Connector for factory fog switch
Discussion in 'Lighting' started by dougarmintrout, May 25, 2010.
  1. May 25, 2010 at 5:31 PM
    dougarmintrout
    dougarmintrout [OP] New Member
    Doug
    Seattle
    2010 Access Cab Prerunner
    I bought a factory fog light switch for my 2010 off e-bay thanks to a tip from Tacoma World. The back of the switch is designed to take a specific connector. I want to use this switch for something other than Toyota fog lights. This device has it's own harness and switch but I want to hook it up to this factory part. How do I get just the connector? I have scoured this site knowing the answer is there somewhere but after hours of looking I could use some help. Thanks in advance.
  2. May 25, 2010 at 9:29 PM
    KaoskrewPB
    KaoskrewPB -Empty-
    I did the exact same thing you did-
    I'm lookig for the site that I ordered from.
    Gimme a sec
  3. May 25, 2010 at 9:57 PM
    KaoskrewPB
    KaoskrewPB -Empty-
    Ok go to this link, http://www.toyotapart.com/EXOR.html , and enter part number 90980-11090 put in a quantity of "1".
    Enter this part number 82998-12340 and you need a quantity of "4"
    For those of you that haven't ordered the fog switch itself yet, here is the part number. The switch is the exact same as the stock switch, but for some reason you have to file down the outter edges after you pop the blank out of the dash to make the switch fit (very minimal filing required)
    84160-04010
    Pin-outs for the fog switch:
    "There are four terminals on the Tacoma switch. Looking at the rear of the switch with the locking tab on the right and starting at the top, the terminals are as follows:
    1. Input 12V from IPF Harness ( this is the red wire that comes off the UL002 IPF Harness). You can check continuity from bare end wire of the harness to the red wire that is attached to the connector where the UL002 comes in.
    2. Red wire feed to relay (this is the other red wire that comes in from the IPF harness)
    3. 12V for switch light (I jumpered this from terminal 1 so that when teh marker/head lamps are on the switch is illuminated)
    4. Ground"
  4. May 25, 2010 at 9:59 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    wow... i wish every thread was this helpful. 3 posts.. DONE. Bravo guys.
  5. May 25, 2010 at 10:09 PM
    KaoskrewPB
    KaoskrewPB -Empty-
    We can talk some more if you want :D
  6. May 25, 2010 at 10:10 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    I hear the Dodgers are doing really well huh? :p
  7. May 25, 2010 at 10:20 PM
    KaoskrewPB
    KaoskrewPB -Empty-
    Ewwww baseball :eek:
  8. May 25, 2010 at 10:22 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    baseball is rad - just.. FUCK the Dodgers and the Yankees. Seriously. (GO GIANTS)
    /end
  9. May 26, 2010 at 10:52 AM
    dougarmintrout
    Doug
    Seattle
    KaoskrewPB - you rock. Thanks for the part numbers.
  10. May 26, 2010 at 1:13 PM
    KaoskrewPB
    KaoskrewPB -Empty-
    Hey no problem man.
    Let me know if you have any more questions
  11. May 26, 2010 at 4:46 PM
    KaoskrewPB
    KaoskrewPB -Empty-
  12. Jun 16, 2010 at 2:31 PM
    hoeflich
    hoeflich Its all mod on the inside
    florida
    96 3.4L 4X4
    Stuff
    Hey man, just ordered those parts, will it connect to a hella 700 light connector? It has ground, Relay, 12V on my existing hella switch. Thanks
  13. Jun 16, 2010 at 8:58 PM
    KaoskrewPB
    KaoskrewPB -Empty-
    It should work, I would tell you how to hook them up, but I'm not sure because I didn't do the electrical myself.
    I'm sure you can find a wiring diagram for the switch somewhere, I'll see if I can find it.
  14. Jun 16, 2010 at 9:06 PM
    KaoskrewPB
    KaoskrewPB -Empty-
    The parts I have listed above are Only the connector and the wires, it does not list the fog switch itself, I will find the part number for the fog switch and edit the post so people looking for complete set can just go by that.
    The reason I only posted those 2 part numbers is because the OP already ordered the fog switch, he just needed the connecter an wires
  15. Jun 16, 2010 at 9:21 PM
    KaoskrewPB
    KaoskrewPB -Empty-
    Ok here you go, this was borrowed from an old post at the fj cruiser forums,
    4. Ground"
  16. Jun 16, 2010 at 9:23 PM
    KaoskrewPB
    KaoskrewPB -Empty-
    My post 2nd post has been editted with all new info.
    Good luck and thanks for the rep!
  17. Mar 4, 2011 at 2:59 PM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Subbed for later
  18. Mar 15, 2011 at 6:26 PM
    blacoma42
    blacoma42 Member
    Joplin,MO
    Black 09 4x4 4cyl
    Thanks for the info Aaron...Ive been trying to figure out where to get these parts for a while! Very helpful
  19. Mar 15, 2011 at 9:15 PM
    KaoskrewPB
    KaoskrewPB -Empty-
    No problem
