Confused!!! Ground plane/ No Gound plane C.B. antenna
Discussion in '3rd Gen. Tacomas (2016-2023)' started by icelandcowboy, Jun 11, 2020.
  1. Jun 11, 2020 at 9:02 AM
    icelandcowboy
    icelandcowboy [OP] 2019 TRD Off Road
    Rich
    Chula Vista, CA
    2019 Tacoma Off Road 4x4 Color Cement
    Winch, Warm Zeon 10,000, Body Armor Front Bumper, TJM Rear Bumper, SPOD, TRD Grill w/Grill lights, Bilstein Shocks Front 6112 (upgraded springs for winch and bumper weight) Rear 5160, Firestone Air Bags, 20' Baja Designs Light Bar (Front Bumper) ,Ditch Lights, Baja Designs Fog Lights, Prinus Cab Rack, Leitner Designs Bed Rack W/Pods, ARB Dual Air Compressor (in engine bay), Cobra C.B. w/Predator 10,000K Antenna, TRD Skid Plate, TRD Cold Air Intake, TRD Cat Back Exhaust System, Rago Back Window Molle Panel, Rago Transmission Hump Molle Panel, Decked System (in truck bed), Camburg UCA, TRD Rims w/265/70R17 Goodyear T/A KO2 Tires, Power Accessory Mount 3TPAM,
    Looking to get the Cali Raised CB bracket for tail gate application. Using Firestik FSii 4'. My question is: ground plane or no ground plane. Not sure what all that means...Help please:confused:
  2. Jun 11, 2020 at 9:16 AM
    rtadams89
    rtadams89 Well-Known Member
    Phoenix, AZ
    2017 Tacoma Limited
    This just refers to if you have a ground plane (using the vehicle's metal body as the ground plane) or not. If you are installing in the rear corner of a mostly composite bed, you are probably better off going with a "no ground plane" setup in my option.
    disconnected likes this.
  3. Jun 11, 2020 at 9:17 AM
    jschwerdtfeger
    jschwerdtfeger Well-Known Member
    Jeff
    Santa Cruz, CA
    2020 Tacoma DLCB TRD Off Road
    Fox 2.5/2.0, Deaver Expo Stage I
    There's not enough metal back there for a good ground plane, so most likely, your SWR is going to be high, and all you'll hear is static. The only good place for a CB antenna on a Tacoma is right in the middle of the roof (as long as you don't have a moonroof). You might have slightly better luck using a hood ditch light bracket and mounting the whip up front. FFIW, most people use two-ways these days since the FFC now allows 2 watt units. If this kind of stuff is interesting for you, I'd hop on Youtube and look up basic CB theory and how SWR / ground planes work!
  4. Jun 11, 2020 at 9:19 AM
    jschwerdtfeger
    Jeff
    Santa Cruz, CA
    I tried a NGP setup off a rear tire on a swingout, and there was still too much metal in the bumper/body for that to work.
  5. Jun 11, 2020 at 9:24 AM
    rtadams89
    Phoenix, AZ
    2017 Tacoma Limited
    Were you using a NGP coax cable and appropriate mount? A NGP antenna should have worked fine in the setup you described.
  6. Jun 11, 2020 at 9:26 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    FS4ii requires ground plane. If you don't/ can't have a ground plane you need a "no ground plane" antenna:
    https://www.amazon.com/FireStik-FG4648-B-No-ground-plane-antenna/dp/B000X3EOPG
    Ground plane is essentially the other "half" of the antenna. The NGP antennas basically cancel out the reaction with capacitance/reactance to make your radio think the other half is there.
    That said, short, loaded antennas suck for HF. A 102" whip on a ground plane will work much better. Physics and laws of EM radiation cannot be magically skirted.....
    jschwerdtfeger likes this.
  7. Jun 11, 2020 at 9:30 AM
    jschwerdtfeger
    Jeff
    Santa Cruz, CA
    Yup, couldn't get the SWR lower than like ≈2.25, but who knows, I only tried tuning/troubleshooting that setup for a day or so. I've been running CBs since the 90s, but just use two-way these days. I do miss listening in on the interstate though.
    MOC221_ likes this.
  8. Jun 11, 2020 at 11:27 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    While all this talk about having a ground plane is correct, and it does make for a better antenna, if you don't want one, just build it for no ground plane. It'll still work fine, it's not the best set up for radio performance, but it's not like it won't work. I wouldn't overthink it.
