02 AM
    smurf taco
    Brian
    Hobe Sound, Fl
    it was simple. my ground from the lights came loose :facepalm: ill put pics on tonight when its dark
  17. Jan 2, 2013 at 5:32 AM
    98tacoma27
    Ben
    Not Beech Creek
    X2...wasn't me. :eek:
  18. Jan 2, 2013 at 5:44 AM
    smurf taco
    Brian
    Hobe Sound, Fl
    this is with only one light in....putting in the second one in a few days
