Conservative sound system build - Should I pull the trigger?
Discussion in 'Audio & Video' started by RTweet, May 16, 2022.
  1. May 18, 2022 at 8:19 AM
    #41
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    If I were to do it again, I would not do the spray for the roof. It keeps the truck cooler, but it was such a pain to apply, and just didnt do as good of a job as the noico I put on the doors.
    MGMDesertTaco likes this.
  2. May 18, 2022 at 8:43 AM
    #42
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I used Amazon Basics sound deadener, it was reasonably priced for a lot of it and went on well. I don't have anything to compare it to, but I am happy with it.
    soundman98 and MGMDesertTaco like this.
  3. May 18, 2022 at 8:46 AM
    #43
    TurboGT
    TurboGT Stirring the pot since...
    Gabe
    Portland
    '16 Inferno DC LB 4x4
    None yet, starting over!! OME lift w/ Dakars & 885's Remote Start w/ window control
    I spent several nights over the course of a couple weeks once I finally got home with the new truck reading through various threads, and they all seemed to come to the conclusion of using some combination of these products:
    Noico 80mil Butyl mat
    Noico Red Closed Cell PE Foam
    Frost King Duct Insulation 12 in. x 15 ft. Self-Stick Foam/Foil Insulation
    Mass Loaded Vinyl
    The Frost King stuff might not be the right product, but that's more for insulating the cab than it is for sound deadening.
    Reference threads:
    Audio Visual DIY Thread | Tacoma World
    Sound Deadener Recommendations | Tacoma World
    Ghost Ship's Removing your headliner and insulating/sound deadening | Tacoma World
    Crom's The Getaway...Crom's build and adventures
    Edit: Updated the Reference threads, specifically added Ghost Ship & Crom's threads.
    Ghost's thread is a wealth of information not only from his roof insulation project, but also several other member's projects as well.
    Crom's build thread has an entire section on his soundproofing project, one I will personally be reading through several times once I start my own cab-quieting project
  4. May 18, 2022 at 4:46 PM
    #44
    MGMDesertTaco
  5. May 18, 2022 at 4:52 PM
    #45
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
    MGMDesertTaco[QUOTED] likes this.
  6. May 18, 2022 at 5:07 PM
    #46
    MGMDesertTaco
    Noico 80 has really good reviews on Amazon for the price. I'll probably do the same.
  7. May 18, 2022 at 5:15 PM
    #47
    venezian
    Los Angeles
    2022 7545E
    Noico Red 150 mil (4mm) 36 sqft (3.4 sqm) Noico Liner Car Heat and Sound Insulation,Heat and Cool Liner, Self-Adhesive Closed Cell Foam (PE Foam) https://www.amazon.com/dp/B07TKXMPH7?_encoding=UTF8
    I’m using this for the roof. Possibly the rear panel.
    Noico 80 mil 18 sqft car Sound deadening mat, Butyl Automotive Sound Deadener, Audio Noise Insulation and dampening https://www.amazon.com/dp/B012B5EMGO
    This for the doors and door panels.
  8. May 18, 2022 at 9:41 PM
    #48
    TurboGT
    Gabe
    Portland
    Use it for the floors and doors too, that will help silence noise coming in from those points
  9. May 18, 2022 at 10:45 PM
    #49
    venezian
    Los Angeles
    2022 7545E
    On top of the sound deadening?
  10. May 18, 2022 at 10:53 PM
    #50
    MGMDesertTaco
    After reading this I had to go back and find your post. I've seen buckets of this stuff for sale recently, but haven't paid much attention to it until now. The prep involved to mask everything, wow!
    https://www.tacomaworld.com/threads...onents-3-amps-wow.576729/page-2#post-20992987
    I agree on the Noico alternative or something similar. No way in hell am I spraying that cottage cheese whipped cream mess all over the inside of my truck. Reading your impressions after the drive through car wash did kind of give me a moment of "what if" though. :rofl:
    soundman98 and 5nahalf[QUOTED] like this.
  11. May 18, 2022 at 10:59 PM
    #51
    MGMDesertTaco
    I'd do Noico on the inside of the door cavity and either the Noico or the foam on the door that the panel attaches to. I don't think there's much to gain from doing both layers plus the inside of the door cavity, but I could be wrong. Kind of like diminishing marginal utility in economics. Also, you might run into issues with material thickness and getting the panel to attach to the door with multiple layers. :notsure:
    Some foam tape between the speakers and speaker mounts might be more beneficial.
    soundman98 likes this.
  12. May 19, 2022 at 6:32 AM
    #52
    5nahalf
    Erik
    Minnesota
    Dont get me wrong the stuff is great and works well. The heat stopping is the main reason I like it, but I would only do it again if I pulled the whole inside of the truck out, removed all wires, and taped everything proper inside a garage or shop.
  13. May 19, 2022 at 9:44 PM
    #53
    TurboGT
    Gabe
    Portland
    @MGMDesertTaco @venezian I updated my post earlier with the links I couldn't find earlier at work
    Turbo's updated post
    @RTweet - sorry for clogging up your thread with some slightly off-topic stuff. Also, I hope you got my DM... pretty sure you and I are local enough that if you want a hand with stuff, I'm more than willing to help.
    venezian and MGMDesertTaco like this.
  14. May 19, 2022 at 10:13 PM
    #54
    RTweet
    RTweet [OP] Well-Known Member
    Oregon
    2021 White TRD Pro, MT
    No worries at all! Yah man, I just saw that. I’ll hit you up when everything gets in. I appreciate the offer!
  15. May 19, 2022 at 10:23 PM
    #55
    TurboGT
    Gabe
    Portland
    feel free to hit me up sooner if you still need some assistance on planning stuff out. If you haven't gotten the Kicker speakers already, consider some of the CDT Audio stuff that's on sale this month... you could get (what I assume to be) equal or better stuff at cheaper prices. I'm a ways out from installing things, but I'm thinking that MX-2692 that I linked in MGM's thread will do me wonderfully, and at half the cost of the Kickers you're considering
  16. Jun 23, 2022 at 11:30 AM
    #56
    BIGW0RM
    BIGW0RM Well-Known Member
    The XP6903C tweeters fit the tacoma? Did you need a custom bracket?
  17. Jun 23, 2022 at 1:17 PM
    #57
    MGMDesertTaco
    You'll have to trim the dash a bit for the 3 1/2's, but once the grille cover is back on you won't see it.
    BIGW0RM[QUOTED] likes this.
  18. Jun 23, 2022 at 1:18 PM
    #58
    MGMDesertTaco
  19. Jul 13, 2022 at 8:53 AM
    #59
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
  20. Jul 13, 2022 at 4:46 PM
    #60
    japjoe7
    japjoe7 Well-Known Member
    Joey
    Pike County, PA
    21 Barcelona Red Sport DC AT
