Considerations for a Plate Bumper
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wynner, Aug 22, 2013.
  1. Aug 22, 2013 at 3:48 PM
    Wynner
    Wynner [OP] Member
    I’ve been contemplating getting a plate bumper and have spent much time reading through the threads. I’ve distilled my thoughts into one spot and was hopping for some feedback and discussion. I can update the list if people have other points of consideration for getting these types of bumpers or not.
    1. Factory Warranty Issue – From my understanding, by the letter of the law, installing an aftermarket part does not void the warranty. However, a shop may make life difficult on you and forcing them to repair any warranty issues will be a lengthy process unless you find a mod friendly dealership.
    2. Coating – There appears to be three popular choices; spray paint, truck bed spray liner and powder coating. Painting is the least expensive and easily touched up but least durable. Spray liner offers great resistant to chipping as it’s a rubber coating and can be easily touched up. Depending on the texture some find it difficult to keep clean. This option can be inexpensive if you do it yourself via spray can or moderately expensive if done by a professional. Powder coating is very resilient but some may argue that point. Touchups are up for debate as some say it’s difficult while others say it’s quite easy. As for cost this is the most expensive of the three.
    3. Alloy Type – Steel vs Aluminum. Steel is significantly heavier than aluminum and I’ve seen quotes of 40% less than an equivalent bumper. However steel is stronger and aluminum can crack. Steel bumpers tend to require a beefier suspension and if a wench is attached it’s necessary. Aluminum can be a good option for those who do light off-roading and spend the majority of their time on asphalt. The weight reduction will save on gas. From my understanding aluminum is harder to work with and can bend/warp during fabricating. As for cost aluminum bumpers are more expensive.
    4. Crash Testing – There is no way small fabricators will have this type of data and other larger manufactures such as ARB claim to have crash tested their bumpers. Will the new bumpers effect airbag deployment and other collision mitigation systems? Is this something that you guys have considered or have experience with?
    5. Insurance – Is there any issues with the insurance if one was in an accident?
    6. Longevity – Have you had issues with corrosion and longevity of these bumpers?
