Connecting lights to battery
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Breaky0self, Feb 27, 2018.
  1. Feb 27, 2018 at 11:23 PM
    Breaky0self
    Breaky0self [OP] Well-Known Member
    Jupiter fl
    2011 Trd Sport metallic grey 2wd
    Im about to add 4 lights to my truck, do i need to add anything to the battery to connect all of them, like a terminal multiplier or something?
  2. Feb 27, 2018 at 11:27 PM
    cesar_taco
    cesar_taco Well-Known Member
    Cesar
    2017 DCSB Off-Road Taco
  3. Feb 27, 2018 at 11:36 PM
    Breaky0self
    Jupiter fl
    I have all the wiring harnesses and switches, I'm just wondering about connecting all of the lights to the battery.
  4. Feb 28, 2018 at 12:17 AM
    Old_Guy
    Old_Guy Well-Known Member
    2017 Tacoma Off Road DCSB
    I used a Blue Sea Bus Bar, connected to the battery with a 4 gauge starter cable.
    eurowner and Breaky0self[OP] like this.
  5. Feb 28, 2018 at 12:20 AM
    Breaky0self
    Jupiter fl
    You wouldn’t happen to have any pics of your setup would you?
  6. Feb 28, 2018 at 12:40 AM
    Old_Guy
    I'll try to take some tomorrow, but it's easy to do. Bolt the bus bar on drivers side fender wall. Run starter cable between battery and bus bar and you're done. I tied into the existing ground bolt that is right there for the ground wires. The bus bar comes with a cover but after I finished wiring everything up I covered the buss bar connections with JB Weld black rtv silicone. That's over kill but it keeps all the connections dry and no chance of anything shorting on the posts. It's easy to peel off if you need to get to the connections later.
    I used a short piece of aluminum bar to make a mount for the relays. I bolted it to an existing nut in the fender well. I think it was a number 8 bolt.
    Breaky0self[OP] likes this.
  7. Feb 28, 2018 at 12:57 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You should be using a relay.
    Relay gets connected to the battery, the lights are connected to the relay with the proper fuse.
    Mr-Paul likes this.
  8. Feb 28, 2018 at 1:36 AM
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    Another vote for SPOD, or in my case Switch Pro. At least consider it depending on your needs and future plans. If this is it for add on electronics let it ride. If this is only the beginning, well "buy once, cry once"
    When you say 4 lights, you mean 2 pairs (IE 2 switches) or do you actually mean 4 different switches? If it's just 2 switches you should be able to find room on the battery, or maybe upgrade to a dual post battery now for a hundred bucks. If your talking 4 sets of lights on 4 switches, that's a hole lotta switches.
  9. Feb 28, 2018 at 8:21 AM
    Breaky0self
    Jupiter fl
    These are all the electronics I'm about to add
    40" roof Light bar -HereticStudios
    20" bumper Light bar- HereticStudios
    Bought switches and Harness's which i believe comes w/relay fuse?
    Fog lights- HereticStudios
    Ditch lights/ brackets, wiring harness and switch - GGlighting
    Warn Zeon Platinum 10k winch
    Rock lights - bluetooth - Caliraised
    Also already have the Toppersezlift on my truck
  10. Feb 28, 2018 at 8:57 AM
    Breaky0self
    Jupiter fl
    Awesome thanks for the info, how many electronics do you have on the bus?
  11. Feb 28, 2018 at 9:16 AM
    Mr-Paul
    Mr-Paul Well-Known Member
    Paul
    2017 Qucksand Tacoma SR5 4x4 V6 Access-Cab
    You need a relay to run the lights off the battery; otherwise your truck is a potential inferno.
  12. Feb 28, 2018 at 10:21 AM
    Hextall
    Hextall Well-Known Member
    NH
    17 Inferno OR DCSB
    Take a look at powertray's forum here in the vendor section. They also are really helpful and will steer you right.
    boogie3478 and Breaky0self[OP] like this.
  13. Feb 28, 2018 at 10:26 AM
    Breaky0self
    Jupiter fl
    How is it naive, I clearly stated what I am trying to do and asked how to do it and what I need?
    Johnnymoto likes this.
  14. Feb 28, 2018 at 10:27 AM
    Breaky0self
    Jupiter fl
    I believe the relays are connected to the wiring harness’s
  15. Feb 28, 2018 at 10:53 AM
    Old_Guy
    I have five relays hooked to the bus bar.
    Like Johnnymoto and Mr-Paul said be sure to make solid connections and know the requirements (wire gauge, etc.) of the device you are installing.
    I noticed the question mark after "harness w/relay fuse" in your list. If the harness didn't come with the device you are installing make sure you are using the correct wire gauge and fuse rating for the device.
    The hot wire from the relay with inline fuse should connect to the bus bar and the inline fuse should be close (within a foot or two) of the bus bar.
    I use Solder Seal connectors covered with marine grade shrink tube to make any butt connections and Posi Tap connectors for any taps that are needed.
    It seems we never have the time or money to do it right, but we always have the time and money to do it over. So take your time and don't make any costly mistakes. The last thing you want is to be stuck out in the boonies with a fried ecu or vehicle fire.
    There are many excellent threads here on properly wiring different devices so do some research, and like Johnnymoto said ask questions if you can't find the answers.
  16. Feb 28, 2018 at 4:04 PM
    Mr-Paul
    Paul
    Yes, those are for the factory lights. If you are installing high amp draw lights or other accessories like an air compressor, you will need separate relay and large gauge wire with a fuse close to the battery. Otherwise it could be a fire hazard.
  17. Feb 28, 2018 at 8:08 PM
    Breaky0self
    Jupiter fl
    Thanks for the reply, all the harnesses i bought came w/each product. So is having 5-6 things hooked up to the battery w/out a Spod a hazard then?
  18. Feb 28, 2018 at 8:19 PM
    Rooster OG
    Rooster OG Well-Known Member
    Tom
    Northern California
    Cement 2018 TRD Off Road M/T
    jerzsubbie and InfidelUSA like this.
  19. Feb 28, 2018 at 8:57 PM
    Breaky0self
    Jupiter fl
    All my harnesses have relays and are specifically for each product, so shouldn't I be fine? I don't see where the spod or a similar product would be beneficial? I'm hear to learn though, so please explain!
  20. Mar 1, 2018 at 1:12 AM
    InfidelUSA
    InfidelUSA Well-Known Member
    Sierra Vista, AZ
    2017 Tacoma Quicksand Doublecab Short bed
    So with a bussmann you keep your switches/wiring going into the vehicle, just send all the wires there with 1 going to the battery/earth ground? Sorry new to this as well and I have a ARB Twin to add on. I don't particularly care for the switch pro (500 price tag is hard to justify.)
