Confused...Toyota used more than one valve cover for the 2.7's?
Discussion in '1st Gen. Tacomas (1995-2004)' started by BajaJohn8485, Jun 20, 2019.
  1. Jun 24, 2019 at 8:57 AM
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    I cannot speak to the differences in engines. I'm pretty sure the blocks themselves are exactly the same but some of the bolt on items, like valve cover, intake, etc might be different. I believe the ECUs might be different too because of the more stringent emissions standards. That's a tough one though.
  2. Jun 24, 2019 at 9:08 AM
    tony2018
    tony2018 Well-Known Member
    There's a 2.4 and a 2.7. Might be a difference there.
  3. Jun 24, 2019 at 9:28 AM
    98tacoma27
    Ben
    Not Beech Creek
    Did you check if it were Cali speced or not?
  4. Jun 24, 2019 at 10:41 AM
    2JHilux
    2JHilux Level 8 Tinkerer
    Denver, CO
    2001 Tacoma Double Cab 4x4
    manual swap in progress
    It sort of depends on what ecu and harness you are using also. If everything is from the donor engine, then use the donor coils. If you are using your old harness and ecu, then use the old coils. I wouldn't mix and match cause one has 2 coils in wasted spark and one has 4 coils. You don't want to have to deal with mix and matching.
    If you are using all your old harness and ecu, then try sticking your old coil in the new engine/cover. If it fits you're good to go generally speaking. I don't have a 4 cyl motor to test it for you. Usually Cali spec engines have an extra vsv or so and maybe an extra o2 but it should work for the most part with your old ecu/harness.
