confused
Discussion in '1st Gen. Tacomas (1995-2004)' started by radcat692000, Dec 1, 2011.
  1. Dec 1, 2011 at 5:49 PM
    radcat692000
    radcat692000 [OP] Well-Known Member
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    if i wanted a budget 3" suspension lift ,could i get some 5100's with either ome 881's or eibach coils and get the 3" i needed up front?? or would i also have to add a spacer to achieve this?? i have a 95 king cab v6 4x4 tacoma.
  2. Dec 2, 2011 at 8:12 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Eibachs give a little over 3'' actually. Do some searching man. There is a TON of info on this site about this. 881s only give about 2.5
  3. Dec 2, 2011 at 9:32 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    what he said.
    If you want 3 inches you will need to run Eibach/5100's or an adjustable coilover. I dont think OME makes any kit for 3''+ without running some type of spacer.
  4. Dec 2, 2011 at 9:54 AM
    radcat692000
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    thanks for the input, i have read but there are conflicting statements up here also,,, the sticky says not recommended to run aftermarket coils,,yets others do... you would think if the sticky is wrong it would be corrected...otherwise why make it a sticky..???
  5. Dec 2, 2011 at 9:56 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    the sticky is talking about using the adjustable coil perch set at anything but 0 on the 5100's with aftermarket coils.
    so if you use a coil to lift the truck, set the 5100's to "stock" height and let the coils do the lifting.
    otherwise, you can change the position of the coil perch on the 5100's with STOCK coils, and let the 5100 do the lifting.
  6. Dec 2, 2011 at 10:35 AM
    radcat692000
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    ahhh,,,thats where i was confused at.... so on the 5100's it will have 3 adjustments for the perch correct? and since i'm planning on eibach coils just set the perch on the shock to 0 or what to get 3"?
  7. Dec 2, 2011 at 10:37 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    set it to stock "0", the lowest setting, and have the eibachs do the lifting.
    you'll get a little more than 3". I got around 3.3-4, other members like Jlee got 3.5
  8. Dec 2, 2011 at 4:30 PM
    radcat692000
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    another question and i should have it...do i need front and rear longer brake lines? or just rear?
  9. Dec 2, 2011 at 8:48 PM
    TacoMX
    Jonathan
    Deltona, Florida
    I have heard of people using longer rear lines, but not front lines unless yours are worn and dried out/cracked.
    I have seen many people on here that never used longer brake lines and never has a problem.
    I know backdawg on here has almost 4'' of lift in the rear and is on stock brake lines.
    so, IMO, do the lift and if you feel that you need them, get them.
  10. Dec 3, 2011 at 10:41 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No our fronts are fine, But you should get the rear one.
    I had like 4-4.5'' of rear lift and ran on the stock line for just street driving and was fine. But i put in a longer steel line before i went on my WY meet trip. Definitely would NOT have wheeled without having that installed.
    So i would plan on getting the rear line especially if you have 3'' or more in the back of lift and your offroad a lot. You just mall crawl, don't worry about it.
