Confused with lift kits... 2017 Tacoma - is there a one-stop solution?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LemmyRat, May 8, 2018.
  1. May 8, 2018 at 7:16 AM
    LemmyRat
    LemmyRat [OP] Member
    Looking to level the truck, and add 2-3 inches of lift (so perhaps a 2" front and 1" rear" - or thereabouts).
    Is there a "kit" I could order, that is recommended? I have zero confidence in my ability to adequately research the millions of recommendations through the threads. My mechanical inclination and understanding is nearly nil.
    Is there a "kit" on Amazon or elsewhere that someone could point me to? I'd have a shop install... looking to keep less than $500-600 if possible.
    I have spent hours researching, and feel just as lost as when I started - all I know is that I likely don't want a simple spacer/block set.
    Thanks, Ken
  2. May 8, 2018 at 7:26 AM
    phsycle
    phsycle Well-Known Member
    CA
    You're not getting a proper non-spacer lift for $5-600, especially with a shop install. Eat top ramen and save up. OME, Icon, etc. lift by themselves is $1,200. That's without install. Budget at least $2k if you're having a shop do it.
    Buy once, cry once.
    jeremy5000, hiPSI and arnette64 like this.
  3. May 8, 2018 at 7:28 AM
    arnette64
    arnette64 Well-Known Member
    Amos, QC (Canada)
    2016 Inferno TRD Sport Double Cab 4X4
    '16 Inferno TRD sport DC
  4. May 8, 2018 at 7:28 AM
    UP2SKI
    UP2SKI Well-Known Member
    Alpine White 2017 DCSB Tacoma TRD OR
    If you’re not installing yourself then I’d recommend buying through a local offroad/4x4 shop and having them install. Keeps the conversation easier if they make a mistake and can’t blame you for bringing your own parts.
    Can’t go wrong with an Old Man Emu kit or Bilstein 6112 up front and OME Dakar’s our back.
  5. May 8, 2018 at 7:30 AM
    Jumpman23
    Jumpman23 Well-Known Member
    Juan
    Houston, Texas
    2017 DCSB TRD Off Road 4x4
  6. May 8, 2018 at 7:30 AM
    LemmyRat
    Thanks for the replies... I was budgeting $500-600 for the kit alone, and then another $500-600 for the install (trying to keep total around $1000)...
  7. May 8, 2018 at 7:33 AM
    jeremy5000
    jeremy5000 Well-Known Member
    Philadelphia
    If the thought of researching a lift on your own is that much out of the question, go to a local shop and have them buy you a lift they recommend and have them install it.
  8. May 8, 2018 at 7:33 AM
    UP2SKI
    That’s probably not going to be enough.
  9. May 8, 2018 at 7:44 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Not gonna happen unless you go with spacers. $2K is more realistic man.
  10. May 8, 2018 at 7:45 AM
    LemmyRat
    Yeah - this is becoming apparent. Thanks.
  11. May 8, 2018 at 9:49 AM
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    Depends on what you want to do.
    You can get 2" of lift out of 5100's up front and do a small spacer in the back and add 5100's. I believe 5100's all around cost $350 and not sure on a 1" spacer out back.
    People bark about spacer lifts because there are guys who run 3+ inch spacer lifts on stock shocks and they get over extended and damage stuff.
    If you are just needing more clearance for mild trails and run slightly bigger tires, mild spacer lifts are fine especially if you're upgrading to 5100's or better.
    Most folks on here are hardcore or mall hardcore. So take what suggestions you get with a grain of salt. Including mine. :D
    tomgru, rlx02 and LemmyRat[OP] like this.
  12. May 8, 2018 at 10:36 AM
    TBV
    TBV Well-Known Member
    Oakland CA
    2017 TRDOR 6MT
    Believe it or not there are kind souls here on TW that will help you with your install for beer/burgers/laffs... Ya might make a wheelin' bud too. Hit up your regional forum and see.
    LemmyRat[QUOTED][OP] likes this.
  13. May 8, 2018 at 10:42 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    If you're not doing the install yourself budget $125 - 250 per corner depending on labor rates in your area
  14. May 8, 2018 at 12:05 PM
    gitacotrd
    gitacotrd Well-Known Member
    Marc
    Texas
    2018 Cement TRD offroad
    Avid lightbar, Eibach 2in lift, various TRD parts
    in the same boat (but willing to spend more) looking at Dobinson's right now. shit looks legit. kit is complete. no Frankenstein between shock and spring brands and what not. I like the teraflex setup as well... but they don't seem to have springs (coil or leaf)
  15. May 8, 2018 at 1:58 PM
    Phich
    Phich Porkchop Express
    San Antonio
    2017 TRD Off Road tuned to KDMax perfection
    Six Demon Bag
    Bilstein 5100's all around, front shocks set at next highest from the top, and add OME dakars in the back. $800. Rides like a champ. Install will be free when you look on local FB pages for tacoma fan club type things, join the group and ask for help for the install. Any number pf people will help you out. I would if you lived near me. People love turning wrenches! Pretty easy install actually.
    Just my 2 cents.
  16. May 8, 2018 at 2:03 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    As mush as I like mine, dont set 5100’s all the way up on stock springs, Bilstein doesnt recommend it either. 3rd click up works great, even off-road.
    The best answers so far were to also check with @HeadStrong Off-Road
  17. May 8, 2018 at 2:12 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Bilstein 5100s. No need for better shocks if you just want to mall crawl or go on fire service roads.
