Congress to hold hearings on Toyota recalls in Feb. 25
Discussion in 'General Automotive' started by epa4wd, Jan 29, 2010.
  1. Jan 29, 2010 at 8:33 AM
    epa4wd
    epa4wd [OP] Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    http://www.egmcartech.com/2010/01/28/congress-to-hold-hearings-on-toyota-recalls-in-feb-25/
  2. Jan 29, 2010 at 8:36 AM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    I say as long as Toyota is working on it, they should keeps thier noses out of it.
  3. Jan 29, 2010 at 8:40 AM
    98tacoma27
    Ben
    Not Beech Creek
    ^^ Agreed
  4. Jan 29, 2010 at 8:44 AM
    Banchi94
    Banchi94 Well-Known Member
    Ron
    Parker, CO
    2008 Indigo Blue TRD Sport DCSB 4x4
    ToyTec 3" basic lift
    ^^ X2 on that! Seriously, Toyota was one of the only companies that didn't need a bailout and they're the ones who took initiative to fix things. Let them do their job!
  5. Jan 29, 2010 at 8:46 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I actually think this Recal shit could be a good thing for Toyota. In the last few years, their reliability rattings have been dropping. THIS may force them to step it up, and get back on track.
  6. Jan 29, 2010 at 8:54 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    X2!
  7. Jan 29, 2010 at 8:54 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I believe the National Highway Traffic Administration might have helped them take the initiative...
  8. Jan 29, 2010 at 8:57 AM
    Banchi94
    Ron
    Parker, CO
    Ah! I guess it isn't a bad thing when safety is involved.
  9. Jan 29, 2010 at 8:58 AM
    itsmyturn
    itsmyturn Well-Known Member
    Victorville, CA
    08 dbl cab TRD sport
    afe Pro-Dry S dropin, Readylift leveling kit, TRD skid plate, Alpine CDA-9887, 6K D2S HID
    i still don't think accelerator pedals are the fix. i believe the problem still lies in software.
  10. Jan 29, 2010 at 8:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I agree.
  11. Jan 29, 2010 at 8:59 AM
    dk6487
    dk6487 NorCal Member
    David
    Novato, CA
    08 Silver 4X4 TRD Sport w/ Tow Pack
    Pioneer Z110BT Nav/DVD H.U., Sub Box by Mr. Marv w/ amp and 10" Sub, Rear-Leaf TSB, L.E.D. Guage Mod, 3" OME Lift Kit w/ 885, Total Chaos UCA's
    X3! Toyota seems to be doing everything they can to fix the problem. I believe that more of the blame should go to the part maker rather than Toyota.
  12. Jan 29, 2010 at 9:00 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, but the part maker makes the part to Toyota's spec and design.
  13. Jan 29, 2010 at 9:02 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    Better than hearings on a college football playoff.
  14. Jan 29, 2010 at 9:02 AM
    Tex4141
    Tex4141 Well-Known Member
    Clint
    Lemoore
    05 PreRunner TRD Sport
    None yet......trying to figure out where to start ;)
    Agree... all the way around. What erks me... is that Congress thinks they need to step in and hold Toyota's hand. Trust me.....they've got it. As was said before... they didn't need a bailout. Why? Because they produce a superior product. Second.....has it been that long since the frame rust issue? Yes... it happened. As has happened to half a dozen other car manufacturers. It happens, manufacturing and design is not flawless. BUT.... Toyota stepped up and fixed it, and made SURE their customers were happy. They will do exactly the same thing with the "accelerator malfunction" issue. Just let them do their job and stip trying to micromanage every little thing... gah....Ok, I'll get off my soapbox now :D
  15. Jan 29, 2010 at 9:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This is nothing new, as far as congress getting involved with an auto manufacture. Back in the "Old days", Ford had an issue in which the Ford Pinto (im dating myself) would burst into flames for no reason. Congress got involved. They have gotten involved in other cases since then. Anytime a vehicle causes a certain amount of propperty damage, injuries, or deaths, they investigate.
  16. Jan 29, 2010 at 11:20 AM
    epa4wd
    Eduardo
    2019 SR
    Then why is the problem only with one of the two distributors if both make the part to Toyota's specs? :confused: If what you say is true, shouldn't both of them have issues?
  17. Jan 29, 2010 at 11:26 AM
    98tacoma27
    Ben
    Not Beech Creek
    Different designs. Ford is issuing a recall for some commercial vehicles
  18. Jan 29, 2010 at 11:27 AM
    Liam1234
    Liam1234 Well-Known Member
    Massachusetts
    2021 DC, LB, TRD Sport, 4x4, Magnetic Grey, leather sunroof.
    The words "Congress to hold hearings" send chills up my spine.
    Too bad for Toyota as they will now have to take time out of fixing the problem and dealing with people that are only in this for the soundbite.
  19. Jan 29, 2010 at 11:30 AM
    epa4wd
    Eduardo
    2019 SR
    exactly! Yeah I heard about ford, do you have a link for the news, I only heard a brief comment last night on the news, searched on the internet and didn't find anything.
  20. Jan 29, 2010 at 11:31 AM
    98tacoma27
    Ben
    Not Beech Creek
